Pallet fork overall width
/ Pallet fork overall width #1
mcfarmall
Kalamazoo, MI
Kubota M5660, Farmall C, JD 260 lawn tractor
I am adding fork pockets on a small genset skid that I'm building. I don't have a SSQA pallet fork attachment YET so I want to install the pockets to fit any set of factory built forks that I might be inclined to buy in the future.
The dimension I seek is the overall width outside to outside of the forks when they are set at their widest point. I'm not going to measure a pallet because pallet widths are all over the map, and with my luck I'd measure an oddball.
My plan is to get a variety of responses and then weld my pockets in place so as to accommodate the majority of the responses. Please limit your response to factory-built SSQA pallet forks that would be used on a typical 30-50 hp SCUT/CUT.
/ Pallet fork overall width #2
Most pallet forks will spread out to about 4' on center, but they do make "wide frame" forks too which go out to about 5' on center. I personally would think that if you set the fork pockets any where between 42" and 36" you would be safe.
/ Pallet fork overall width #3
Looking at the palletforks.com site, their non-adjustable width pallet forks use 4” wide forks at 24.75” on center.
Adjustable fork models can vary from 6” to 44” on center.
The fork pocket spacing on your project will need to be determined by the size and weight. If it will weight less than 1000 lbs and will be less than 60” wide with the center of gravity (COG) in the middle, then the 24.75” spacing should be fine and you should be able to move it with any possible set of forks you happen to purchase.
If your genset will be larger than that, or has a COG off to one side, then space them out as wide as needed to keep the COG as close to centered as you can, but don’t go wider than 44” on center.
/ Pallet fork overall width #4
Just measured mine, for what it's worth.
Factory built late 90's, name long gone from sticker.
44 1/2" max left outside of fork to right outside of fork. Forks themselves are 4" wide.
/ Pallet fork overall width #5
Just something to think about: When I have my forks set wide it is very difficult to see where the tips are from my operating position. When they are inside the loader frame, I can see them sitting down. Huge difference in the ability to slide the forks in and out of pockets.
/ Pallet fork overall width #6
I make them just a bit narrower than the widest position for some margin of error. BUT, now that I think about it. I have hydraulically adjustable forks, and if I made them the maximum distance, I could just spread them out all the way and know I am good. Same would apply even moreimportantly to manually adjustable forks.
Thanks for the replies, fellers. I will plan on spacing the pockets so the forks will measure 40" to the outside and that should have me covered for any pallet fork attachment that I will buy.
/ Pallet fork overall width #8
I never noticed, but in the background, there is another thing with fork pockets. A dolley to hold my 3ph ditch bank mower. The pockets were just pieces of angle and whatnot, but pockets should always be a tube for best safety.
My pockets are actually re-purposed fork extensions. Basically a long piece of channel. I cut them to length and will be welding them onto the bottom of the skid "upside down" so as to create a tube like structure so that my genset won't bounce off the forks if I encounter rough terrain. I'm bolting casters on the underside of the pockets so I can roll the unit around on the floor, then spear it with the forks through the pockets to load it on a trailer or whatever.
/ Pallet fork overall width #10
I built a frame out of 2" angle for my Miller Bobcat welder to sit in, with casters on the bottom so I can roll it around in the shop, or pick up it up with tractor forks. I've been over some extremely rough ground with it and never did it ever come close to coming off.....so pockets nay well be overkill.
Using the welder to build a tower at the top of my property.
enhance
enhance
enhance
Cool pictures, TnAndy and an awesome project! Pockets on my genset are a side bonus of the free fork extensions so I figured "Why not?" Just for fun, how wide do your forks measure outside to outside when they are at their maximum width? Merry Christmas!
/ Pallet fork overall width #12
44 1/2"
/ Pallet fork overall width #13
I just gots ta know! What's the tower for?
/ Pallet fork overall width #15
Yeah.....tower to get wireless internet into our valley. Now I get free 40mb service (compared to the blazing 528k DSL we used to get) plus enough tower rent to cover the property taxes on the place.
/ Pallet fork overall width #17
Curious on revenue. I too need a tower to get real internet in this hilly country but the best I have been offered to host an ISP is basically two free internet accounts. Not worth my time, electricity and possibly having to clear snow, plus the responsibility. Oh, plus, they provided no "out" clause. The agreement would have to be written into any sale of land! No way!
/ Pallet fork overall width #18
This deal started off in 2004, kinda casually with the ISP I had a dial up account with. They were starting to do some wireless and I contacted them as I own the highest elevation private pc of land in the county.
They came looked, said 'we need a road'.....so I built a mile of road up there. Then they provided the materials and some help, together we built the tower. We ran an electric line that runs 2300' down the side of the mountain to my shop (in a conduit laid on the ground) for power.
I got free internet was the only payment....which going from 56k dialup (DSL wasn't even available then) to a 10mb connection was worth it to me. Worked great for several years, then the ISP owner got off into other things and turned the business over to his son, who has run it in the ground, near as I can tell. Things would break down, I'd either fix them or it wouldn't get done, they never developed a customer base on this tower, etc, and finally one day they were history.
The tower sat unused from around 2009 to 2015 (we used phone co DSL which had become 'sorta' available.....528k on days it didn't rain or ants....literally....get in the phone boxes) when a small, local startup bunch contacted me about the tower. Given I'd heard nothing from the original bunch about it, and possession being 9/10's of the law, I figure it's mine....given the road I built, the labor I put in and letting it sit there for years. Scrap value of it wouldn't be worth the effort to get it.
So, we worked out a deal for them to use it. They spent a bunch on upgrading the tower, put a whole new, heavier section on the heavy 50' base part, all new radios/ant/etc and got a decent marketing plan going (they have 3-4 other towers locally now). I think these guys will make it, business wise.
So, going in, not to hit them too hard, I agreed to a 5 year, $1200/yr, with a 10% increase each following 5 yr renewals, plus my connection of 40mb is no charge. January starts the 3rd year.
I provide 10KWHrs/day of electric with that metered by a revenue grade meter on the line to the tower, anything in excess of that billed at the current commercial rates...which they haven't exceeded so far, though it is getting close now. Works out to 400 watts/hr, and the radios they use are not huge.
Last I knew of, they had around 100 customers on this tower, paying an average of $40-50/mo (I'm guessing based on their rate tier), so the rent isn't hitting them too hard....and I'm not trying to make a killing on the deal, just help me out some with property tax, and of course, a good, reliable, high speed (enough for me anyway....streaming Netflix is probably my biggest use) connection is the biggest deal. Considering I went from paying the phone company $720/yr for a crappy service to making $1200/yr, that's my kind of swing.
Building that tower was a royal pain, due to the location....the terrain is near straight up ( elevation changes from 2200' at my house to 3,000' on the top), the road had to go a long way around to even come close to getting up there, and so on.....just a big pain all the way around. IF you have a better access, throwing up a light weight Roan tower isn't a huge deal. You might consider it just for the connection until they get a customer base up, then renegotiate. I wouldn't consider the "agreement goes with the place" language though, they really would have nothing it it.
AND you might consider getting in the ISP business. From what I can tell with these guys, it ain't rocket science......were I a lot younger man, I'd do it. I don't know what their expenses, like the cost to hook into the Sprint fiber main line, but looks like a pretty fair potential for profit based on the gross numbers.
From the tower looking east, down on my farm, and valley I live in:
enhance
Looking back toward the west:
enhance
/ Pallet fork overall width #19
Thanks a lot for that very interesting information. What about insurance and does the municipality charge commercial rates for the site? I'm surprised that given the spot is the highest, that there were not VHF repeaters on site a long time ago. I too ran power over the ground on account of difficult terrain and pine trees.
I have an 80 foot tower on high ground that cost me peanuts, but I wonder, every ice or wind storm if it's gonna be there afterwards. Even finding one used, erection of a heavy 150-200 foot tower would cost 20K or so. Just no revenue model to support that, unfortunately. They always claim that the power is negligable, but I see it's really not.
I had a Ham friend who negotiated a large tower on a neighbors property through BELL Celular. They put up commercial VHF/UHF antennas and Heliax for him, and provided him power. Just so they could get on the site, without problems as he had a tower there already attached to the farmers silo. He never got anything in writing and he isn't even the owner. Now they say he owes them a ton of back RENT!
/ Pallet fork overall width #20
No insurance.....no municipality to charge anything....county doesn't pay it any attention as far as taxes.......things like that are pretty relaxed here/.
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
Arrowquip 8708L-EF8 Portable Cattle Chute (A64047)
Arrowquip...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
