Amazed !
/ Amazed ! #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
After visiting my son in Arkansas and seeing all the farming that goes on there, I'm amazed at the size and brand of the tractors those farmers use .
You don't see any Kubota's, Kioti's, Ls's, TYM's, Yanmar's, etc, plowing the fields.
Guess they just don't build a tractor big enough, or tough enough for the job.
All you see there are Big JD's, Case, Some JD's with Tracks, and some New Holland's
/ Amazed ! #2
Same here, the other brands do build some decent size tractors but you don't see them working around here either. Farms I see around here run big Deere's and some NH, up in the potato belt they run a lot of old IH..
/ Amazed ! #3
A lot of that is the scale of their operations. We have a couple that use Case QuadraTracks and other large equipment. There is at least one that runs multiple large JD combines side by side. They have their own fleet of grain trucks and refueling tankers. Some of their trucks are set up with platforms for their crop spray helicopters to land and reload spray tanks.
JD and Case Ag handle the leased machines; the farmers don't own much of anything.
I don't know if Big Orange finances on that level or not, but I know most of the others you mentioned don't.
/ Amazed !
Do you live in area too ?
They run allot of those quads case and JD. in Arkansas
Never seen a quad orange tractor
Never seen a orange combine either
/ Amazed ! #5
Same here.
/ Amazed ! #6
Jd , Ferguson and case/NH build tractors big enough for large scale farmers. All the others build for home owners and hobby guys.
/ Amazed ! #7
This kind of came up in another thread.
Yanmar's biggest machine sold in the US is 59 HP/4442 lbs. Not near big enough to be a working farm's "big" tractor.(I am, of course, generalizing. I'm sure someone, somewhere, is "farming" 800 acres with one)
LS offers 100 HP/7,714 lbs. It would be...difficult to run a dairy/cattle operation with such a light tractor. Maybe if you lived on dead flat ground.
TYM's biggest machine is 105 HP/8666 lbs. Not big enough for a lot of tillage. You could maybe run a smaller dairy/cattle operation with it.
Kioti offers 110HP/9064 lbs. Like the TYM you could maybe have it as your "big" tractor on a smaller dairy/cattle farm, where row crop acres are minimal and you're primarily doing hay and pasture maintenance.
Kubota's biggest tractor available in the US is the M7-171. It's a medium sized tillage machine. It "only" weighs 15,000 lbs. You could run a modest sized, 500ish tillable acre farm with it before things got out of hand.
Case Magnums, JD 8Rs, Fendt Varios, challengers, etc all push well past 200HP/20,000 lbs. And Quadtracks, JD 9Rs, Versatiles, etc are on another tier beyond that. A 9620R weighs 43,000 lbs minimum, has 620HP, and could pick the M7 kubota up with its 3pt. Weight is work done when it comes to tillage.
Most of us are older boys playing with toys while the real giants are plowing hundreds or thousands of acres a year.
/ Amazed ! #8
What you see is the difference between suburbanites (hobby farmers) and real farmers (people who farm for a living).
/ Amazed ! #9
The neighbor's new big deere doesn't even sound like a tractor. It sounds like a jet engine...that whistle sound. You hardly ever see smoke out of the stack either.
/ Amazed ! #10
I grew up working on farms. Could it be that you are seeing is the difference between a farmer's crop farming tractors and his chore tractors?
People who farm for a living usually have both types today, but that wasn't the case 50 years ago. Back then, 100 hp and 10,000 lbs was a tillage machine. Everything is bigger now.
Today, 70 to 90HP and 10,000 lbs is plenty big enough for the largest chore tractor with a front loader that can handle about half the machine's weight in the bucket.
And today's tillage machines for field crops are way different. Huge machines. Crazy big.... A suburban farmer wouldn't have a use for one of those. He might not even recognize it as a tractor. It doesn't even look like a chore tractor grown up....it's a whole different animal. But a chore tractor at least has some sort of smaller 3pt and will work a pretty good size garden or orchard.
I hope the future is more a return to small family farms instead of corporates.
rScotty
/ Amazed ! #11
I work in Arkansas and the tractors they run in the flat lands around blytheville are massive. Like the sign in Caruthersville MO says, this is CASE IH country. Tons of RED. Across the river by the house is quite a bit of JD greene. I havnt seen any AGCO tractors. I saw a blue/yellow combine i would guess NH and it stuck out like a sore thumb out in Arkansas.
We see tons of big quad tracks go by the house. They are so insanely HUGE!!!The implements they pull could probably till my 6 acres in 1 pass.
/ Amazed ! #12
What you're seeing is the difference between hobby farmers (us), family farmers (my neighbors) with several hundred acres and corporate operations with many thousands of acres under contract. The first two groups own our land and machines. The third group may not 'own' much of anything other than the land and buildings used for their base of operations.
/ Amazed ! #13
Here it's the huge JD's, Cat or IH Case. Most with either full tracks or those triangular track units on each wheel. Last summer - while motorcycling down south - met a Cat tracked tractor pulling a folded disk setup. Even with both side wings folded up it was still wider that the 24 foot paved county road.
Wheat is king here and the fields go beyond the horizon. Everything regarding wheat is scaled up. It's the economy of size factor. Folded down that disk setup was close to 90 feet wide. H**L - some farmers are plowing in two different time zones - all with a single piece of equipment. And at the same time.
/ Amazed !
Yep, the disc they pull behind those large tractors look like they could disc several acres at a time. I guess they have to be that large, or it would take them a month to disc the fields.
I never knew Arkansas was big in farming till I visited my son there.
My son knows one of the farmers and he farms several thousand acres. I can't imagine having several thousand acres !
Just wonder how they farmed that much land back in the day when a 30-50 hp tractor was considered a large tractor ? lol
/ Amazed ! #16
Once you go big, you can't go back. If a small farmer buys a big tractor, then he starts breaking all the attachments because he has way more power now. So then, he has to spend a bunch more on bigger and better attachments..........
It is a cycle that doesn't reverse it's self.
/ Amazed ! #17
Short answer is they didn't. Farms didn't really get big until things like the steigers and Buds became available, and even then it took time for the larger equipment to spread. Speed is everything when it comes to tillage and planting. You have to hit your ideal window or suffer huge percentage losses off your yield.
/ Amazed ! #19
They didn't farm that much land back in the day here . a huge farm was maybe 500 acres . Back in the early 90's we had 500 acres of peanuts and that was HUGE in those days we did everything with 150hp tractors. WHen older guys died or retired the mega farmers started leasing and to be about to keep up with thousands of acres you had to buy or lease bigger equipment to cover more ground faster. The profit margins were greater in those days also and it did not require as much land to live comfortable. The cost of everything is 3 times what it was but the price for the commodity is the same as it was back then. Its volume only business now
/ Amazed ! #20
JD just announced a 6 series with 250 PTO horsepower and 21,000 lbs of 3 PT lift. Crazy.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
John Deere Cotton Picker Catwalk Floor and Railing (A63116)
John Deere Cotton...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2012 Chevy Impala Sedan (A61569)
2012 Chevy Impala...
John Deere 7000 Planter (A63109)
John Deere 7000...
