What would you use to glue seat back down?
   / What would you use to glue seat back down?
I use Mean Green spray adhesive to glue my seat back to the pan. You spray both sides, wait till it is tacky then stick both together for instant bond.
I get it from my local HVAC supply house. I think they must use it to attach the foam boards inside AC ducts. I have also used it to secure weather stripping.
That sounds cool but looking g at their site or some supply house site it's only availible in 12lb, 40lb, and 375lb cylinders. All of which would be quite a bit larger than I would want to buy for this project or to even keep on hand for others.
I did find the masterseal on I think walmart.com for like $8. I have a few other things I am gonna order so I am throwing a tube of that in with the order to try.
   / What would you use to glue seat back down? #12
My adhesive of choice is Silicone II. But I must say that I was impressed with Lepage PL construction adhesive. I dropped a blob on concrete and couldn't kick it off without a fight. However, unlike silicone with give, when it breaks free, it's free.
   / What would you use to glue seat back down? #13
It comes in a spray can (about 16 oz.) for $12?? (forget the price but a little pricey) You may have been looking at the wrong item.
I think it was the same stuff. But I think they just sell to businesses doing installs. It was mean greend contact adhesive. Applied just like you say.
It sounds handy. I'd buy a can at $12 ish dollars if I could find it.
   / What would you use to glue seat back down? #16
That is the same company (Mean Green by Quest Vapco). Mine comes in an 18 oz. spray can. You might try your local HVAC supply company. I know that if I can get it in Hot Springs, Arkansas, it should be available just about anywhere. I dont know why their website only list huge containers.
The can gives address of distributor as:
QuestVapco Corporation
P.O. Box 624
Brenham, Tx. 77834
phone 713-896-8188
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
