Rounded off drain plug
/ Rounded off drain plug #1,201
Well, I had a little problem with no drain plug. I got my new flail mower ready. Removed the fill plug and could not see any oil. I put the funnel in and filled the funnel full of oil. Looked back a little later and funnel was still half full of oil. Removed funnel and case is not full. It must have already been half full as needed. So now I need to drain some of it out. There is no other plugs on the case and I do not have a pump. Turned the mower up on end,(it is a ditch bank mower with tilt). After about 30 minutes, I got about 1/2 inch of oil out of it. It is thick and runs real slow. I will have to see a better way to check it in the future. I may just need to turn the pto on and let the oil warm up a little. And there could still be air pockets in the case.
So I may change my vote to just turning the tractor upside down. I know it will work.
How big is the fill plug? After the oil was hot ( probably obtained with another heat source not just running it ) you could probably siphon it out.
/ Rounded off drain plug #1,202
After it is hot, I may try a turkey baster. I can wash it and the wife may never know.
/ Rounded off drain plug #1,203
I can picture it now. Sucking hot oil up a hose, burned mouth, trip to the ER, week w/o being able to eat. Got smart one day and pulled the plug on a hot crankcase. Good burn on my hand and arm. That was before I perfected my methodology; let it cool below the burn point for one.
Ron
/ Rounded off drain plug #1,204
Use a clear hose. If you suck oil in your mouth using a clear hose you probably aren’t the sharpest tool in the shed.
/ Rounded off drain plug #1,205
Hook this up to your air compressor, drop the tubing into the case and squeeze the trigger to get the siphoning started, pull the tube out when enough has been removed.
https://www.amazon.com/Milton-S-157...YMYCBBCX7HA&psc=1&refRID=RDC2WB88QYMYCBBCX7HA
/ Rounded off drain plug #1,206
/ Rounded off drain plug #1,207
Maybe it is just me but I still don't understand how this helps remove the drain plug. :confused3: Maybe it reduces the hydrostatic pressure on its backside? :laughing:
It doesn’t. But it will start a siphon. It’s the same concept I discovered when I was about 5 by putting 2 straws in a glass and covering the top with my hand. Blowing in one straw would push water out the other straw. Take it easy with the pressure so you don’t blow a seal out.
/ Rounded off drain plug #1,208
Called the "venturi effect".
/ Rounded off drain plug #1,209
That’s different than what we’re describing. We’re talking about about sticking a hose to the bottom of the fluid in a sealed container and pressurizing the container. The fluid is pushed out the hose. It’s the same way a fire extinguisher or a pump up weed sprayer works.
/ Rounded off drain plug #1,210
It was actually invented by Curly Howard. After spraying Moe in the face with it Curly got vice grips on the nose treatment.
It does work, you just have to know where to aim it. The turkey baster works well also, just get one from the dollar store.
A universal fuel pump like this works also, self contained like this using a battery or just clip lead it to a car/tractor battery.20181023_152619.jpeg20181023_152608.jpeg
/ Rounded off drain plug #1,211
Right, however, the the picture that bigtiller posted is setup so the hose hooks to the barb under the nozzle and liquid is sucked into the hose by the venturi effect, then blown out the nozzle.
Aaron Z
/ Rounded off drain plug #1,212
Aaron Z
I didn’t notice that barb the first time around. Sorry you’re right. And probably a better idea than pressuring the case.
/ Rounded off drain plug #1,213
But what about the drain plug???
/ Rounded off drain plug #1,216
Update on the drain plug?
I plan on changing the engine oil in my JD450 dozer next pretty weekend. And I need to do service on my LS. Because I leave my old ISEKI outside all the time, I have to drain a little water out of the bottom of the transmission every few months. With the rain that we have had there may be more. One winter there was enough water that it froze. Pump could not pick up the oil. No lift to move hay that day. I had to wait for warmer weather to drain and put out hay. I tried to keep it drained after that. We almost never have weather that cold. Does any of our northern boys have problems with water in the hyd. oil freezing?
/ Rounded off drain plug #1,217
I run into condensation problems on customer tractors once in a while. Not very often though. If you have shift levers that go through the top of the transmission the best thing to do is make sure they are in good shape. No cracks or tares in the rubber boots as that is where rain gets into the transmission.
/ Rounded off drain plug #1,218
Yep. Keep in from getting in and you wont have to drain it out...
Aaron Z
/ Rounded off drain plug #1,219
Keep looking for update. I pulled my drain plugs without too much problems. No pipe wrench, just the right size socket.
/ Rounded off drain plug #1,220
If you tighten them too hard when you put them back in, you and Kando can have something in common. :thumbsup:
Sunflower Yard Art (A61569)
Sunflower Yard Art...
CORE CUT CC1200XL WALK-BEHIND SAW (A62129)
CORE CUT CC1200XL...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
300 GALLON FUEL TANK (A62131)
300 GALLON FUEL...
