Handling railroad ties
/ Handling railroad ties #21
My preferred method would be a set of tongs so you don’t have to worry about getting under them. The method described in post 19 also works well. I’d probably use a boom pole and the tongs to set them in place. You should also get a cant hook for rolling the ties over.
/ Handling railroad ties #22
Don't know if you have interest but if you rent a mini Ex you could do the entire job very easily. If you can get down in the creek (you mentioned very little water) just grab them with the thumb and set them right in place. Would take almost no physical effort and you can use the mini to clean up the bank for a flat entrance/ exit. If you can't get into the middle you could easily work it from both size due to the power/reach of the machine.
/ Handling railroad ties #23
Instead of a grapple and boom pole the simple way is to use your loader bucket,
Use a heavy ratchet strap, pull up with your loader with the tie making a tee shape lower the bucket
down on top of the tie, say 3 feet from the end, loop your strap under the tie and back to your bucket,
with the strap to the front side of the bucket tighten the strap, lift with your loader,
the heel of your bucket will hold the end of the tie down and you can drive right up with the tie extended
set it down and be done with it.
I hope my description is clear, it will be similar to a clamp on fork lift arm, only the strap replaces the clamp bolt.
your bucket .
Oh it's clear ,except the part where you pick up the tie with one hand while tucking strap under and around tie with other hand.:superman: Then you have the part where he said he want's to do it without getting off tractor.
/ Handling railroad ties #24
I would be taking them out of the pickup the same way, and if I was stacking them, I'd lay a 4x4 on the ground under the end.
And leave room between them for my hand.
I like hydraulics :cool2: :drink:
As far as not getting off the tractor, thats the helpers job :dance1:
/ Handling railroad ties #27
Put a pallet in the bed of the truck. The end of the tie will hang of the pallet. So no need to lift. Also if the tie is 10 long it will likely stick out beyond the end of the bed if using a pickup truck.
/ Handling railroad ties #28
your bucket .
That is the way I set 3 16'ers across a creek with my little BX
Ron
/ Handling railroad ties #29
Backing up a bit, I don't think I'd use used ties for any weight bearing needs. At least not the ones I've seen so far. Lots of splits and cracks and there are the spike holes. If you're going to use it to drive over with anything larger than a small riding mower, I'd try to find new ones.
/ Handling railroad ties #30
Tongs would work, but I suspect a choker chain would too.
Are there any large trees in the area? If so, you could use the tractor to place the RR ties on one side of the stream, more or less aimed in the right orientation, then setup a fairlead up in a tree on the opposite side of the stream to lift the end of each RR tie and drag it into place across the stream.
I use a logging block/pulley and short tree strap to setup fairleads up trees, and a 5/8" or 3/4" logging rope to do the pulling (with chain/choker on the business end). I move logs, but railroad ties would be a good application too, and easier. The nice thing about this is that you can setup the pulley so that you pull in any direction. Sometimes I pull 90 degrees to the motion of the log, sometimes I pull opposite of the direction of the log. Conceivably you could pull from the same exact side of the stream that the RR ties are delivered to.
/ Handling railroad ties #31
I used these for a railroad tie project years ago. They are made in the USA so I know it was a long time ago. 😀 Used a chain and set one on each end.
/ Handling railroad ties #32
I would never buy used ties that are split or show rot. As I stated in my previous post, this thread, I spanned 12' with 3 16' ties and drove my 1 ton w/2 tons of gravel several times (close to 12,000# with no problem, no movement, no sagging. A ten yard truck or concrete mixer? NO way.
Used ties are graded as to condition: #1-one good side (avoid these they are considered culls), #2- 2 good sides, OK for landscaping, #3- 3 good sides (what I usually use structurally), #4- 4 good sides hard to find & most expensive they are almost new been in service short time. No matter the grade avoid ones with long splits are evident rotting. If they are not heavy preservative they are ready to rot. Heavier the better.
Ingenuity and common sense it is easy to handle ties with a SCUT. Let leverage do the work to cantilever them to push across a stream/ditch. I have had 16'ers cantilevered out of my FEL many times, remember rear counterweight and tie down the FEL end to prevent swinging sideways, and go slow. Come along from the outboard end from the center top of bucket helps stabilize.
RR ties are still an economic means of building sturdy stuff. I use them for the base of tent type garages/green house, storage buildings, always bedded in crushed gravel.
Ron
Rock Hammer for Excavator (A65579)
Rock Hammer for...
1989 Freightliner FC60 Day Cab Truck, VIN # 1FUP2DYBXKH356541 (A65563)
1989 Freightliner...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
