ideas for setting up a chain hoist from harbour freight
/ ideas for setting up a chain hoist from harbour freight #1
mechanic
missouri
Looking for ideas for setting up chain hoist for lifting heavy objects in my shop. Does it need a gantry or is there a different method to use this. Pictures would help
/ ideas for setting up a chain hoist from harbour freight #3
I just hang a chain over a couple of ceiling joists. But I never lift anywhere near capacity, maybe 500-750 pounds maximum.
/ ideas for setting up a chain hoist from harbour freight #4
I originally had the 800 lb electric cable hoist from HF. I had it installed on the back side of my twin post garage lift supported by thickwall schedule 80 pipe. The pipe was attached to the lift with HD U-bolts and the cable hoist could slide on the pipe from one side to the other. I now have a 2000 lb. (using snatch block to double the cable) electric cable hoist in place of the HF unit. The support pipe has been doubled. Now is two schedule 80 pipes, one inside the other, that are welded together that the hoist slides on.
A gantry would be nice to make the chain hoist portable. HF sells one of those but not sure of the weight rating. Hanging a pipe from shop rafters could also support your chain hoist.
/ ideas for setting up a chain hoist from harbour freight #5
I use this all the time for the mowers, lift up to sharpen blades or load/unload something heavy off the truck. I used treated 2x12 scrap.
/ ideas for setting up a chain hoist from harbour freight #6
After using hoist in dedicated location (on ceiling joist) and a gantry crane that does not quite reach where it needs to be, I think I would use a portable "A" frame if shop space permits (ceiling height).... Beauty is if can be anywhere even outside if you have concrete apron in front of shop and it can be pushes against back wall and span workbench or park vehicles under it it's all usable space under it while its in "storage"...
For example...
It can be "sized" dependent on your needs....
Dale
/ ideas for setting up a chain hoist from harbour freight #8
Depends on how your shop is built and what your needs are.
I have pulled a 351 with a c6 bolted to it with the 1 ton HF chain hoist chained to a rafter of a single car metal carport. In my garage I built an angle iron support to spread the weight out between two rafters.
/ ideas for setting up a chain hoist from harbour freight #9
Not sure why everbody's jumping on the gantry thing that's like $600 and still needs the optional trolley to be useful. OP, fill us in a bit more on what you want to do and what resources or budget you have to work with.
/ ideas for setting up a chain hoist from harbour freight #10
Well for one, when I hoist something I want it to stay where its supposed to be... Don't want it to come down unexpectedly .... Rafters and such is all guess work if OP does not know structural integrity of building.... Safety you know....
Dale
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Yanmar YT359 (A53317)
2005 Big Tex 14TL (A60462)
2005 Big Tex 14TL...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
