JD 990 electrical problem
/ JD 990 electrical problem #1
RKettle
Northern Colorado
John Deere 990, 1942 Ford 8n
My John Deere 990 won't start unless I put a jumper from the positive post on the battery directly to the starter....Then it starts and runs fine. I assume there is a blown fuse in the mix but can't find it. Any suggestions would be appreciated.
/ JD 990 electrical problem #2
Well, that MIDI Designer patch editor for the 990 looks incredible.
I wonder if he'll expand it to work with a JV-1080 (which holds more of the expansion cards).
I tend not to do much programming on my 1080 just because it's basically menu-diving and it already has more presets than I'm likely to hear in a lifetime, but it does sound really good. Just a simple mixer interface to mix the separate channels would be helpful too.
I have no doubt that that combo would be a good time, especially if you're running a sequencer as well.
/ JD 990 electrical problem #3
I have a PDF of the Deere tech manual you're welcome to, all the wiring is in it, shoot
me your email if wanted
joe
/ JD 990 electrical problem #4
Dale
/ JD 990 electrical problem #5
Did you try jumping to terminal on solenoid to see if you can energize solenoid and spin up starter?
Dale
/ JD 990 electrical problem #6
If a jumper to the solenoid won't crank it and a connection to the starter motor armature does, then the contacts inside the solenoid are worn out. Look on ebay for Denso replacement contacts. It's a common problem. I replaced mine a few years ago. Same symptoms.
:thumbsdown::thumbsdown::thumbsdown::thumbsdown::thumbsdown::thumbsdown::alert::alert::alert:
Spam
I'll give that a try today. Thanks
/ JD 990 electrical problem #9
My guess is you meant to post this on another forum, not TBN? :laughing:
Your other posts are tractor related. Do you have an audiophile habit as well as a tractor habit? :laughing:
2003 International 7400 T/A Dump Truck (A66736)
2003 International...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2011 INTERNATIONAL PROSTAR (A67714)
2011 INTERNATIONAL...
2018 JOHN DEERE 320G SKID STEER (A65056)
2018 JOHN DEERE...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
PALLET OF DISCHARGE HOSES MISC SIZES (A68842)
PALLET OF...
