M9540 gear ratio
/ M9540 gear ratio #1
AllDodge
S, Central, KY
Terramite T5C, Kubota M9540HDC24, F3990, RTV1100, Cat 416C, D3B, 955L
Anyone know what the gear ratio is for the M9540DHC24 SN 86399 ?
The tire sizing is not matching up so trying to verify other possible issues. Have read the M7040 has a 1.438 ratio, but if I use that with my tires this would mean real trouble.
Rear 18.4-30 Front 12.4-24
/ M9540 gear ratio #2
Don't know gear ratio but 18.4X30s are compatible with 12.4X24s ()R1s).
SDT
/ M9540 gear ratio
SDT
I am assuming the same even though the manual shows
For the M8540 and M9540
Front 12.4-24 or 360/70R24
Rear 18.4-30 steel, 16.9-34 cast iron, 480/70R34 (this tire is 18.4-30 and has 187 inch circumference)
I have cast wheels and manual list 16.9-34
I'm sure things are ok, but would like to verify everything so nothing is left out
/ M9540 gear ratio
Figured it out its 1.3529
/ M9540 gear ratio #5
My M9960 (replacement for 9540) has 12.4X24 fronts and 18.4X30 rears on cast centers. So did the 9540HDC24 that I looked at but did not buy.
I believe that you are confusing standard tires with available tires. Either size is available.
SDT
/ M9540 gear ratio
SDT
Not confusing the issue just reading the manual. As for all free op manuals, there are things missing. After figuring out what the drive ratio is, I was able to clarify that the wheels on the tractor are of correct size and they have no impact on current issues
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
T/A 18ft Enclosed Trailer (A61569)
T/A 18ft Enclosed...
2005 Freightliner M2 106 20ft. Reefer Box Truck (A61568)
2005 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Lot 1001 (A64047)
Lot 1001 (A64047)
