Wire size for a pump?
/ Wire size for a pump? #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
One day, probably years from now, I hope to have a pump that I can get water from my pond to water my gardens. I don't know how big this pump will be, or if I will put it next to my house and run a thousand feet of pipe to the pond, or run the wire to the pond and put the pump in the pond. It might not even happen, but I'm at a stage in my house remodel that I want to run the wire from my breaker box to the side of my house. It will be super easy to do it now, and not so much if I have to do it years from now.
There is also a good chance that I will have the power company put in a couple more poles and set a meter close to the pond, and have power down there that will make all of this meaningless.
Since I don't have the pump, and I'm driving myself crazy looking at pumps online to see what their power needs are, I'm curious what some of you would run for wire?
I was leaning towards 8/3. I only need about 40 feet, so I'm hoping that I can buy a 50 foot roll. I found some direct bury 6/3 on my shelf of scrap wire, but it's too short, but might work great in the future to go from the junction box that I will put on my outside wall, to the pump if I put it next to my house.
Which just reminded me that I need to put a 110 outlet out there too so I can have power to turn the sprinklers on and off!!!! I didn't even think of that until just now.
/ Wire size for a pump? #2
Get a longer piece of 6/3.
Bigger is better in everything except P***ey
/ Wire size for a pump? #3
The distance from the house to the pond is the important factor because of the voltage drop. The higher the length, amps, the smaller the sq mm, the higher the voltage drop. The cable length in the house is probably short compared to the length outside, and would have not much voltage drop, you can compensate for voltage drop by choosing a heavier cable outside.
It doesn't mater of voltage drop occurs in-house or outside, it is the total voltage drop that matters.
In house, choose a 3 wire+ground so you have a neutral, ( maybe not needed but more possibilities, timer?). Choose the inside cable to the breaker Amps, you may need a special breaker for motors. Choose the outside cable so you stay within the permissible voltage loss for the pump. The pump should be 220 Volt for sure.
Without knowing the pump amps, voltage, cable lengths and their environment (in insulation or in conduit or in bare ground) it is impossible to calculate the square diameter of the wire, which than can be converted to the weird "gauge" size that is used on this continent, to make things more complicated than necessary.
In short: choose the in-house cable to mach the amps of the biggest pump your considering and the rest comes later.
I am a retired electrical contractor from Europe and I am not familiar with your local code. But voltage drop calculations are not different, except for the complication of that weird "gauge" thing. In Europe the square mm is printed on the cable. Plain and simple. No need to convert from "gauge".
/ Wire size for a pump? #4
Here is a link to a handy wire size calculator. All you need to know is current and distance to find the required wire size.
/ Wire size for a pump? #5
I think what Eddy is saying that he needs to run 40 feet from the main panel to the panel for the pump. From that panel 1000 feet to the pond, where the pump is.
I would not choose a 1000 feet long cable on an internet calculation that asks only 4 questions.
/ Wire size for a pump? #6
While you're installing things for the future, maybe low voltage wire for remote control of valves or motor control as well..................mike
/ Wire size for a pump? #7
Given what you know at this point, I think I would run a 1" or maybe a 1-1/2" conduit from your main panel out to a weather proof enclosure on an outside wall. Then when you decide on which pump you want to buy and where you want to put it you will only have to run the appropriate sized wire. You can put up to 3 #2thhn wires in a 1" conduit.
If you used a 1 hp pump 1040' away from your main (at (240v) , it would take #6 wire to stay under 3% voltage drop. If you want a bigger pump, you can run up to 3 -#2awg wires in a 1" conduit.
/ Wire size for a pump? #8
Eddie, what is the elevation change from the pond to the gardens? If the elevation change is only a few feet, you won't need a huge pump. My 1/2 hp well pump is rated for a well 200 feet deep. I am guessing you are not pumping the water uphill anywhere neat that, but I could be wrong. You could be pumping downhill for all we know!
I would definitely put the pump in the pond. The water will always flow if you do that. In our town, we have no fire hydrants so in the fire department we practice filling up 3000 gallon tanker trucks from local ponds and rivers, and it takes much more horsepower to suck water up an empty pipe that it does to push water up that same pipe. We are using 6" PVC dry hydrants that are sometimes 10-15 feet above the water level. We will back fill the empty pipe with water from the pumper engine and then reverse the flow to begin filling tankers. We can fill a 3000 gallon tanker in 2.5 minutes. We can pump water faster, but pushing it into the tanker at anything more that that can blow out the tank.
/ Wire size for a pump? #9
I have never seen a pump with a thousand foot lift. Lift being the distance between the pump and the water source.
/ Wire size for a pump? #10
Pumps push, they don稚 pull worth a darn. About 15-20ft lift is about it with much reduced efficiency. Pump will hardly notice pushing 15-20ft of lift .
/ Wire size for a pump? #11
Another way to look at this.
You can get a HF gas pump for under $200. and put it at the pond.
For a timer only put in enough gas to run for how long you want to water.
I have one of the pumps and it does a great job and pumps as much water at 1/3 throttle as it does full!
/ Wire size for a pump? #12
/ Wire size for a pump? #13
The consideration is about cost. You can buy a 4 wire 100 amp alum direct burial service wire for $1.20 a foot. Service pole with meter will cost at least $26.00 just to sit there. Spend it now or later.
/ Wire size for a pump? #14
Like TMC; why speculate now; just install an over size conduit to the building exterior now, then solve the rest when you start the pump project. Invariably you will pick the wrong size wire now, either too small, or you have wasted money on wire bigger than necessary. Always put the pump as close to the fluid as possible. Friction on water flow is more expensive than resistance on wire.
Ron
Conduit really isn't an option based on what I have to work with. I think that I will buy 50 feet of 6/3 and run it from my breaker box to a junction box on the outside of my house. If I decide to put a pump next to my house, I'm good. If I decide to run wire all the way down to the pond, I'm good. If I decide to set a meter by the pond, I've wasted some money, but not a lot.
Based on a topo map, I'm probably 30 feet higher at the house then the full water height of the pond. To be on the safe side, figure 50 feet of lift, and a thousand feet of run.
My original plan was to drill a well next to the house, but that doesn't have a lot of appeal to me. I might rethink that idea before committing to anything.
Thanks!!!
/ Wire size for a pump? #16
Are you planning to have a pressure tank in the house or an insulated out-building, so you are not just running directly from the pump? This will give you better and more even pressure. Running the water directly from the pump 1000 ft to the house, and then directly out through the hoses and irrigation lines is going to mean you may be dealing with a trickle by the time it comes out of the end. With a tank you have 50 PSI starting from the tank, so you have lots of pressure coming out of the hose end. Have you considered the location of your pressure tank? I have about 300 horizontal yds plus the vertical height from my well's submersible pump to the pressure tank in my house and it manages fine.
To have a pressure tank in the house, you will need in/out hoses for the water plus wire to allow the tank pressure switch to turn on/off the pump down at the pond. This is in addition to the wire you are running to power the pump. If you use an outbuilding, then the wire from the house will be enough but the run from the outbuilding to the pump will need the water pipe plus three wire so you can power the pump and still have a wire left to allow the tank to switch the pump on and off.
I am not sure how much water your well has and how it holds up in the summer, but putting the pressure tank in the horse barn might allow you to keep the horse troughs filled in the summer and have an outflow for the wash stalls, so you have an option to keep the horse water consumption off of your well during the dry season.
Good questions. I have city water at the house, which adds about $60 to my bill when my wife starts watering her gardens in the spring. Currently, we are using about a third of the yard for gardens that she has set aside, which means my water bill could easily triple in the future. All I'm trying to do now is plan ahead to the best of my abilities, without actually committing to anything.
Another option was to buy a 2,500 gallon water tank and set it next to the house, and then run a solar pump all day to try and fill it up. Then open the valve at night and let it drain out into the gardens. After researching this for a little bit, I have my doubts that this is a good solution.
/ Wire size for a pump? #18
I'm confused about why you could install direct bury wire but not install conduit.
Since it is a fairly short run, with unknown future things to connect to, I'd run the highest amperage wire you can justify paying for. As with tractors, then maybe go up one size!! :D
/ Wire size for a pump? #19
If you are looking for a gravity feed for the garden, rather than turn it off manually you can use a hose timer. I put one of those 1000L used veggie oil totes (the square plastic ones with the wire cage around them) on a stand under the downspout from my rain gutters and hooked a battery powered timer to it, which opens the valve twice a day for a half hour. Two AAA batteries will run it for about 3 months. That worked well for my cottage gardens where i was often away for two weeks at a time. You need some height though. As I understand it you will get 18 psi per vertical foot the tank is off the ground. I didn't get enough pressure to run a buried soaker hose because the dirt squashed it flat, but when I buried 1/4 inch pvc with holes drilled every foot it worked pretty well in the spring when the rain was regular. The tank wasn't big enough for summer once the rain was less frequent.
The 6/3 direct bury is scrap that.i had on my shelf. I have no idea where it came from, it's just there. If it.was longer, I was going.to use it because it's already paid for. Now I will buy 50 feet of 6/3 and run it.over my rafters and through the top plates of my wall, and then into a junction box that will remain sealed up until I decide what I will do regarding the pump.
To get from my panel to the outside of the wall means making two very quick 90s that make conduit impossible to pull wire through. I wouldn't try it with 12/2!!
If I decide to put a pump next to my house, I can use the 6/3 direct bury wire to go from the junction box to the pump.
My debate on pump location is between running wire 1000 feet down to my pond or not.
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
Steel Blasting Shed (A62679)
Steel Blasting...
