bucket forks hold downs
/ bucket forks hold downs #1
coupman35
Gold Member
Northen Ontario
Now a L4060 had B2650
I made a set of forks they work good but the hold down are not that great I used a treated 5/8 rod and welded a washer in the botthem but it hard to get them real good . i need to find a way to get a flat bearing in there some how.The one in the pic are something like I have but whit a washer in the end .Any one ever done some thing like that
/ bucket forks hold downs #2
Perhaps your washer is the problem. Too much smooth surface to skid around.
Try using JUST the bolt as it may “bite” better. Or go up a size or two in diameter.
/ bucket forks hold downs #3
Yep, most use just the end of the bolt (or the pointed end of the bolt) so that they will "dig in" and keep it from sliding around.
Aaron Z
I saw lot of them have a set up like a vise clamp style like this
/ bucket forks hold downs #5
I use 2-1"x 4" bolt on each fork.
/ bucket forks hold downs #7
I bought swivel pads to put on the hold down bolts, they work really well.
/ bucket forks hold downs #8
handtools where did you purchase the swivel pads from? They appear to be well made. Do you have a link you could post?
TIA
/ bucket forks hold downs #10
In the photo they look like a 15/16” bolt head which would make them 5/8” D
Nope there 16/16" bolts, when I bought them I ran the threads up higher with 16/16" thread die. The bolts are going through doubled up truck spring.
Here's a picture of my homemade 16/16" wrench, made out of truck spring.
/ bucket forks hold downs #11
I think I would've put two of those clamps on each fork but seeing how those clamp pads are pushing $40.00/ea, I'd have one clamp with no pad and most important I'd have short pipes on top of each clamp bolt and run a bar though that like a regular C clamp. So on each fork, one clamp near cutting edge, and one clamp in the bucket.
/ bucket forks hold downs #12
Thanks. Good thing my annual optometrist appointment is coming up
soon.
Them clamps are very cool id like to get 2 of them am going to look them up.
/ bucket forks hold downs #14
You get 2 swivel pads for that price.
/ bucket forks hold downs #17
Not SEEMS more. We do pay more.
/ bucket forks hold downs #20
McMaster Carr has a good selection of those swivel pads, they also sell the replacement pads for c-clamps that snap onto the ball end.
McMaster-Carr
1770 (A58375)
1770 (A58375)
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
4021 (A59228)
4021 (A59228)
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
E-Z TRAIL HEADER CART (A63291)
E-Z TRAIL HEADER...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
