Pulling a Ford engine with my Kubota
/ Pulling a Ford engine with my Kubota #1
dkchandler
Member
Little Rock, AR
2002 Kubota BX2200
Hey guys, I have a question. I am pulling the motor out of my son's 1999 Ford F-150. The 5.4L engine should weigh about 550lbs.
It seems like my 2002 BX2200 with a LA211 FEL is having issues lifting the engine. Is that too much weight for the LA211??
Thanks
Dan
/ Pulling a Ford engine with my Kubota #2
I think answer is yes. According to Tractordata.com, lifting force (full height) is 460lbs at pins.
Perhaps if front of Kubota was raised so loader was low, you could be closer to utilizing the breakout force of 950lb?
Loader type: Kubota LA211
Height (to pin): 71.3 inches [181 cm]
Clearance, dumped bucket: 51.2 inches [130 cm]
Dump reach: 29.9 inches [75 cm]
Dump angle: 45
Rollback angle: 25
Breakout force (bucket): 950 lbs [430 kg]
Lift to full height (at pin): 460 lbs [208 kg]
Bucket width: 48 inches [121 cm]
Raise time to height: 2.9 s
Lowering time: 2.9 s
Coby, thanks for the quick reply. I will try it a a lower height. I may have to go old school and use a come-a-long and a nice tree limb to pull that engine.
/ Pulling a Ford engine with my Kubota #4
I doubt it’d going to do it. My L3800 just barley pulled a 454. IMG_0976.JPG
/ Pulling a Ford engine with my Kubota #5
I’m no engineer but it would seem the more inline the lift cylinders are with the direction of lift the less force it “used” pushing against the pivot point.
In other words, wouldn’t you get the most lift with the bucket at the top of its travel? With the FEL lower the cylinders are having to push out instead of up.
If I’m on the ragged edge of a lift with my tractor I find that using curl gets me more lift. The other trick (as mentioned above) I use to lift heavy rocks is to attach the the chain as far “back” as I can. Like the chain comes off the back of the bucket instead of the front.
/ Pulling a Ford engine with my Kubota #7
Portable engine hoists are pretty cheap, and readily available at rental yards.
Buy one and resell it after you are done. You’ll minimize chances of damaging something with a purpose built, easily controllable tool.
/ Pulling a Ford engine with my Kubota #8
Yep- OP may be able to borrow a cherry picker from 1 of the part stores if he buys replacement parts there and they offer that service.
/ Pulling a Ford engine with my Kubota #9
You have an LA211 loader. The first digit, 2 (hundred kilograms) x 2.2 (pounds in a kilogram) = 440 pounds. That is how Kubota rates their loaders. Now, I don’t know at what height or distance but that is how it goes. You probably won’t lift your sons engine with your tractor.
/ Pulling a Ford engine with my Kubota #10
/ Pulling a Ford engine with my Kubota #11
Can you remove your front bucket and lift the engine without it on?
Or remove the intake manifold and the heads to reduce the weight of the engine?
/ Pulling a Ford engine with my Kubota #12
The price of the replacement gaskets would probably exceed the price of an engine hoist. I’m pretty sure this motor has aluminum heads and a plastic intake manifold so it wouldn’t help much anyway.
That is a thought, I could remove the heads, the intake is already removed. The intake is plastic, no weight there. The heads are aluminum, but they are huge, may lose enough weight. Oh, no I cannot remove the front bucket easily, that is the larger models that can do that. My FEL is nothing more than a fancy wheel barrel. LOL
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
