Who's got a log splitter that they run off the PT?
/ Who's got a log splitter that they run off the PT? #21
Would you have pictures of the upside down splitter on the FEL quick dis-connect plate ? I would like to see that. I have some monsters to split. Thanks in advance.
Ugly but it’ll split just about anything up to 32”.
/ Who's got a log splitter that they run off the PT? #22
I'm thinking some people are thinking the title of this thread is asking if they're running their splitter off of their PTO. The PT in the thread title stands for Power Trac.
PT, ALSO stands for "power takeoff".
SR
/ Who's got a log splitter that they run off the PT? #24
I understand that, but many of us just read the "New Post" and (in my case) didn't realize we had posted in the Power Trac forum...
BTW, I'm old and PT stood for power take off, LONG before there was a power trac. lol
SR
/ Who's got a log splitter that they run off the PT? #25
SR
Yup, my first PT was on a Ford 8N? Was used in an apple orchard for mowing and moving bins. :thumbsup:
/ Who's got a log splitter that they run off the PT? #27
I want to see more of that what is it where’d you get it
Mine runs off a PTO powered hydraulic pump...
What would I do different? I would have bought it a LOT sooner!!
The one that I have that runs off the remotes, it's too sloooooow...
SR
/ Who's got a log splitter that they run off the PT? #28
I want to see more of that what is it where壇 you get it
It's a Timberwolf TW3HD,
It's fast and really kicks azz, pushing EVERYTHING through the 4-way wedge,
Even my wife loves to run it,
We roll the big ones, right off the wagon onto the splitters beam,
Anyway, I called several Timberwolf dealers, shopping the best price, then bought it...
It's one of my best buys!
SR
/ Who's got a log splitter that they run off the PT? #30
Thatsa nice setup!
Thanks, I have a system worked out and it works pretty good for me...
I cut/skid the logs out of the woods,
then use the tractor to lift and hold them over my wagon while they get cut into firewood lengths,
next, pull the load home and move the splitter into place for splitting...
SR
/ Who's got a log splitter that they run off the PT? #31
That’s a nice set up you have there. thanks for the pics
/ Who's got a log splitter that they run off the PT? #32
Is that an Agco Alis 5660 tractor with a Quicke 310 loader if so that is the same tractor and loader I have, love it.
/ Who's got a log splitter that they run off the PT? #33
Yup, it's an AGCO 5660, has the 16 speed tranny and over size tires, the loader in an ALO 310...
I love mine too...
SR
/ Who's got a log splitter that they run off the PT? #34
I've had a SplitFire 2PH splitter for years. Running off the tractor hydraulics can be slow, but the SplitFire splits in both stroke directions, you aren't ever waiting for it to retract before splitting again. I like it a lot, including being able to set it to whatever height is comfortable.
/ Who's got a log splitter that they run off the PT? #35
I have asked this question many times myself. I read this thread with much interest and was surprised no one offered an alternative! There are lots of benefits to having a stand alone splitter. It leaves your tractor available for dragging wood to the sight, using a grapple to gather and chainsaw logs to length, move split wood to stacking location. But the most important advice for me was not racking up the hours on the alpha machine that I count on for everything. Good luck with your search!
/ Who's got a log splitter that they run off the PT? #36
Read post #17. ;)
/ Who's got a log splitter that they run off the PT? #37
That’s why one PT just isn’t enough. :)
/ Who's got a log splitter that they run off the PT? #38
This is the Black Diamond 3pt hitch log splitter that I “attached” to my 425. It works both horizontally and Vertically. I welded an attachment plate to the side of the splitter so it sits perpendicular to the tractor. This make it easier to move around. It works great running off the Aux hydraulics and I can split some pretty massive rounds in the vertical mode.
/ Who's got a log splitter that they run off the PT? #39
I bought a Black Diamond 3pt hitch log splitter, welder and accessory plate to the side so it sits perpendicular to the tractor. It works off the Aux hydraulics.
Splitter $700.00
Quick connectors (purchased from PT) $90.00
Two 1/2” hoses made locally $130.00
Accesory plate I bought with tractor & dont’ remember $
/ Who's got a log splitter that they run off the PT? #40
I have a walenstien? I like that I can drop the splitter to the ground and roll the heavy log on then lift it to a height that saves my back. Try that with a stand alone, lol. I change the oil on the alpha and don’t worry about the hours run. Probably does it good. Anyway to each his own. My logs are piled early for splitting, then cut, then split. I don’t run and get a log, cut the log, split the log and start again. But hey, there are pluses and negatives to everything, eh?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Wooden Wagon Wheel Rocker (A61569)
Wooden Wagon Wheel...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2016 Ford E-350 Passenger Bus (A61568)
2016 Ford E-350...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
