New to Grid Tied Home Solar...
   / New to Grid Tied Home Solar... #11
On our system it was installed by a contractor, who had to get a permit from the county, and at completion of the installation, it had to be inspected by the county and then the utility before it could be turned on. The only glitch was the contractor hadn't applied the plaques on the front of the meter box. He showed up while the inspector was still here and everything was fine. I get a weekly statement form the utility showing usage and a monthly statement from the invertor supplier showing production.
There is a small display plugged into the closest wall outlet to the meter box and a small unit plugged into a wall outlet closest to our desk top computer.The installer told me that the unit in the garage communicates with the little plug in box by the computer through the common wire in the house wiring.This little box communicates with the computer wirelessly and I can check anytime to see what it is producing.
It's all voodoo to me but seems to work.Having a system owner installed like you're dealing with would be near impossible without some records including passwords etc. but should be doable through the utility customer service dept. if you can find anyone there who will go to the effort.
Yep... no display except on the unit itself which is field mounted... the array is on the hillside.
Plenty of labels on meter, disconnect, etc...
Looks like I will need to contact the invertor manufacture for specifics on the model I have... if it needs Internet there is none.
Pictures today if I can get there before dark.
   / New to Grid Tied Home Solar... #13
considering it..friend has solar city install and it took the utility FOUR MONTHS to approve it so it could be turned on. She's liking i. No cost to her, at all. She gets credits for energy produced that offsets her usage.
I may retire in less than 5 years and will sell my house..so I'm debating whether it's worth it not, what ramifications are if I sell, etc.
   / New to Grid Tied Home Solar... #14
So she has no electric bill?
   / New to Grid Tied Home Solar... #15
Mine doesn't require internet to operate but is just an additional way to monitor what it is doing.With my system it has individual inverters and the unit on the wall tells you if all of them are working and ,if not, which isn't.Also the output updated every few minutes. I would think that you can buy this from th inverter mfg. if you have the model number etc. It is my understanding that if you have a single large inverter and it or one panel goes bad the whole system is down.
It is my understanding that it is illegal to have a solar system connected to the power grid without authorization from both the utility and local government agency involved, in our case, the county.
   / New to Grid Tied Home Solar... #16
Huh, that seems totally counter the the point of hybrid grid tied. Also doesn't line up with the FAQ:
Have a source for that info? I know they are on v2 so that may have been for the old, non-hybrid versions.
I happened to watch a YouTube video of about a guy who installed a solar system with a Tesla Powerwall. He was very happy with the installation and how Tesla handled some issues with the installation. He made the statement that no Internet meant no power.
Later,
Dan
   / New to Grid Tied Home Solar... #17
I supply Internet to my Neighbor who has a microfit (grid tied) solar installation. He doesn't even live here but I hear about it soon enough if I have to take the Internet connection down temporarily on account of the microfit using it.
   / New to Grid Tied Home Solar... #18
Sunny Boy is very good about having the operational/set up manuals on line. You just need to know what the invertor model is. On most, if not all of the Sunny Boys the internet monitoring system is optional and can be rewired to stand-a-lone. These are BIG PDF files so have lots of paper and printer ink. :) After having my Own Grid Tied array for 12 years, my opinion is sort of mixed. If I was doing it over again I would just buy-in to someone else's project. You will always pay the base Electric Syste Charge. As a prior poster said, it makes no economic sense to generate more power than you use. The utility buys that back at the same rate that they pay for the power they get from say "Seattle Light." In my Case, what my Power Utility pays Bonneville. What it does do is let you live "Large." In the sense that you are now free to use up all of that electricity with stuff like charging an electric car. That is where you gain, because you are offsetting the more expensive electricity you would normally be paying for. And you can buy and use less efficient, cheaper, appliances, light bulbs...etc. You really get nothing for over generating what you can't use.
   / New to Grid Tied Home Solar... #19
We have had grid linked solar for about 7 years now I guess. We get 50 c per kw for what is fed into the grid. That was fixed for 15 years at the time. It is only a 4 kw system which, at the time was a considerable size. It is a SMA inverter.
Sometimes we are in credit but during winter we may get a bill around $200 per quarter.
In the time we have had the system we have produced 40,000 kw. It cost us about $11,000 at the time so it has easily paid for itself.
If we had managed a slightly larger system at the time we wouldn't get any bills at all. Hopefully in about 3 or 4 years I will be adding to or replacing the system with a larger one.
We have had no maintenance costs at all.
Finally able to take some pictures...
Today's winter production was just under 15 kW... for a 6kW array?
Sunny Boy Readout states 103,582 kW produced.
Pictures include the hillside arrays, Sunny Boy Invertor with Specs and Disconnects, Panel Specs, Utility Meter with 2014 install and Back Board.
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
2016 Audi A3 (A56859)
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
Caterpillar 740 HT-129 Tanker, S/N CAT00740PB1P009728, Cat Turbo Diesel Engine, Tidal Wave Tanks ... (A59076)
Caterpillar 740...
