Small generators
/ Small generators #21
For less than $200 (usually way less) you can find these old Coleman 4000W generators used on e-bay and craig's list all day long. This one is $125.
33 amps @ 110V
16 amps @ 220V
I've had one since 1995 and it works fine to this day.
Cheap, affordable portable power to get some work done.
COLEMAN GASOLINE GENERATOR - 4000 WATT | eBay
I knew you had one of those Colemans running up there in South Bend.
I can hear it all the way down here in Florida.
/ Small generators #22
The original poster asked about small gens. I've worked on job sites with less $$$$ generators operating at normal outputs. My ears do have a value, and I'll not do that again.
/ Small generators #23
Finally got new batteries in your hearing aids, eh? :laughing:
Yes, it is loud. I'll agree with that.
But the OP just spent $950 on two generators that still won't start his air compressor. And he already had a $450 generator from a few years ago.
The task was to paint a shed. That should only take a couple hours at best.
- $125 for a used 4000W generator.
- You can buy 80 pairs of foam earplugs for $15, or a decent set of earmuff style for $30.
I always wear hearing protection when operating power equipment anyway, so no different.
/ Small generators #24
When I built this house I ran 200 some odd feet of extension from my other house.
What I did was purchase a spool of 12 gauge (red) heater line as I'd be needing it anyway for the baseboard heaters).
Wired it thru the proper breakers and that served me well as it handled all my power tools that I needed.
At night I'd power up a small heater to keep the chill out as during the day I had installed an old pot belly that I had kicking around.
Day heat was via pot belly and cut off scraps of studding and furring strips.
With #12 gauge no power tools complained.
you must have used low current tools. "1 conductors per phase utilizing a #10 Copper conductor will limit the voltage drop to 7.00% or less when supplying 20.0 amps for 200 feet on a 120 volt system.
For Engineering Information Only:
30.0 Amps Rated ampacity of selected conductor
1.1417 Ohms Resistance (Ohms per 1000 feet)
0.05 Ohms Reactance (Ohms per 1000 feet)
12.0 volts maximum allowable voltage drop at 10%
8.395. Actual voltage drop loss at 7.00% for the circuit
0.9 Power Factor" Voltage Drop Calculator and THIS is for a 20 amp load, if you needed to start a capacitor start motor, like a compressor, it could, depending on the motor, draw 100 amps for starting!..(check the LRA, which is the locked rotor amps) you'd get much too much voltage drop with 12 gauge wire!.. I have a friend that tried starting his 2 HP compressor with a 4000 watt generator, and all that happened was the compressor slowly turned, but never started, and it was plugged in directly to the generator!.. for a compressor, it's better just to put an engine on it, or buy one with an engine already installed..
/ Small generators #25
I'm not so sure why your confident that a used 4k genny is going to run the compressor, his surge rating is 4600 on the 2 he currently has.
i had a 4k genny with parallel windings, it would barely run a Lincoln welder on its highest setting and it had a 13.3a input on it. surge is a big deal for generators.
/ Small generators #26
I think we're making this way more complicated than it needs to be for the OP's issue. :laughing: Michael just wants to paint his shed with a Graco Ultra 395 PC airless sprayer. I'm no sparky, but I can use an online voltage-drop calculator well enough. ;) If he plugs a 100-foot 12AWG extension cord into a residential duplex receptacle producing 120v at his house/garage, the voltage drop will be slightly less than 5%. So usable voltage will still be slightly more than 115v. The specifications of the Graco Ultra 395 PC call for a voltage of 115v. That assumes that the useable line voltage delivered by the Utility in Michael's area, Colorado Springs, is the typical 120v/240v (nominal) for residential service.
If he uses a 10AWG extension cord, voltage drop will be only 3v, resulting in 117v at the sprayer. In addition, that Graco sprayer is a commercial unit, intended for all-day-long professional use on construction sites. Michael can call Graco and speak with a tech rep if there's any question about this, but I'm virtually certain it can be used on a 100-ft 12AWG extension cord on a 20A residential circuit to paint his shed with no problems.
16 years ago, a couple of helpers and I painted my barn with a 5/8 hp Harbor Freight airless sprayer in a couple of days, running on 300 feet of 12AWG extension cords plugged into a 20A receptacle in my tractor garage! Even that $250 HF sprayer didn't complain. :laughing:
/ Small generators #27
I just purchased a Briggs & Stratton Q6500 https://www.homedepot.com/p/Briggs-...h-Briggs-and-Stratton-Engine-030675/301871650 generator for my house to replace a loud All-Power unit that developed valve problems. It has 240 volt plug that is compatible with my transfer switch. Caught them on sale at Home Depot for $999 in November 2018. It is very quiet, compared to the All-Power unit and has sufficient power to run 6 circuits that include a microwave oven and both gas heaters. It meets my needs for 1/4 the price of the Honda EU7000. Many hours was spent shopping and the Q6500 came out the winner.
/ Small generators #28
the problem lies in the current required to START a Capacitor start motor, using a rope start or 12V starter to bring the motor up to speed, but most people don't do that!.. your calculations don't take account the starting current..
/ Small generators
I bought the little A-iPower SUA2300i's from Sam's Club when they were on sale for $249/each. I also have an A-IPower SC2000i from Costco. I think it was ~$450 on sale in store.
Painted the inside of the shed today. Wound up using a 100' 10ga extension cord connected to mains electricity. I didn't notice any difference -vs- a 25' extension cord.
I strongly suspect the two little generators in parallel could have handled it. I might do some more testing when I'm not pressed for time.
/ Small generators
I sort of mixed two different electrical loads into the same topic.
I'd been thinking it would be "nice to have" more generator capacity than the single SC2000i. I've been watching the price of the SC2000i, thinking I'd snag another one if they ever went on sale from $550 to $450 again.
I needed to paint the distant (about 125' from the house) AND I noticed the SUA2300i's on sale for $249/each at Sam's Club. I assumed the two SUA2300i's in parallel would be fine for the paint sprayer, but I decided to "test" them with my heaviest single load -- the Dewalt D55153.
I figured if they could run that Dewalt compressor, they could run anything.
When they ultimately couldn't run the Dewalt compressor, I started 2nd-guessing whether they could even run the paint sprayer.
I wound up using a 100' 10ga extension cord and 50' of paint hose.
I may still look for a ~5000W (running) or larger generator just to have around for larger jobs.
I noticed a Champion 4375/3500W running dual-fuel at Sam's Club for $300, and a Honda-powered Black Max 7500W running for $1000.
Costco has a dual-fuel Champion 9000 / 7000W running for $700 and a Generac 10000W / 8000W running EFI for $1000.
The EFI is especially appealing as it automatically adjusts for altitude. No carb.
/ Small generators
Is there any way to estimate from this placard how large a generator would be required to start this air compressor?
I've seen charts that predict the starting watts for an air compressor to be anywhere from 2x to 6x the running watts.
/ Small generators #32
look on the data plate for LRA amps, THAT is what the motor will draw when starting up, multiply the LRA amps times the motor voltage, and THAT is the wattage. for instance, 40 LRA times 120 Volts=4800 Watts.
/ Small generators #33
Is that the only spec plate for the motor on that ? Most electric things (motors) will list an amp rating somewhere
I don't see one here
/ Small generators #34
A general rule of thumb is to calculate the size of generator required , then purchase a generator twice that size . Not kidding or trying to be funny.
A small consumer grade generator should not be operated anywhere near 100% load . Plus reserve capacity is required for inrush loads .
/ Small generators #35
Our shed is 285 away from the nearest plug. Rather than drag our EU2000i down to it, we run three 100 extensions. Because it痴 much cheaper and we can connect items left unattended.
Amazon Basics 100 10/3 is $100.
I would be burying four runs of #2 copper in a conduit from the nearest service to a 60 amp panel in your shed . Two 10 ground rods at the shed and float the neutral wire free of the ground bar at the shed .
/ Small generators #36
As previously stated several times by others . Inverter generators will not provide that momentary 2 or 3 times full load rated current . An Inverter generator goes to max current then shuts itç—´ self off.
/ Small generators
Honestly, that's what I thought I had done.
I wanted to be able to run any single 120V appliance that could be powered by a standard 15A outlet (~1800W).
These little generators are rated 2300W surge / 1800W running. So roughly 4600W / 3600W combined.
Even after compensating for altitude, that should be something like 3600W (~30A) surge / 2800W (~24A) combined.
TEREX RL4 LIGHT PLANT (A63569)
TEREX RL4 LIGHT...
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
