falling on ice
/ falling on ice #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
How's everyone handling the ice problems. My wife just took another fall. Patches of Ice walking out the door to our vehicles are bad.
/ falling on ice #3
Around 2 weeks ago I experienced a part failure on one of the crampons that I was wearing while walking on ice which caused a fall resulting in a trip to the ER the next morning, a fractured/displaced patella, 6 weeks in a knee immobilizer, and months of anticipated PT. By the time I am waling outside again it will be Spring or at least Mud Season.
/ falling on ice #5
I recall that you had a failure on yours, I am thinking that yours were the aggressive ones with the steel cleats?
The ones I ordered only have some small studs, I'm hoping that they work adequately and allow me to have them on in the tractor cab,
while still providing some grip improvement.
Lou
/ falling on ice #6
/ falling on ice #7
/ falling on ice #8
dalola- Those cleats are of a similar design and hopefully heavier duty than the ones I purchased. Yours also have that crosspiece in the front. I'd keep my eye on that wire.
Thanks for the link.
/ falling on ice #9
I was surprised that most of the ads for the various traction adders were shown on athletic type shoes not work boots.
I'm hoping that the ones I ordered fit boots, I have heck finding stuff to fit my hands and feet (14eeee or 15eee) it can be quite aggravating at times.
Good luck with your recovery from your fall, I worry about my replacement knee walking on rough ground and soft ground and all the climbing and twisting getting in and out of the tractors. But so far so good, the worst is actually having to get up off a creeper or if I have to crawl under something, getting back up as it is quite uncomfortable to kneel on it.
Lou
/ falling on ice #10
Absolutely! Inspections are done before & after hikes. Some of the places we hike, a failure could be life threatening.
After countless miles & years, they are still unchanged. I literally trust my life to these things!
/ falling on ice #11
dalola- I was walking my dog in the dark by headlight. We've done this walk on ice many times before. Had that part failed farther along my intended walk and considering the injury and temperature at the time of the part failure I might not be posting now. Those crampons were less than a week old. I did not inspect them well enough.
Again thanks for the link and the pictures. I like the design and the pictures too.
BTW EnergeticSky is a Chinese company despite their website's vague Oregon address.
/ falling on ice #12
Best of luck with your recovery. Stay safe out there!
/ falling on ice #13
I was going to check the seed level in bird feeder when I hit a patch of black ice and down I went on blacktop drive. I got up and hobbled back into detached garage about the time world started spinning. Guess I hit my head pretty good also. After that passed I hobbled 30yd to house and was hurting like H#**.
Got to Dr. next day and found out I had fractured my pelvis...oh joy.
I'm 3 weeks into a 6 week no weight bearing on right side.
House bound with crutches now...
Ice skating rink up here in N Wisc with temp dropping to -30 with wind chill in -50 to -80 tomorrow.
Global warming strikes again!!
/ falling on ice #14
Thanks for the + thoughts.
TB and Lou- Take care out there.
RN- I checked your referenced link. I like the design. When my YakTrax ice creepers start showing signs of wear. I will probably order those slipovers. :cool: Thanks
/ falling on ice #15
Based on recommendations in another thread I bought Yaktrax for both myself and my wife. I've size 13's and they barely fit my boots, but they fit. My prime concern for my self is ice for those occasions when everything, even the grass, glazes over. For my wife I just wanted something to stop her from going out on the ice.
These are basically heavy duty rubber bands with wire spring wrapped around, I don't expect them to hold up for any distance. They remind me of extremely cheap "tire chains". The one time I used them this year they worked fine.
/ falling on ice #16
The coil springs on the Yaktrax can get real slippery on smooth surfaces. Yaktrax does mention this on their website. Yaktrax also makes a non-coil "Diamond head" design that I have never seen nor used.
/ falling on ice #17
Lots of ice here :( so if it shine it get heavy dose grit upon it.
/ falling on ice #18
My in-laws are elderly, and not so stable on their feet anymore. We pick up bags of Prestone driveway heet on clearance towards the end of each winter. It keeps well in their shed. Melts ice very fast. We clear their driveway, then put this stuff down lightly (doesn't take much) just a path-wide strip down the drive from the garage to the mailbox, and on their sidewalk to the bird feeders. Really works well.
/ falling on ice #19
I use Stabilicers Maxx, and recently bought a set of Max2. They are pretty good on ice, with the Max2 being a little easier to put on as you get older. Have replaceable studs that you can change. A lot of brown truck and USPS folks wear them up here in the boonies. I put mine on this year after I had fallen for the third time. Finally dawned on me...... :)
/ falling on ice #20
If you dont have the dexterity and time to shovel/chip it out, then just use CaCl or salt on those areas.
You can also do micro spikes, but they do take time to put on and take off once to the car.
2023 Scag Cheetah 61in. Zero Turn Commercial Mower (A61567)
2023 Scag Cheetah...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
30 Yard Dumper (A61166)
30 Yard Dumper...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
