Stackable hydraulic valves
/ Stackable hydraulic valves #1
unimog_jason
New Brunswick, Canada
JD 755, Kioti DK40SE, JD 410
My Kioti Dk40 has a single rear hydraulic port with the option to add a second.
I was thinking about adding another valve to my tractor and was curious of the lay out.
I looked at the parts catalog and I'm wondering if there are third party valve bodies available.
I assume Kioti is buying off the shelf hydraulic components where possible, but I haven't been able to find any valves that are similar.
Has anyone seen a valve unit that is similar to the one pictured in the attachment? Ideally, I would like to find some electric valves that I could stack up in place of the mechanical valve.
/ Stackable hydraulic valves #2
Don't know the answer to 3rd party vendors to that valve, but you could also replace it with one that is readily available with whatever type valves and number you want. Check out Surplus Center's hydraulics.
/ Stackable hydraulic valves #3
Unimog
Does Kioti offer the option of purchasing more valve sections? This would confirm fit.
There are lots of valve manufacturers in Europe some of which are Doosan, Walvoil, Hydac, Etc. I have no clue if any of these supply valves to Kioti
/ Stackable hydraulic valves #4
I've tried the same thing for my Branson tractor. It would probably be cheaper than getting one from the dealer, even I had to make the linkage which is no big deal.
I couldn't come up with a manufacturer for the valve. It's pretty similar to the one you show on your tractor.
The block in the middle of the tractor that provides Pressure, PB, Return and a main Relief valve for the loader is made by Walvoil, if I'm remembering right though.
However, I think this is custom order from the tractor manufacturers for their tractors as they make this stackable valves with only 2 tie rods. The ones you see from a 3rd party vendors are either 3 or 4 tie rods..
/ Stackable hydraulic valves #5
On the CK series Kioti used a proprietary valve body assembly and I'm betting they did the same for the DK series although yours in the drawing still looks different from mine.
The newer XX10 Series CK & DK valves look to be a little more "off the shelf"
If you want more than the 2 factory valves you're going to have to tap into the power beyond line between the loader valve & the rear of the tractor and use that to feed an new valve block.
I have looked into both manual & electric diverters to plumb downstream of my existing 2 valves to effectively split them into 4 separate functions but the cost (and room to do so) is prohibitive for my limited needs.
Hopefully a DK owner will stumble through shortly and have a better answer to your question.
Thanks for all of your input.
Yes, I can buy additional valve bodies from Kioti, it looks like you can stack up as many as you want, there is probably space under the cab for 4 at least, it's just setting up the linkages. There is only room for two linkages from the factory and it's a bit of a complex setup and not easy to modify, hence my desire to determine who made them and see if there are electric valves instead.
I guess if push comes to shove, I'll break the like between the loader valve and the rear valve and insert some additional valves that way.
Jason
/ Stackable hydraulic valves #7
Curious, any particular reason not to simply use diverters? :confused3:
The diverter valves look to be single function, in my application I would be looking for double function so that I can reverse the flow since I would be tapping the flow directly from the pump.
If I were to use the rear valve on the tractor with the diverter valves, it would work but it's a detent valve to start with and the fluid path is return to tank so I loose my 3pt controls while using the diverters, making it a little bit awkward.
In the end, the best solution for what I'm looking for would be it get a stack of electric valves and tap the main flow I think.
Jason
/ Stackable hydraulic valves #9
Jason
The diverters would be used in conjunction with your existing rear remote. You cannot plumb directly from the fluid supply source, they are diverters, not control valves. Again, just a question, so you use your 3pt and a rear remote at the same exact time? I have 3 diverters on my tractor that only had-has a single rear remote available. Zero issues.
I guess I just don't understand what your uses are going to be.:confused: Keep in mind that most electric valves are either open or closed, nothing in between.
/ Stackable hydraulic valves #10
Oh, there are most certainly electric valves that are “proportional” meaning you can feather them and shift them only as much as you want, but then the electronics became much more involved than just a switch at that point.
/ Stackable hydraulic valves #11
While this is absolutely true, I know of none that are used with the typical utility tractor that is talked about on these forums. I believe that cost might be a factor??
/ Stackable hydraulic valves #12
Yes you said it better than I did. What I was stumbling around saying. The electronics to operate them cost more than the valves.
/ Stackable hydraulic valves #13
What is the cost associated with the valves from the dealer? I would have to think that it’s cheaper to buy ONE correct valve then it is to buy two or three wrong valves. The factory valve would guarantee fitment.
/ Stackable hydraulic valves #14
If you want the stock lever location it's usually easiest to buy the factory kit. That'll have the levers, the valves, and the linkage between them. For example on my Branson the levers fit in a tight space between the seat and fender, the valves bolt on to the transmission housing and the output T port goes directly into the transmission (to the 3pt), and the linkage is complex. It'd be really hard to duplicate.
OTOH I also have another valve which was added by the dealer. It's bolted to the fender (with a nice mount/guard) and connected in line between the loader valve's power beyond and the factory valves. It would not be too hard to fabricate something similar at home. There's a number of threads here from people who have done the same.
The lever position is not factory so it does not have the factory ergonomics. In my case the factory levers are a little short and the dealer added valve's lever is handy on the fender, so it's kind of a wash between the two. But with levers directly mounted to valve bodies you're going to be more limited in placement than a cable or linkage system.
/ Stackable hydraulic valves #15
Reviving a bit of an old thread, but wanted to build off this.
I've got a CK3510SE cab with the 3rd function up front and the 2 rear-remotes from Kioti. I've installed a hydraulic toplink using one set of the remotes, and still have the other port open, which I believe is for the constant flow like a backhoe.
I would like to get a flail mower with hydraulic offset and tilt like the Del Marino Centurian. And I've been looking at the Summit electronic valve system to multiple the ports.
My question is, would I have to use the remaining rear port or is there a way to directly connect it to the valve body? Are there other open ports on the valve body that I could tap into rather than use the rear remote port.
Thanks for your help!
2022 EZ-GO ELITE...
PALLET OF FILTERS & MISC (A64278)
PALLET OF FILTERS...
2025 Electric Cart (A64557)
2025 Electric Cart...
Wooden Glider Chair (A64557)
Wooden Glider...
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
UNUSED FUTURE MINI EXCAVATOR 31" ROCK BUCKET (A65055)
UNUSED FUTURE MINI...
