Who Uses CB Radios?
   / Who Uses CB Radios? #111
Yes, and no. There are many repeaters that have fairly active road information during times of severe weather. It just depends. Yes there are more people on any given stretch of road with CB vs. Amateur vhf/uhf rigs in their vehicles, BUT repeaters can cover a wide area, and during severe weather they are often linked together and nets are called to provide information. Now as far a warning you about a wreck up ahead, the CB will likely be more help. Also keep in mind, with the relaxing of the Amateur Radio licensing requirements, more and more truck drivers are licensed amateurs and many do have Amateur rigs in their trucks. Some both vhf/uhf and even HF. I am not saying even every 1/10 truck has an licensed amateur aboard, but they are a fair number of them.
And let's face it, a cell phone with a GPS and map application will show you traffic conditions in real time anywhere in the country (for the most part). A CB you can call up ahead and ask what's the reason for the traffic jam and is there any hope of moving in the near future. :laughing:
   / Who Uses CB Radios? #112
I am not sure where to even begin. But I will assure you a CB radio is capable of communicating over thousands of miles at the peak of a sunspot cycle (11 year cycle). At the minimum of a sunspot cycle (where we are now) and with poor (inefficient) antennas, then that "couple of mile" is about right.
Yeah, it's capable. But the truth of the matter is someone buys a CB, tosses it in their truck, slaps up an antenna, and they're good for 5 miles or so. I was happy to get 15 in my car with friends in other cars.
I have had good luck getting winter road information off the Government of Ontario website. I tried a couple of days ago, and a whole new platform with much complexity, made it impossible (within time and patience contraints) to find the particular area I was intending travelling.
All this high tech stuff just seems to get worse with time. the people that design this stuff have spent hundreds of hours using it and then expect someone to figure it out, when someone may only need it once in a blue moon. And then the platform changes again!
One reason, I like something, stupid simple like a CB radio!
   / Who Uses CB Radios? #114
Breaker one nine you big sack of monkey nuts howz it hangin 10-4...You got the Clutch we slipping & gripping up the north side come back.:laughing:
   / Who Uses CB Radios? #115
Yes, we use them at work daily (all the trucks have CB's and many of the company pickups), couple of miles is all that is needed.
   / Who Uses CB Radios? #117
I still have and use a hand held C-B purchased from BIRD of Texas
Here they are used when pulling into wood lot with logs to be unloaded the dispatcher tells you a number so when unloader is ready for your truck to pull into line.
also same method for in the woods. truck loaded has right of way in exiting the area.
the state weight police parked on side of road and there will be no logging truck on the high way.
Deer hunting and CB's keep track of who is moving from one location to another.
I prefer not to listen to skip or the local yokels in the city.
ken
Also here the cell phone signal is directed along the highways get 4 miles away and no signal available.
ken
   / Who Uses CB Radios? #118
I have a CB as well as a VHF/UHF ham radio installed in my truck and I use it almost daily. I don't talk much but I am listening while I drive. CB radio is still in wide use and I don't think there are many truckers without a CB. If you are only getting a mile or 2 range out of it then improving your antenna installation should greatly improve your performance.
While cell phones are great, there are lots of places her in the mountains of PA where they just don't work. I have cell coverage where I live but once I get out of town there is no cell signal for several miles in any direction. I am always able to communicate by radio in any of these dead areas.
The biggest problem with a CB is outside of professional drivers, not many people have them anymore. Everyone has a cell phone and they are pretty reliable if you don't live in or travel through rural mountains.
Gravel pits use them around here. When I was working in their office, I thought, how primitive, thinking they used them for on site communications. Then I realized and observed how they could talk with any incoming or outgoing dump truck. VERY effective, and CHEAP!
   / Who Uses CB Radios? #120
That sounds more like a bad antennae or the system needed tuning. Radio is not always plug and play; sometimes the whole system needs to be tuned.
A mismatched system(CB, ground, antennae cable, antennae etc) may just give you bad results even tuned.
You should easily get more than 2 miles...
I must never have been in a high solar flux. (not sure what that is)
Been using CB radio's since the early 80's, best I ever get is a couple miles.
Hose Reel (A55758)
Hose Reel (A55758)
UNUSED DIGGIT 10D-10 DRAWER WORK BENCH (A54757)
UNUSED DIGGIT...
1564 (A54756)
1564 (A54756)
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
