MESSMAKER
Not sure what I need or how to mount. I guess It would need to be portable so I can pull in both directions. I am looking to avoid that once a year wrecker call that usually takes a couple hours and cost about $150.
You really aren't very clear about what you are looking for. Are you pulling your tractor out, other vehicles, or ????
Like Bob I have a 3pth winch that I use for pulling trees and the occasional small building. From your comment though I wonder if you are looking for something more like a Lewis winch, which is powered by your chainsaw.https://www.amazon.com/Powerhouse-L...5TTAZAMAZZK&psc=1&refRID=PWCKP6W3R5TTAZAMAZZK
Not sure what youre looking for but I got an Igland winch that mounts on the 3 pt hitch. It is capable of pulling about 8000 #, which is enough to pull my 3215 out of most tricky spots that I have been in. I like to keep it on in the winter for weight (580 #) or if I find myself stuck!
Is it some type of logging winch? 580lbs seems excessive for a winch.
I'm with you, Industrial Toys. But with a slight twist - I don't like being in a position where I need a winch.
Belzington - too true. A stuck vehicle without a winch, of some type, attached - - a real PITA(squared).
Want to know what stuck really is, go to youtube channels and look at some of the really big excavators and such with even the cab full of mud... This is stuck... Use "stuck excavators" as youtube search string...
Two Excavators in Deep **** - Heavy Recovery - Terribargarn, Sweden - YouTube
Dale
