Wire size for a pump?
/ Wire size for a pump? #21
The 6/3 direct bury is scrap that.i had on my shelf. I have no idea where it came from, it's just there. If it.was longer, I was going.to use it because it's already paid for. Now I will buy 50 feet of 6/3 and run it.over my rafters and through the top plates of my wall, and then into a junction box that will remain sealed up until I decide what I will do regarding the pump.
To get from my panel to the outside of the wall means making two very quick 90s that make conduit impossible to pull wire through. I wouldn't try it with 12/2!!
If I decide to put a pump next to my house, I can use the 6/3 direct bury wire to go from the junction box to the pump.
My debate on pump location is between running wire 1000 feet down to my pond or not.
I am sure there are people on this site that can give better advice than me because I am definitely not a plumber, but what you are thinking about a pump next to the house because of the price of the wire doesn't add up to me. Texas freezes in the winter sometimes doesn't it? If so you are either going to have to build an insulated box and keep it warm all winter, or pull the footvalve out of the pond and let the line drain every fall because you won't want the water to freeze in a pump or a tank. Then every spring you are priming 1000 feet of pipe, or maybe 2000 feet if you need a two pipe deep well design. With the pump in the pond pushing the water you need only one pipe and you don't need to prime it.
/ Wire size for a pump? #22
Conduit really isn't an option based on what I have to work with. I think that I will buy 50 feet of 6/3 and run it from my breaker box to a junction box on the outside of my house. If I decide to put a pump next to my house, I'm good. If I decide to run wire all the way down to the pond, I'm good. If I decide to set a meter by the pond, I've wasted some money, but not a lot.
Based on a topo map, I'm probably 30 feet higher at the house then the full water height of the pond. To be on the safe side, figure 50 feet of lift, and a thousand feet of run.
My original plan was to drill a well next to the house, but that doesn't have a lot of appeal to me. I might rethink that idea before committing to anything.
Thanks!!!
How deep to water, if you were to drill a new well at the house?
30 to 40 feet will probably hit water. Hundred feet would have unlimited supply.
/ Wire size for a pump? #24
Look into washing down a well.
I have washed down about a dozen shallow wells down to 42' using 2" PVC then dropping 1 1/4" PVC in with well point. Then remove 2".
I used a garden hose for wash water. You cut teeth in the 2".
/ Wire size for a pump? #25
My artesian is 670 ft deep, 150’ from house.
5 hp single phase pump on 40 amp breaker, 8/3 wire
/ Wire size for a pump? #26
Eddie, I'd drill or have drilled a shallow well <100', put in a 1/2 hp jet pump, and use a caged poly tote to store near the barn or garden. Put the pump on a timer so as not to overdraw on a long cycle, and wire a float switch between pressure switch and electric line.
Another small pump can redistribute from storage. (solar?) We catch roof runoff in these, and gravity flow is indeed slow on totes installed several feet above the garden. That we have more rain up here shouldn't mean you can't combine concepts suggested by the group.
The TDH capacity required to pump 1000' horizontally and 30' feet up must need >1hp to get more than a trickle, and a hefty supply line to handle starting surge. (big resistive loss at big distance) I suspect your electric bill might go up noticeably like your water bill has when watering heavily. A lot of energy needed to overcome line friction, and a big investment to write off if performance disappoints.
Consider the TDH of the pump you'd use, check ampacity/gauge of the wire needed for that length of run, and ask around what is the best diameter pipe to run the 1000'. Too small could be a prob, too large could just cost too much. The 'pump at the pond' plan may give way to a simpler setup with le$$ commitment going in. Sure glad you have time before planting, and I hope what you go with works out ... the first time. t o g
/ Wire size for a pump? #27
For quick bends, use one of these. They come in several different configurations and are available at HD & Lowes: conduit-fittings-90 deg.jpg
The wire is run and terminated in an exterior metal junction box. I will paint it to match the siding and forget about it until I decide what I want to do. It might very well remain like this forever. But at least I have an option with it in place.
Thank you for all the help and suggestions.
/ Wire size for a pump? #30
A pump cannot 'suck' water more than 33' above the water surface even if everything is perfect. A pump can be made to push water as high as you need it. When a pump pulls water/air from the suction line, air pressure pushes more water in to replace it. Air pressure at sea level is about 14.7 PSI so, if the pump pulls a perfect vacuum, the air pressure can push the water (.44 lbs per inch of lift) up about 33 feet. The pump will not pull a perfect vacuum, and there is friction and other restriction in the lines, so actual results will be less.
So, your pump will need to be closer to the pond so that it can push the water to you. It cannot pull the water to the house.
Thank you. I've run the wire to outside the house, so if I decide to dig a well, I'll be good to go. If I decide to get the water from my pond, I'll run power down to the pond and put a pump in the water. I want to build a pier anyway, so that would be a perfect place for a pump. Just don't have any idea when any of this will happen.
/ Wire size for a pump? #32
I have installed my fair share of pumps for cottage owners.
I always have used deep well pumps that I mounted on a welded up pedestal so that the pumps would stand proud of the silty lake bottoms.
Some advantages are: pump is always primed, never needs removing due to winter freeze up.
Most installations are into the 10-15 year spans without any problems.
In some installations I used heat tracing wire due to soil conditions and others are simply buried below frost line.
Those that are merely for summer usage I'd install a 'T' below water level and a ball valve on the 'T' so simplify seasonal draining.
Drainage was simple, shut off pump, open all faucets and then open the submerged ball valve.
Presto, system drained for the winter.
Reverse process for spring hook up.
No pump/system priming for me.
Should add, all told the $'s difference between submerged well pumps and piston or jet pumps is not all that impressive to not use a deep well pump.
/ Wire size for a pump? #33
I agree submersibles are always better than jet pumps. Over sizing the wire is not really a good thing with a sub. Actually using the longest length of the smallest wire possible makes a reduced voltage soft stater and reduces torque by up to 36%. Over sizing the wire makes it a harder start, but with small pumps won't hurt much.
How a Pressure Tank Works and why you need a Cycle Stop Valve on Vimeo
/ Wire size for a pump? #34
My artesian is 670 ft deep, 150 from house.
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
New Holland TS115A (A64126)
New Holland TS115A...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
Dragline Bucket (A65640)
Dragline Bucket...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
