What is the best battery operated chain saw
   / What is the best battery operated chain saw #101
Not sure where you are getting your chains, but over $40 is a complete rip-off. I can get replacement chain for the Milwaukee M18 Fuel chainsaw a whole lot cheaper than that. The saw comes with a 16" bar, 0.043" gauge, 3/8" Low-profile chain with 56 drive links. Baileys (who is not the cheapest place around to buy chains) sells a few options:
WoodlandPRO 34LP56 for $13
Oregon 90PX056G for $17
Stihl 61PMM356 for $22
I'm not a big fan of the Woodland Pro, but the other two manufacturers make good chains.
I’d bet that the Stihl chains are made by Oregon anyway.
   / What is the best battery operated chain saw #102
Does Oregon make some of the stihl chains? Mine all say Stihl on the drivers.
   / What is the best battery operated chain saw #103
It appears so...
Amazon has it for about half or a twin pack for $47.
#3670 (71 PM3 72) OILOMATICョ saw chain
OILOMATICョ CHAIN 1/4" STIHL PICCO 14" bar length
MSA 200 C-BQ 14" bar
   / What is the best battery operated chain saw #104
Just checked Baileys... $29.99 which sure beats $40 until Baileys adds the $9.99 shipping making it 39.98 which is what I paid plus tax.
Also, if I am reading it right there is no other option from Baileys for the 1/4" pitch but Stihl.
I would love to save but it seems Bailys is the same as the Stihl shop where I bought my 3 loops.
Stihl 14" 71PM3 Chainsaw Chain Loop (1/4 x .043) 72 Drive Links, SKU STL 71PM372
Swiss made OEM chainsaw chain from Stihl. Stihl saw chain is made for the most demanding cutting conditions and is loaded with professional features. Stihl chain has Oilomatic drive link lubrication slots, which funnels oil directly to the rivet to reduce wear. Stihl chain is also pre-stretched at the factory, which helps eliminate excess adjustments during break in periods. 71PM3 is part of the Stihl Picco Micro 3 series.
This chain has reduced kickback and low vibration features. 71PM3 is a narrow kerf (.043") low profile saw chain designed for lightweight chainsaws and pruning saws. The combination of reduced kickback and low vibration features with improved cutting and boring efficiencies make it a favorite of professional arborists.
   / What is the best battery operated chain saw #105
Brushless Makita 36V, 14". Has an Oregon Bar and Chain. Part of Makitas push into 36V by using 2 of the existing 18V Batteries.
We have a String Trimmer/Brush Cutter, and the Chainsaw and both work incredibly well. I would never have thought them as replacements, but haven't picked up either of the 18" .30's or the Sthil Trimmer since we bought them. I did change the String Bump for a Tanaka push pin and picked up 2 spare chains from Oregon. I prefer to swap the chain in the field and sit with a beer later sharpening.
All I can really say about both, without sounding like a commercial, is yes they do their job, do it well, have never complained, battery life is excellent and unexpected, wife acceptance is through the roof. She will even grab the Makita for some trim work, rather than wait for me to add it to list. Also she grabs the String Trimmer snaps in the batteries and has no problem trimming around flowers, hedges, house, walk way, etc. Even has spun on the blade and smacked the thicket around. :D
You pay for the privilege, but if asked if I would do it again, after over a year of use, the answer is absolutely yes. So much so, I am salivating over the Compound Miter....
Ohh crap, forgot about the Hand held blower. It has become such a standard use item. I don't even think about it. Used almost daily to blow leaves, sticks, acorns, nuts, dirt, what ever, from walks, driveway, porches, etc. Use it to blow dust out of the tractor and debris from behind the seat, and oh so many things. Such an easy and quick grab, anyone around here has no prob using it without hesitation. Adjustable air and crazy power. Full tilt, using a 6 setting (which is rare tbh), it will go about 1/2 an hour to 45min, normally we rarely need to re-charge.
Makita batteries charge in 15min. From dead to over 80-90%.
Feel free to ask any questions.
   / What is the best battery operated chain saw #106
i have the milwaukee chainsaw. it does the jb - but you really have to use the high output batteries that i over 200 bucks for one. if you try to use the batteries for drill that is less then 9 .0 it only runs for 10 mins. the high output battery lasts for about 20-30 mins thru 16 inch oak logs. i prefer to use gas as i can keep going without carrying the batteries with me but the battery saw is perfect for limbing or that 10 min job so i keep it in my work van at all times. If I knew i was going to cut down a tree - I am going with my gas saw - period.
   / What is the best battery operated chain saw #107
How many cuts through 10" diameter logs (mix of maple, birch, ash, oak) do you estimate the saw will make before a recharge?
Thanks,
   / What is the best battery operated chain saw #108
Bailey's WoodlandPRO 71SC is 1/4" .043. I find the Woodland Pro chain does not stay sharp quite as long as Stihl but it's cheaper. I use it for larger saws for felling and bucking.
I group up my Bailey's orders to amortize the shipping cost across many items. Also the gas to drive to the Stihl dealer costs about as much and it takes more of my time.
   / What is the best battery operated chain saw #109
No. Stihl makes their own chains, and there has traditionally been a noticeable difference between Stihl and Oregon. Both seem to me to cut about the same (assuming you chose similar types of chain). Stihl seems to be a bit harder metal, so tends to hold an edge longer, the oregon chains are easier to sharpen. Either one is toast if you hit something you shouldn't when cutting.
For years, Husqvarna chain was just rebadged Oregon chain. within the few years, Husqvarna started making there own (some styles may still be rebadged Oregon. I'm not sure if the Husqvarna facility can meet all of their needs.)
Not too long ago, both Husqvarna and Oregon introduced new chains. If I remember correctly, for Husqvarna, it's the "X-Cut" family of chains. Oregon's new offering is called "SpeedCut". I've not used either myself yet, but have heard they are good performers, and the durability/hardness is more similar to the Stihl chains. I'll be picking some up one of these days to try it out.
   / What is the best battery operated chain saw #110
I've never had anything bad Makita... it was my first cordless back around 1983 and still have it...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
16001 (A55853)
16001 (A55853)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
