Missed it by that much
/ Missed it by that much #1
widefat
Central Va
Kubota L3200 Husq GT52XLS Husqvarna LC121P Husq 455 Rancher Stihl FS90 Stihl MS170 99 Ram 1500
...in a good way.
I have learned ( I thought) to be very careful when doing any time of brush and tree work with my tractor. But, sometimes things still escape my attention.
I was pushing some brush around saturday. I had seemingly policed the area and thought I has a good grasp of my surroundings.
I started to back up, and heard an awful grinding(?) scraping(?) sound that immediately reminded me of stripping gears.
I immediately shutdown and climbed down and checked the left side - no fluids running our or dripping.
I walk to the right side, and see a one inch stick jammed up the side BETWEEN the fuel filter and engine case, all the way up against the radiator fan. The fan edge was making the noise.
The stick was wedged tight, I had to cut it to get it out.
The end result, no damage other than a little bit of grindage to the outer edge of the fan blades.
Talk about lucky - I could have broken the fuel filter off, pierced the radiator, any number of things.
/ Missed it by that much #2
Yep, sometimes the bear gets you and sometimes you get the bear! A little stick in the wrong place can get expensive!
/ Missed it by that much #3
Smart to stop so quickly. I've never been so lucky. I've had the oil sensor on the engine block broken off by a twig that worked it's way into the engine bay and I only knew it happened by seeing the oil shooting out through the seams in the engine cover. Not a huge expense to repair, but very messy and time consuming to get a new sensor and get the broken out threads out of the block.
/ Missed it by that much #4
It pretty cheap to have underside of tractor armored with expanded steel.
To armor my L3560 only four fender washers and two fabricated tabs with holes and two bolts/nuts were required; in addition to the expanded steel.
It is worth shopping for heavy gauge expanded steel.
LINK: STEEL EXPANDED 3/4" #9 FLAT 36" x 48" PERFECT FOR B.B.Q | eBay
/ Missed it by that much #5
I knew it!! The old stick against the radiator fan blade trick!!
/ Missed it by that much #9
I could go someplace with that but I won't. :p
I had a similar experience as the OP on my L275. Not quite the same though, as I smashed the sediment bowl and was paunched for the weekend. The only good part was that my neighbors were cutting wood across the road, and towed me back home. Of course I heard for months about getting towed by a John Deere.
/ Missed it by that much #10
Before I could reach the key I sheared all the blades off my Kubota fan......
...and the shrapnel pierced the radiator.....
/ Missed it by that much #12
I lucked out there. Only repair was new fan.
/ Missed it by that much #13
A few years ago I saw an ad on C.L. for a good looking Woods mower,ad said "needs work". I called and the guy said it had a squeal and he didn't have time to repair it. I quickly looked up the mower parts list and figured it would be an easy fix so I bought it for $150. Got it home and there was a stick about the size of a pencil jammed under a belt and against a pulley. Problem solved and I still use the mower all mowing season with never a problem.Not all encounters with brush are bad for everyone involved.
/ Missed it by that much #14
Jim, that's good! Some folks just give up to early, or maybe just clueless.
/ Missed it by that much #15
Or looking for an excuse to buy a new mower.
/ Missed it by that much #16
When I bought my Grasshopper for $500 they claimed the drive motor was down and it only drove in circles. I figured I might get lucky on the repair and even if it never cut grass again a running Kubota diesel was worth $500 so I bought it. I did get lucky and the linkage between the handles and the pump was messed up. An hours work and no dollars and it was cutting grass again. I don’t think they ever even looked for the source of the problem because they had a new Hustler super Z in the shed. Government efficiency at its finest. Dump a $10,000 or more mower because a 2 cent bolt fell out.
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
429858 (A61165)
429858 (A61165)
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
