Rounded off drain plug
/ Rounded off drain plug #1,141
Would a baked potato work?
Not as well... I suggested the carrot because it is stronger than a potato... raw that is. If you are going to get into cooked vegetables then you need to factor in cooking time and preparation methods. :D
/ Rounded off drain plug #1,142
Okay then. What should Tractor Seabee use to grip the carrot?
/ Rounded off drain plug #1,146
/ Rounded off drain plug #1,147
Salt and pepper, with parsnips, carrots, winter squash, onions, garlic, taters and sweet taters, under a lamb roast...
completely unsuitable for bulb removal at that point, so it is best to hide the evidence.
/ Rounded off drain plug #1,148
Right, trick question. The answer is pipe wrench.
/ Rounded off drain plug #1,149
No, the answer is a 12" Knipex Cobra:
Sorry, don't have a broken light bulb base to get a picture of. :)
/ Rounded off drain plug #1,150
Just break a light bulb. Leave power on for special effects for pictures. We love pictures!
/ Rounded off drain plug #1,151
Stop me if you’ve heard this one: “ How many TBN’ers dos it take to unscrew a broken lightbulb?”
/ Rounded off drain plug #1,152
:laughing:
Evidently not enough yet.
/ Rounded off drain plug #1,155
Now that we have unsuccessfully unstuck a drain plug and a light bulb, does anyone have anything else that is stuck that we cannot agree how to unstick? :confused3:
/ Rounded off drain plug #1,156
I have a key stuck in a truck ignition. To make matters worse it won’t turn either.
/ Rounded off drain plug #1,157
How many fasteners and auxiliary panels/other components do you have to remover first to get at the switch to replace it? What's the flat rate manual time standard to do all that? Let's see my Ford dealer charges $110/hr for shop time.
Ron
/ Rounded off drain plug #1,158
Not very much since it’s a 90s ford but I don’t think the key cylinder is designed to be removed with a key in it. Edit it’s supposed to be removed with the key in it turned to the on position but the key won’t turn and it’s stuck in the ignition in the off position.
/ Rounded off drain plug #1,159
Not very much since it痴 a 90s ford but I don稚 think the key cylinder is designed to be removed with a key in it. Edit it痴 supposed to be removed with the key in it turned to the on position but the key won稚 turn and it痴 stuck in the ignition in the off position.
you probably have to push it in a tiny bit more. you can buy this. https://www.amazon.com/Extractor-Br...45199914&sr=8-2&keywords=broken+key+extractor or make one from a hacksaw blade by grinding, just be sure to keep the blade cool so you don't take the temper out!(grind,cool, repeat).. a hard steel wire with a hook on it can be tried too..
/ Rounded off drain plug #1,160
Break off the blank end of a very small scrollsaw blade, so pulling teeth are on the end. Slip it in beside the key, twist a bit to engage the teeth, then pull the key out.
Bruce
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2018 INTERNATIONAL LT625 T/A MID ROOF TRUCK TRACTOR (A59909)
2018 INTERNATIONAL...
INOP/NON-RUNNING 2000 Sterling L7500 Series Dump Truck, VIN # 2FZHAFBC2YAH48068 (A61165)
INOP/NON-RUNNING...
1952 Army Jeep M38 (A61166)
1952 Army Jeep M38...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A62130)
UNUSED SWICT 66"...
2026 Steel Pines Cargo 7x18 Enclosed Trailer, VIN#7FWBE1832T1036525 (A61166)
2026 Steel Pines...
