Tiny Dump Trailers Sure Trac Utility Dump
/ Tiny Dump Trailers Sure Trac Utility Dump #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I need trailer, but our SUV only tows 5000 lbs, and i need something compact in size to fit in the barn, and its pretty soggy back there.
I will tow yard debris (less than 2000 lbs), some lumber (less than 1000#) , fire wood (only about half a cord) and maybe stone once every 4 years or so to touch up the fire pit area (pretty small)
Does anyone have an opinion on this trailer: Sure-Trac | Utility Dump - Sure-Trac ?
Detailed reviews seem hard to come by.
/ Tiny Dump Trailers Sure Trac Utility Dump #2
Looks pretty decent for a light dump trailer and the payload is just under a ton. I assume the dump will handle the payload weight
Any idea of the cost?
/ Tiny Dump Trailers Sure Trac Utility Dump #3
I壇 be concerned about the panels rather than swinging gate. If anything slides up against the back panel while you drive down the road, you might be up in back, shoveling it out or trying to move all the branches, before you can remove the panel so you can dump the rest. That would keep me from buying this design.
I think I壇 look for a swinging gate version or something else. People always underestimate the importance of gate functionality. I did, and am having to have my gate hinges rebuilt because of damage during the dump, secondary to poor design. This is the reason I知 very cognizant of how trailer gates work.
im getting pricing around $2,300.
Awesome info on the gate, i would have never thought about that....
/ Tiny Dump Trailers Sure Trac Utility Dump #5
That's a good price for a dump trailer!
/ Tiny Dump Trailers Sure Trac Utility Dump #6
Look at 5x8’ single axel dump trailers. They can be had around $3500 new, and will be light years better then that.
I had one, prior to my 6x12, weighed about 1200’ empty and had about a 2 ton payload.
I have dealt with several boat trailers in the past, all of course had surge brakes.
Why do dumps come standard with electric brakes? Some manufacturers offer a surge brake option, and negatives to surge brakes for this application?
If I went to 5000 lbs I would need surge brakes since I will be towing with a chevy traverse, and may use my dads toyota 4 runner once in a while,
/ Tiny Dump Trailers Sure Trac Utility Dump #8
PJ trailers has one, and they ARE quality built trailers.
SR
/ Tiny Dump Trailers Sure Trac Utility Dump #9
Mine was bought used from a rental place, Cross Country Manufacturing, with surge brakes
/ Tiny Dump Trailers Sure Trac Utility Dump #10
Complexity and cost, is the two main reasons for using the electric brakes over surge.
/ Tiny Dump Trailers Sure Trac Utility Dump #11
I always thought it was the other way around... Why do boat trailers use surge brakes instead of electric... and the answer is due to how they are backed into water. I could be wrong but that's just why I thought they were used.
/ Tiny Dump Trailers Sure Trac Utility Dump #12
I've been looking at those also but don't care for the tiny axle. As somebody else suggested you will get a much better trailer if you go up to the next sized trailer which will handle a yard of gravel or up to a cord of dry firewood.
/ Tiny Dump Trailers Sure Trac Utility Dump #13
I can’t sleep so here is some long winded thoughts.
I happen to have my “hid from wife’s view from the house beer drinking outdoor glide chair” right close to my 5x8 CAM dump trailer behind the shop causing many hours of pondering its various advantages and disadvantages as I work my way through a quiet beer or 13 before going in the house.
1. It is handy but I will convert the dump gate to a swinging type barn door for this reason also.
When hauling trash or brush, then the tailgate ends up on the ground with the load on top of it during the dump. Which means a pull forward dragging the gate until the pile is cleared off. PITA it’s pretty **** heavy to take off and likes to pinch the **** out of you reinstalling.
2. Per another poster, a load of gravel will seriously overweight it.
Payload is around a ton.
Gravel or sand at 2800 lbs a cubic yard means it it capable by volume of holding 2.2 cubic yards roughly. That is 6160 lbs! It can’t quite carry a half full load safely.
https://downeastermfg.com/wp-content/uploads/2015/07/Cubic_Yardage_Chart-D.pdf
Firewood cord equals 128 cu feet. The trailer only holds 60 Or around 2.2 cubic yards. So a cord load means two trips or stake sides around 1 1/2 ft tall.
Red oak weighs 1200 lbs per cubic yard and measures 5 cubic yards roughly.
Plywood = 50 lbs per sheet roughly. 40 sheets to the ton which is the payload.
So. A 5x8 with a 3500 lb axle can easily hold a lot more than it can carry safely.
It is handy as a pocket though. Sure is nice to know you can unload it by “pushing that button”!
/ Tiny Dump Trailers Sure Trac Utility Dump #14
I too have considered this trailer. For my use I would rather invest in some thing more substantial. Seriously considering a DO 608 from Quality Steel and Aluminum. Overall build and capacity is heavier. The deck over design does raise the center of gravity but also create more under body clearance when dumping. With the wheels underneath allows easier side loading and a narrower profile while maneuvering around the yard. I only wish it had a combo tailgate as an option. Barn door for regular dumping and top swing tailgate for spreading gravel and fill.
/ Tiny Dump Trailers Sure Trac Utility Dump #15
I looked at this trailer as a possibility for a couple of uses and decided it wouldn’t be very good at either... I wanted something I could use around my property as a lawn/garden/trail use trailer. This one had the right size but terrible gate, no manual dump, and no stake pockets for loads like brush.
I did like that it was street legal but again, the gate issue and puny payload.
Couldn’t see spending the money they wanted for it. If you’re not needing it for a yard/trail trailer, get the larger “homeowner” model
I ended up with the sure trac 5x8 homeowner. Its perfect. It can fit all my equipment for transport, one at a time of course. With the new wood sides, it has plenty of capacity. The single axle is very maneuverable, which is critical for me.
Farmall Super A Tractor (A62613)
Farmall Super A...
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
