bucket forks hold downs
/ bucket forks hold downs #1
coupman35
Gold Member
Northen Ontario
Now a L4060 had B2650
I made a set of forks they work good but the hold down are not that great I used a treated 5/8 rod and welded a washer in the botthem but it hard to get them real good . i need to find a way to get a flat bearing in there some how.The one in the pic are something like I have but whit a washer in the end .Any one ever done some thing like that
/ bucket forks hold downs #2
Perhaps your washer is the problem. Too much smooth surface to skid around.
Try using JUST the bolt as it may “bite” better. Or go up a size or two in diameter.
/ bucket forks hold downs #3
Yep, most use just the end of the bolt (or the pointed end of the bolt) so that they will "dig in" and keep it from sliding around.
Aaron Z
I saw lot of them have a set up like a vise clamp style like this
/ bucket forks hold downs #5
I use 2-1"x 4" bolt on each fork.
/ bucket forks hold downs #7
I bought swivel pads to put on the hold down bolts, they work really well.
/ bucket forks hold downs #8
handtools where did you purchase the swivel pads from? They appear to be well made. Do you have a link you could post?
TIA
/ bucket forks hold downs #10
In the photo they look like a 15/16” bolt head which would make them 5/8” D
Nope there 16/16" bolts, when I bought them I ran the threads up higher with 16/16" thread die. The bolts are going through doubled up truck spring.
Here's a picture of my homemade 16/16" wrench, made out of truck spring.
/ bucket forks hold downs #11
I think I would've put two of those clamps on each fork but seeing how those clamp pads are pushing $40.00/ea, I'd have one clamp with no pad and most important I'd have short pipes on top of each clamp bolt and run a bar though that like a regular C clamp. So on each fork, one clamp near cutting edge, and one clamp in the bucket.
/ bucket forks hold downs #12
Thanks. Good thing my annual optometrist appointment is coming up
soon.
Them clamps are very cool id like to get 2 of them am going to look them up.
/ bucket forks hold downs #14
You get 2 swivel pads for that price.
/ bucket forks hold downs #17
Not SEEMS more. We do pay more.
/ bucket forks hold downs #20
McMaster Carr has a good selection of those swivel pads, they also sell the replacement pads for c-clamps that snap onto the ball end.
McMaster-Carr
2016 John Deer 5075E (A60462)
2016 John Deer...
2004 Ford Explorer SUV (A61569)
2004 Ford Explorer...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
2014 KENWORTH T370 QUINT/A  DUMP TRUCK (A59906)
2014 KENWORTH T370...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
