Rounded off drain plug
/ Rounded off drain plug #1,321
Did anyone ever consider his strength may be a result of what he smokes in that pipe of his?
:laughing::laughing::laughing: The Spinach was just for the munchies :drink:
/ Rounded off drain plug #1,322
What characteristic sets the BICO apart?
I like the way it feels in my hand but it also is 3/8" drive if you pull the tip off that holds the screw driver bits so you can use it with sockets on nuts or bolts. I know that with modern impact tools this may not be the attraction it was 30 or 40 years ago but there is less chance of rounding off a hex head while trying to break it loose.
Everyone has their likes and dislikes but to me this is an oldie that I like.
With what?
After so many tool suggestions you report that you "got a good hold" but neglected to say what tool got the "good hold".
8" ridgid pipe wrench. Need the small jaws to actually bite, but handle length is the problem.
/ Rounded off drain plug #1,324
Here’s the first Knipex tool Im disappointed with. I own several pairs on knipex pliers of outstanding quality. My buddy is a snapon addict and in general I wouldn’t trade my Knipex pliers for his snapon. He bought a pair of locking pliers. I wanted to see how the knipex compared against vicegrip and snapon. I got these in the mail yesterday and I’ve never used them so I can’t say how the teeth quality is. The jaw rack is pitiful. I’ll be sending these back. If these were $5 China crap you could probably squeeze the body in a vice and tighten them up but these weren’t supposed to be crap.View attachment 592779View attachment 592780
Knipex is supposed to have 61 Rc jaw hardness. ... Clamp those on a dowel pin 1/4 turn tighter than you can possibly do by hand, Use a vise to operate the handles. A Vise Grip wont make a mark because the jaws are too soft. If it leaves a mark that is a superiority. If it doesnt, can you now close it at the SAME setting by hand? If you can, advance 1/4 turn and try again. Same result; it is inferior to Vise Grip.
/ Rounded off drain plug #1,325
/ Rounded off drain plug #1,326
Im guessing it is impossible to extend the handle with a pipe? :confused2:
/ Rounded off drain plug #1,327
If I had a pipe suitable to use i would have done so and reported results on it. As such i don't, nor have a looked for one. I had the tractors out and decided to give it another try while draining engine oil.
/ Rounded off drain plug #1,329
No worries. The fact that you have a wrench that grips is encouraging news, The next step is easier. So what are you doing with your tractors now, snow removal?
/ Rounded off drain plug #1,330
Now do not go rushing things. Easy does it. :D
Pretty much, although just with the 960. The 5000 would be much more suitable, given filled rear tires except for the shape those tires are in. Poor tread and both tires have been patched by previous owner. A nice ~2x2" spot on both. It would probably still pull better due to sheer weight though.
/ Rounded off drain plug #1,332
Should we discuss different ways to get those tires off of the rim?
/ Rounded off drain plug #1,336
Thats the spirit, slow and easy can get the job done. Not everyone is intimidated by todays fast pace :laughing:
/ Rounded off drain plug #1,338
I think it was Red Green that once said "if a man said he will do something, he will do it. There is no reason to badger him for 2 years about it." :laughing:
/ Rounded off drain plug #1,339
Off is easy, getting the new ones back on.....
Let's not get the cart before the hors,,,,,,,,,tire before the tractor.:no: We should discuss methods and tools for removing valve core,then we can talk about the tire. Re-inflation should be in a seperate thread.
/ Rounded off drain plug #1,340
Stanley classic 99 razor knife, no need to remove the core :D
2021 FREIGHTLINER M2 106 S/A 4X2 24FT BOX TRUCK (A59909)
2021 FREIGHTLINER...
Genie Z60 Articulated Boom Lift (A64047)
Genie Z60...
2015 FREIGHTLINER  2500 4X2 SPRINTER VAN (A59909)
2015 FREIGHTLINER...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
