deezler
Elite Member
- Joined
- Jan 30, 2012
- Messages
- 3,895
- Location
- Southeast MI
- Tractor
- Cub Cadet 7305, Kioti CK3510seh TLB
Have to agree with wagne223, you need to hang a heavy implement off the back of the tractor asap. I know you loaded water into your rears... maybe that's enough, but why chance it. A 600+ lb implement hanging off the 3-pt give you huge leverage to counter full buckets of sloppy clay like that.
If you lift a rear wheel, it means you're putting nearly the entire tractor, loader, and dirt weight on the front axle alone. If your front wheels are down in a ditch, and you have to reverse, think about how much strain that is on the front drivetrain. No bueno.
If you want to search here and elsewhere, you can easily find threads and pics of peoples exploded front axles. Even worse if Mahindra sees you didn't use rear ballast, warranty might not cover any repairs. Keep your machine planted down!
