Replacing hydraulic lines
/ Replacing hydraulic lines #1
kenjohn63
LS XR3037H
I have a 2014 xr3037h, and I need to replace 2 hydraulic lines. One end is mounted way inside the firewall. How do you get to them? I I thought maybe I would pull the hood tomorrow, and see if that’s possible. Anyone else done this and have advice? Thanks in advance.
/ Replacing hydraulic lines #2
Thanks. I’ll take the hood off.
I completed the job a couple of days ago. It was not a fun project. Lots of minor hand cuts and scrapes.
They are power steering lines. Out of the 4 connections, there is only 1 that is easy to get at. The two on the firewall were really recessed in there. Took the hood, hood bracket, and some other minor stuff to get at them. Then we heated and bent some wrenches to get in there. Only problem was, once you bent the wrenches, you couldn’t get enough torque to break them loose. Finally we were able to get the open ends on partly. We then with a pipe on the end , we’re able to get them. If there was a way for the mfg to mount that male connection in the firewall out a bit, it would be a lot easier. I even called a technician at a LS dealer, and he said there is no easy way.
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2022 EZ-GO ELITE...
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
