Buying my first Kubota - education needed!
/ Buying my first Kubota - education needed! #21
I couldn't find the one by bp fick, but like John, does a good comparison between the BX and B. oldballs also has a good chronicle of how he wound up with what he has. My story/advice so closely follows their I won't bother.
https://www.tractorbynet.com/forums...30-b3200-bx2660-side-side-not.html?highlight=
https://www.tractorbynet.com/forums...ing/147841-bx-just-isnt-b-you.html?highlight=
https://www.tractorbynet.com/forums...224-buying-first-test-tractor.html?highlight=
So, seems like everyone here is a nogo on a small grapple for a bx? I know it couldn't pick up huge logs, but i have acres of smaller logs and branches that i have let lay over the years. That's why I'm looking to get one. And even a larger tree can still be cut up into smaller pieces. EA makes an excellent grapple built just for that size tractor.
Am i crazy to be thinking about doing this?
Tim, from tractor time w/tim has a grapple and i think he uses a JD 1025. He does quite a lot with his grapple.
/ Buying my first Kubota - education needed! #22
I've checked out the B2650, it was actually the first quote I got. I just don't think I can make it work size wise with some of the things I'm wanting to do at this time.
Right now I think I'm going with this:
3 pt pallet forks
FEL
Rear blade
54" MMM
And maybe switching from the R4 tires, but I have to research that one more.
How much lift can you get using 3 PT pallet forks? Worthwhile?
You not going to like moving snow with a FEL bucket.
You're going to want to have at least 2, maybe 3, rear hydraulic SCV valves if you have a rear blade, unless you don't mind getting off tractor a lot to angle, tilt or offset it.
I don't have a grapple and have been making do with forks. Lately I've been considering a bucket grapple thumb (to mount on the forks). I think this is lightweight, and cheaper, and useful when you just want to lightly hold brush or whatever from rolling off. A good poor man's solution. It does require a third function, or running hoses from the back SCV.
/ Buying my first Kubota - education needed! #23
So, seems like everyone here is a nogo on a small grapple for a BX?
I know it couldn't pick up huge logs, but I have acres of smaller logs and branches that i have let lay over the years. That's A larger tree can still be cut up into smaller pieces. EA makes an excellent grapple built just for that size tractor.
Am i crazy to be thinking about this?
Corral/pile your acres of debris with a Ratchet Rake.
Lift and transport piles of debris to the lift capacity of your FEL on ULTRAFORKS.
You will have considerably more lift capacity with Ultraforks, relative to a very small grapple.
LINK: Multi-Spear Ultra Fork
VIDEO: New Multi Spear Utility Forks by BucketSolutions.com - YouTube
Keep it simple.
/ Buying my first Kubota - education needed! #24
I don't have experience with grapples. But my research would suggest to me that a grapple on a BX is much much better than a rake and picking things up by hand.
If the question is whether a grapple on a bigger tractor could lift more - of course it could. If you're getting a BX and the question is whether a grapple is better than no grapple, I'd have thought the answer is obviously that a grapple is better.
A B2601 doesn't lift much more than a BX, and GP Outdoors lifts a heck of a lot with his. #99 Kubota B261 Compact Tractor and HLA Grapple : It's Grappl'in Time! - YouTube. If a BX lifts half of that it'd still be very very useful.
/ Buying my first Kubota - education needed! #25
These are good on going posts with lots of good contributions of thoughts/questions by lots of experienced and inexperienced owners/buyers. BP Fick also did a great personal experience write up on the B vs BX question if it can be found. I actually have done the B to BX to B to BX trades several times due to property and needs changes and with a great trading/selling dealer like Barlows the financial hit hasn't always been that bad. My venture from tractors to skid steer back to tractors was a financial disaster though.
/ Buying my first Kubota - education needed! #26
If you want the grapple just get it.
Here are the facts:
-You want the grapple
-It seems you can afford it
-A grapple is a nice tool, with good real world applications
-Is a nice toy and an stress reliever
-Just get it
Here is my recommendation
Root Rake Grapple For Kubota BX
Very capable and only 150lb...can't beat that.
/ Buying my first Kubota - education needed! #27
Does it come with a QA bucket?
If not I would work that into the new purchase deal. Has to be cheaper than to do it later which is what I did. I bought my tractor used so didn't have that choice at purchase but it was sooo worth it. If you want forks or a snow blade (someone else I think already pointed out how tedious snow removal becomes with a bucket) it is like a 2 minute changeout. Also grapple bucket changeout is the same.
Just my 2 cents. You know your application best. Enjoy your new purchase.
P.S. I have a B2150 that I have owned since new that is a little monster. If my bigger tractors were as tough as the 2150 has been they would be incredible.
/ Buying my first Kubota - education needed! #28
SSQA will reduce the lifting capacity, on this particular case I think he should keep the pin-on system.
Or move to a different, more capable equipment
/ Buying my first Kubota - education needed! #29
I've never owned a grapple and am not sold on its utility at my place. I'd say that using some model of a pin on fork is the best option. I say this because I really doubt that a grapple will pick up all the debris that I accumulate dropping dead pine trees. I really don't mind lifting my butt out of the seat to load the FEL/pin on forks. Even a dedicated Pallet Fork might even be better....viz..no third function hydraulics.
/ Buying my first Kubota - education needed! #30
See these pics of a Kubota "B" model and a "BX" model.View attachment 591593View attachment 591594
View attachment 591595View attachment 591597View attachment 591598
how do you attach the pallet forks on the tractor in the middle picture?
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
1992 22ft Bayliner BYQ Boat w/ ASPT T/A Boat Trailer (A59231)
1992 22ft Bayliner...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
2019 Chevrolet Silverado 1500 RST 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
2024 Chevrolet Tahoe SUV (A59231)
2024 Chevrolet...
