How to weld copper?
/ How to weld copper? #21
Isn't that always the case? Usually the wife sees something and thinks it would look great. Then when she's informed that gold is $1000 an ounce she changes her mind. Too bad. I've seen a few custom copper vents over stoves that look very nice. But the people putting them in just said do it, not how much. To me copper in a kitchen looks so much nicer than stainless.
It looks better most places. It is not as sterile and cold. It also has kind of an old timey type appeal to me, I like working with it being a soft metal. Bending, shaping, soldering.
/ How to weld copper? #22
Years ago an engineer friend of mine called me about doing a copper hood for his kitchen remodel. I told him a good tig welder could easily do it. The welder did an excellent job. Polished up it was nice.
I got the go ahead to do it. Copper was $255 with shipping. Hope to have it here later this week.
/ How to weld copper? #24
Stainless always looked industrial to me.
I'm sure plenty of us are looking forward to the pictures.
/ How to weld copper? #25
I might have a job that will include welding, or maybe brazing, some copper. I will fold it over one inch and I need to connect the bent over part. This will be a cover that will go over a cabinet. It will be 22 mil thick, or 24 gauge. Its pure copper.
What would you do?
I might just take it to a welder and have them do it, but for such a small project, I think I can do this myself.
Thank you.
Eddie, did you figure this out yet? If not, are you an O/A welder? I have found a process to torch weld copper. You use copper filler or fuse w/o filler and a special flux.
Ron
I have unrolled the copper and I'm letting it sit out in the sun. Temps are in the mid 60's and warming up into the high 70's next week. I'm hoping that the sun will relax it to lay flat. I still need to cut it and bend it. Once that's done, I plan to take it to the welder and have a pro do it. There will only be two welds, each an inch long.
/ How to weld copper? #27
Ron
What process do you use? I do oxy-acet welding and am always interested in a new process.
rScotty
/ How to weld copper? #28
rScotty
Here is their web link:http://https://www.tinmantech.com/
They have fluxes for copper, aluminum, stainless, and cast iron. Haven't tried any yet. Good to know. They have a lot interesting stuff.
Ron
/ How to weld copper? #30
That company does have a lot of stuff that they buy and resell but.. You can get a much better selection at a much better cost by simply visiting Harris Products group ( Lincoln Owned ) Allstate ( ESAB ) or Weldcote Metals ( lowest cost ) Washington Alloys ( Import ). These 4 are the best go to and price due to being importers and manufacturers.
/ How to weld copper? #31
I would solder with lead free solder inasmuch as it is decorative only and is not subject to pressure stress (copper plumbing or HVAC lines). While I am no professional, I have soldered plenty of copper plumbing with acid core. If you manage the heat properly, the solder all but disappears into the joint. I have also used solder paste for solder joints. Either wire solder or paste solder works well and leaves little visible excess solder at the joint interface. I once soldered a leaking copper HVAC line on my motorhome roof mounted A/C unit (R22). It never leaked thereafter. Unless the job is electrical (completely different animal), I have always used a propane torch. They provide more than adequate heat.
2020 Bobcat E26 Mini Excavator (A66734)
2020 Bobcat E26...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2011 SHBO MANIFOLD TRAILER (A67714)
2011 SHBO MANIFOLD...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
