Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,088
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
In Sept, I bought a Terrain King, hydraulically powered mower. This is nothing more than a 15' flexwing mower but, instead of being powered by shafts on the PTO, there is a closed loop pump hanging on the pto to power the blades.
At the hinge location for the wings (on BOTH sides of the hinge) is something like a 3x4 boxed section. You can't "see" this part as it's simply part of the construction of the mower assembly. None the less, each wing has two of these chambers and these chambers are most of the reservoir for holding the hydraulic oil. I think the factory calls these the cooling channels or something like that.
There is then a "box" on the front of the mower that would have (what you would otherwise think to be) the hydraulic reservoir sitting there.
Meaning.... if you want to change the fluid, you drain the 'front' reservoir of fluid....you think you are done but, you've only drained (guessing) five gallons out of the (guessing) 45 gallons that it holds since most of the volume is sitting in these cooling channels.
Hope that painted a picture that makes some sense.
Ok, just got done adding a schematic of mower. The squared sections near the hinges are the cooling chambers I'm speaking of.... it doesn't show the front reservoir.
Here's my question.... Evidently the hoses on these are REAL tight. Guy who welded something on it for me had to take one off. They had a six foot cheater and TWO people twisting on it to get it off.
I want to get as much oil OUT as I can so I can flush it.
If it uses 45 gallons, I'm simply NOT going to do a couple drain/refils..... so how do I siphon out.
What I'm trying to find is NOT a kerosene heater type siphon hose with a squeeze ball.....I have one of those.
What can I use that might pull hydraulic fluid out faster and still be controlled? (so when my 5-gallon bucket fills, I can control flow as I move to next pail)
Also.... how do I get the oil out of the cooling chambers if the hoses are that hard to remove?
I'm wondering if by lifting the wings, some of the fluid (in the wing half) will gravity feed to the chamber on the chassis.....and then maybe push its way to the reservoir on the front of the mower. I could use my backhoe to lift the front/back to try to then let that oil move forward.
From what I understand, they didn't make any drain plugs in the cooling chambers so I'm a bit perplexed on how to do a "good" drain job and not mix half new fluid with half old fluid.
Thoughts??
Thoughts??
