Branson 7845c Block heater Question?
/ Branson 7845c Block heater Question? #1
haboo1968
Jd 790 & Branson 7845c
Has anyone installed a block heater in a Branson 7845C . It has the D3400T10-UTC-3 turbo diesel engine. From the info I gathered the Branson part # BH-K was listed for $138.00. A guy I talked to was nice enough to measure one for me ... it was 1" 400w and look like npt threads.. so a quick search, I found Kat's 11407 400 Watt 1" NPT Engine Heater for $32.00. Now to my Question: Does anyone know where the plug is located on the engine?
/ Branson 7845c Block heater Question? #2
I have an 8050 which is the same engine,
if you look at your oil filter, you may have the same oil cooler/heater that I have;
just ahead of the oil filter is a pipe plug with a recessed square head, that's the one to pull out for the heater.
When I installed mine the fitting for the oil cooler was in the way, I pulled it out and added a nipple and a coupler
to it so the heater hex would clear.
Watch out for the length of the heater element it gets close to the cylinders.
Also with mine the manifold heater controller is looking at water temp for the time to run it,
with the water warm the manifold heater doesn't run and on a sub zero day I have had it fire and die from the cold air
with no heat.
Lou
Thanks .... I'll go out and take look to see if i can find that plug. Is it located within this pic? Should I say is yours located within this area. This is on the right side just in front of the cab. Thats the oil filter in photo.
I'm getting conflicting versions ... one dealer says : Sorry to inform you but the 7845 do not use the BH-1 that screws into block, they use an inline heater that goes in the bottom radiator hose. While another says that they do have that type.
If at all possible i rather have a block heater vs an inline.
/ Branson 7845c Block heater Question? #5
I will get some photos of mine in the morning,
when I purchased my tractor the dealer told me that it took a lower radiator hose heater
and that was what he installed that did not work well and I got some more info from another poster on
here and installed mine in the block.
As I recall it was hard to see the plug until I looked real close.
Lou
Thanks... Lou, that would be much appreciated.
/ Branson 7845c Block heater Question? #7
Morning haboo1968;
I got some pics this morning,
hope they help;
this first pic is about like yours, looking closely you can see the orange cord from the block heater
a close up of the area of interest, the plug is directly below the oil cooler tap behind the other hose
and here I'm pulling down on the other hose
Hope these help you.
Good Luck
Lou
A picture is worth a thousand words, thanks again for taking the time to take the pics. Unfortunately that port is being used on mine. I marked the hose in this pic. It goes into the front right hand corner of the cab, up into the cab. If i had to guess, I would say it goes to the cab heater. Looks like I might have to go with the inline. Heck it might be easier just to build a heated shed...lol
/ Branson 7845c Block heater Question? #9
/ Branson 7845c Block heater Question? #10
The 7845 & 8050 are not the same engine. Different designs.
unfortunately there is not a port on the 7845 engine to fit a screw in block heater. I know we've installed the lower radiator hose heater and we've installed an extra one on the heater hoses going up to the cab (tank heater) seems to make a big difference but now you have two electrical plugs. Fortunately the 7845 start really well providing you have good battery power.
/ Branson 7845c Block heater Question? #11
Mr Bitz;
Would you expand upon that?
When I look at the parts breakdowns, the blocks, starters, cylinder heads are the same?
When I look at the 7845C plumbing, the pipe threaded port used for the cab heater is the same port
I used for a block heater.
I know a few years ago when I looked at an open station 7845 it had the unused pipe plug in the same location?
To my knowledge they both use the D3400T block, the same bore and stroke?
I have heard that the K78 series uses a 2.7KW starter can you confirm that?
As far as a 7845 being a good starter in the winter I have no clue,
I do know that my 8050 would not start in sub zero untill I replaced the trans/hydraulic fluid,
it would make about 2 engine revolutions and refuse to turn anymore till it had set for 10 minutes,
and then repeat untill it warmed up or a heater warmed up the tractor.
It had the lower radiator hose heater in it at that time that my dealer had installed.
Lou
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
