Good morning!!!!
   / Good morning!!!! #87,263
No not really
   / Good morning!!!! #87,264
Forgot to put vehicles in garage, so cleaned them off. 30° and light flurries. Measured 4" snow in driveway.
Moved Ranger from barn to garage to install a poly windshield i bought from amazon.
Found out it needed assembled, rubber seal around the side was a PITA to get on, then clips on side didnt fit the holes, so had to file the hole bigger.
Then went to install the vent slides and discovered i did everything backwards. Instructions made no mention that one side needed to be the inside due to a preinstalled stud for the vent.
Tried to fit it on ranger anyways, without vent slide, and it doesnt appear to fit well.
And once i took the film off the poly, found a 6" long scratch on one corner, at least not in field of view. Sticker says cant return once you remove the film, but couldnt see scratch until removed.
Pretty disappointed, this thing was over $400.
Went on amazon to write review, and i cant. They said i violated their policy. No clue how that happened.only wrote one review that i can remember. Now I'm pissed at amazon also.
Guess I'll go back out and reverse everything and make it work.
   / Good morning!!!! #87,265
fill up that fork with potatoes and you'd better be pretty strong, looks like it could hold a bunch.
Not much more to get done in garden shed, pretty much filled up waiting to be moved to greenhouse.
Maybe I'll set up my new worm farm. Concerned about getting worms shipped to me in freezing weather.
My Urban Worm Bag has been taken to the country. Gosh I hope my country worms will be ok...;)
   / Good morning!!!! #87,266
Don, that is not a potato fork. Potato fork has about 4 heavy tines strong enough to dig.
   / Good morning!!!! #87,267
Called mom she thought it was used for cleaning out the hay from the barn.
It’s new use is the best mulch tool for the Trail Blazers group. IMG_2601.JPG
   / Good morning!!!! #87,268
I turned the key on the JD to see how many hours it was used yesterday and right before it displayed the hours this message was on the hour meter. What does it mean?IMG_2599.JPG
   / Good morning!!!! #87,269
I thought that fork was a haying fork. It would take a strong hombre to pull potatoes with that fork. We always used a garden fork as described for potatoes.
BEF- I do not envy your situation. What a ripoff. Good luck.
Drew- Good luck with the worms.
RNG- That’s a nice sawbuck. I agree about current designs, I made a sawbuck out of pressure treated doubled 2”X4”’s similar to yours when we bought this place +30 years ago. I bet I had 20#’s of self tapping screws holding it together. It was constantly modified as needed and finally DOA’d this year. Thanks for the picture.;) It’s 16” for me nowadays.
David- NE won handily today. Today it was LA who did not show up. I actually stayed awake. I did not go near my easy chair.
3 possible weather events with multiple un-phased parallel (upper level lower level/jet streams) system setups next week = my head hurts. February should be interesting. Maybe, just maybe I'll get a snow management exercise this coming weekend.
1619 (A58375)
1619 (A58375)
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
2021 John Deere HPX815E Gator 4x4 Diesel Utility Cart (A56857)
2021 John Deere...
