What would you use to glue seat back down?
   / What would you use to glue seat back down?
I use Mean Green spray adhesive to glue my seat back to the pan. You spray both sides, wait till it is tacky then stick both together for instant bond.
I get it from my local HVAC supply house. I think they must use it to attach the foam boards inside AC ducts. I have also used it to secure weather stripping.
That sounds cool but looking g at their site or some supply house site it's only availible in 12lb, 40lb, and 375lb cylinders. All of which would be quite a bit larger than I would want to buy for this project or to even keep on hand for others.
I did find the masterseal on I think walmart.com for like $8. I have a few other things I am gonna order so I am throwing a tube of that in with the order to try.
   / What would you use to glue seat back down? #12
My adhesive of choice is Silicone II. But I must say that I was impressed with Lepage PL construction adhesive. I dropped a blob on concrete and couldn't kick it off without a fight. However, unlike silicone with give, when it breaks free, it's free.
   / What would you use to glue seat back down? #13
It comes in a spray can (about 16 oz.) for $12?? (forget the price but a little pricey) You may have been looking at the wrong item.
I think it was the same stuff. But I think they just sell to businesses doing installs. It was mean greend contact adhesive. Applied just like you say.
It sounds handy. I'd buy a can at $12 ish dollars if I could find it.
   / What would you use to glue seat back down? #16
That is the same company (Mean Green by Quest Vapco). Mine comes in an 18 oz. spray can. You might try your local HVAC supply company. I know that if I can get it in Hot Springs, Arkansas, it should be available just about anywhere. I dont know why their website only list huge containers.
The can gives address of distributor as:
QuestVapco Corporation
P.O. Box 624
Brenham, Tx. 77834
phone 713-896-8188
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
