YM226D Starter
/ YM226D Starter #21
Glad I own a yanmar and they can keep the high dollar LS on their Forum that's for sure. I thought JD. was High Geeese!!. That time of yr. here to get everything up and going. Checked my battery day before yesterday. Sat for Months and it read 12.35. so it looks like my 11yr. old battery just may hang in there another Yr.. My starter seemed slow end of last yr. so I have a feeling I'm going to need to replace my cables. I had to replace them when my Starter went down the first time. Used a couple old marine clamps and cables I had laying around so Hey!! 10yrs.. That's on the to do list since the battery still seems to be good. I can only check volts not AMP's so will see.
/ YM226D Starter #22
you can get an accurate starter current tester cheaply, it should draw around 100 amps. BSIDE ACM3 Plus Auto Range Digital Clamp Meter AC DC Current Voltage Hz Tester 8392621 | eBay
/ YM226D Starter #23
you can get an accurate starter current tester cheaply, it should draw around 100 amps. BSIDE ACM3 Plus Auto Range Digital Clamp Meter AC DC Current Voltage Hz Tester 8962392621 | eBay
That shows measuring up to 400 amps DC using the clamp. I've never seen a clamp meter that would measure DC, only AC.
Edited: I went and read the reviews on Amazon. Several owners confirmed this can measure DC amps, up to 400 amps. Its not a Klein or Fluke but for ~$25 it looks like a good buy.
/ YM226D Starter #24
If there wasn't any shops around me. Which I have all the Big chain I'd hop on that also!! There all check it for free. But I only have 2 12V batteries to keep up with now. My truck and the Yanmar. Just replaced the Truck. This winter killed it. Went to start it and it barely turned the motor over. Poped the hood 11.85.. It was Still under Warranty so they didn't even check the amp's. Now back Yrs. ago I'd be on that meter also more of just to have it handy.
/ YM226D Starter #25
if Fluke can do it, then others can too. it uses hall effect sensors to measure the DC current.. Clamp Multimeters | Fluke 325 True-RMS Clamp Meter | Fluke
/ YM226D Starter #26
Sears used to sell one that didn't have any electronics, it had channels you put the wires in, there were 2, for high and low range, it worked on electromagnetism. it seems that type is not sold anymore, though..
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
WABBLE BOX & HYD PUMP (A63745)
WABBLE BOX & HYD...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Hyster H65M Forklift (A64047)
Hyster H65M...
2006 Polaris Sportsman 90 (A64047)
2006 Polaris...
Informational Lot - Financing (A63118)
Informational Lot...
