L3800 PTO cable fix
/ L3800 PTO cable fix #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
Any tried and true, long lasting fix for the sticking cable issue? I've lubed mine with the best lube I can find and I'll still have an issue if I don't use it frequently enough. Stronger spring, different cabling routing? The problem is certainly compounded by the lack of accessibility to get it properly cleaned and lubed. A direct lever would be a nice modification or retrofit.
/ L3800 PTO cable fix #2
Have you already replaced the cable in the past?
No, haven't replaced it. I've managed to get it freed up and lubed each time and it works for a while, but eventually starts to stick again.
/ L3800 PTO cable fix #4
Sounds like you'll need to replace the cable.
I had the same problem arise on my motorcycle clutch cable. No matter how much lube and cleaning, it would never perform correctly. Wound up spending the $80 to replace it. Works so smooth.
/ L3800 PTO cable fix #5
L3700 here. After a few years I couldn't get PTO to engage or if engaged, to disengage. I got a new cable from Messicks and presto, problem solved. It's best if you dismount the rear tire/wheel to do the job, not so bad.
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2023 BOMAG BW120AD-5 DOUBLE DRUM ROLLER (A62129)
2023 BOMAG...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2009 Chevrolet 1500 Savana Van (A63116)
2009 Chevrolet...
1993 WhiteGMC WG Tri-Axle Dump Truck (A61568)
1993 WhiteGMC WG...
PROPANE TANK CAGE (A62131)
PROPANE TANK CAGE...
