Got my Kens Bolt on Hooks installed today
/ Got my Kens Bolt on Hooks installed today #1
mic214
Northern Colorado
Kubota LX2610 with cab..
I got my L3901 a couple of months ago. For my first mod, I decided to add some chain hooks and Clevis mounts to the bucket. After doing some research on the web, I decided to go with Kens Bolt on Hooks. I ordered three chain hooks and two Clevis mounts.
My bucket has an extra piece of steel welded across the top, which is perfect for mounting everything. The only issue is the top lip of the actual bucket does not meet up with the back edge of the top plate, so you end up with an uneven seam right where the bolts holes are located. This makes for an uneven surface for bolting everything together.
A quick email to Ken got my problem solved in no time. He sent me (For no charge!) a set of spacers that filled the gap between the two layers of the bucket and these allowed for a level surface to tighten down the bolts.
Here is everything installed:
I cannot say enough good things about Ken and his products and customer service!
/ Got my Kens Bolt on Hooks installed today #2
Only though is if you have welder, is a bit of tack weld to make sure spacers stay where you want them, as you "work" with bucket it will flex some and may reduce holding tension on spacer and allow them to slip/move...
Otherwise great looking install....
Dale
/ Got my Kens Bolt on Hooks installed today #3
Well now I'm envious. I didn't get a can cozy with my order last summer.
/ Got my Kens Bolt on Hooks installed today #4
Nicely done. I am a big fan of 3 hooks on a bucket so you are lifting from the right spot depending on what you are lifting and not twisting the loader. I have bought several sets of weld on hooks from Ken also as I have welder and prefer that way. I have done mine and several of my friends.
/ Got my Kens Bolt on Hooks installed today #5
Great Job!! I love my hooks, although I do need a third (middle) hook.
One question: Is there a reason you bolted the additional clevis hooks on top rather than underneath (Ken's option #2)?
/ Got my Kens Bolt on Hooks installed today #6
For a bolt-on installation, his hooks and setup are the best and they look great. They're probably better than many welded installations.
My tractor (L3901) has the “Square back” SSQA bucket and the way it is shaped does not make compatible with putting the Clevis mounts in the option #2 position.
Here are a couple of pics of the back of my bucket. You can see where the top portion of the inside of the bucket is actually slanted a downward bit (The section where the black ID plate is located) in relation to the the actual top of the bucket itself, which is flat. First off, you would need a really long drill bit to get through everything and then that angle would make it difficult to bolt the hooks and clevis mounts together…
/ Got my Kens Bolt on Hooks installed today #8
why wouldnt someone weld on $6 hooks from the local tractor supply store?
/ Got my Kens Bolt on Hooks installed today #9
Thanks for the great writeup Mic214 :thumbsup:
/ Got my Kens Bolt on Hooks installed today #10
-They can’t weld themselves
-They can weld and don’t trust themselves
-They don’t want to wreck the nice paint on top their bucket
-TSC doesn’t sell proper weld on hooks, only zinc plated ones that are not meant for welding
Those are a few quick reasons....
/ Got my Kens Bolt on Hooks installed today #12
Dale
bucket hooks are very useful: we need heavy duty everything so don’t do any bolted on anything if it can be welded, and our dealer welds them on for almost nothing
/ Got my Kens Bolt on Hooks installed today #13
/ Got my Kens Bolt on Hooks installed today #14
Looks great!! Thanks for the write-up and answer to my question. I have used (and maybe abused) my bolt on hooks from Ken and they have been great!! Just need to get one for the middle!
/ Got my Kens Bolt on Hooks installed today #15
/ Got my Kens Bolt on Hooks installed today #16
/ Got my Kens Bolt on Hooks installed today #17
Those Amazon weld on hooks are about the same price as Ken’s. And what do Amazon and TSC do for the TractorByNet forums? I’d rather spend my money with a forum sponsor who helps to make this place possible.
Thank you very much.
/ Got my Kens Bolt on Hooks installed today #18
And thank you as well.
/ Got my Kens Bolt on Hooks installed today #19
If only more businesses would follow the lead of Ken's "bolt on hooks" with respect to customer service. This business responded to an issue that a customer raised and delivered an answer and guess what, the customer is more than satisfied and tells others. What a crazy idea for business? You make customer after customer happy and you get more and more customers. Who would have thought? Or, use the other business model which is maximize profits for the month and lose customers who are annoyed and tell everyone they meet. The business fails and the owners question, what did we do wrong?
Well done "Ken's Bolt on Hooks." You've got my attention.
/ Got my Kens Bolt on Hooks installed today #20
What a unique process....Most concepts today are "take the money and run" (hide)....
Dale
500BBL WHEELED...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
