front wheel won't come off
/ front wheel won't come off #1
desertrydr
Tri-Cities, WA
Kubota L3010HST
I have a Kubota L3010 that has a flat front tire. I took off all the lug nuts and tried to take the wheel off the hub. It won't come off! Not sure what I'm missing, how do you get the wheel off?
/ front wheel won't come off #2
Are you taking it off to take it to be repaired?
Will it hold air for a few minutes?
If it will stay up for a few minutes, leave the lug nuts or studs on loosely and drive in a figure 8
for a bit the wheel should loosen then. The jack it up and remove.
If you can't drive it, a block of wood and a BIG hammer, keep beating till it comes loose.
/ front wheel won't come off #3
I've used this successfully. A propane torch - heat the rim, right around the axle - gently. The rim will expand and should break free of the axle.
Thanks, that did the trick. I'm reluctant to really pound on something without knowing why it didn't come loose, but in this case, its ok.
/ front wheel won't come off #5
I apply some never sieze to the hub and rim before reinstalling mine.
/ front wheel won't come off #6
I've used that trick many times on many different things. The real trick - not too much heat and give it time. A lot of times the stuck part will release with a loud clicking/cracking sound. Most all the times it's been a combo of old rust and dirt that almost welds the parts together. A real good sanding and, like George says, an anti-seize product. It won't happen again - real soon.
Pounding can bend things. Then you have just added to your problems.
/ front wheel won't come off #7
I rolled the bead off on my front tractor tire once. I got it to inflate again by putting a ratchet strap around it and manually pulling it around to help seal the remaining gaps. It helps to take the valve stem out to get in more air faster. If the tire is busted then you’re back to square one.
/ front wheel won't come off #8
Which method did the trick? Driving around with loosened lug nuts or heat? Just curious. I've used both methods.
/ front wheel won't come off #9
Someone here on TBN told me this same trick many years ago when I had my small pneumatic tires on my casters break the bead and come off the rim. Works great! Tighten that strap and then inflate.
/ front wheel won't come off #10
I would sooner the wheel be hard to come off than deal with that horrible anti seize. I mean we're not talking galvanic action between alloy and steel.
/ front wheel won't come off #11
I use lots of nickle anti-sieze and I have a couple cans of copper spray that I also use.
Anything that I take apart gets never sieze, when I swap tires winter and summer the studs and mating
surfaces get it.
It is a pain to get off your hands but I use it a lot.
I may cuss a bit when I get on myself but to me it's worth it.
/ front wheel won't come off #12
Anti-Seize is amazing stuff!
You put it on something, and then you find that you have it all over yourself as well.
/ front wheel won't come off #13
You gotta give er more throttle and POP the clutch. Maybe get a good burn-out while getting the front wheels off.
Opps...did I read this wrong?
EZ Trail 3400 (A63688)
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
2010 John Deere 4720 (A64126)
2010 John Deere...
Deere 333E (A60462)
Deere 333E (A60462)
