Rounded off drain plug
/ Rounded off drain plug #1,121
"\Wonder what the 1st prize is."
An all expense paid vacation to Cromwell Indiana to get that dam plug out.
Includes stay at the Shady Rest, lunch in Crabwell Corners near Pixley.
/ Rounded off drain plug #1,122
Expenses paid, but by who? :D
/ Rounded off drain plug #1,123
/ Rounded off drain plug #1,124
Kando, now that you have absorbed all these solutions I think you are the perfect solver of my similar problem. The work light on my drill press is broken and I can't budge that bulb base no matter what I try. Tried broom handle, channel locks, needle nose plies, collapsing the walls, super glue a dowel in there. Nothing works. Here is a picture. DSCN0018.JPG
Ron
/ Rounded off drain plug #1,125
Kando, now that you have absorbed all these solutions I think you are the perfect solver of my similar problem. The work light on my drill press is broken and I can't budge that bulb base no matter what I try. Tried broom handle, channel locks, needle nose plies, collapsing the walls, super glue a dowel in there. Nothing works. Here is a picture. View attachment 583295
Ron
Not enough remaining suitable material for a pipe wrench. :confused3:
/ Rounded off drain plug #1,127
Ron
You might try collapsing the light bulb socket and removing it. Or you could just cut the whole thing out and put a new light bulb base in for like $2.
/ Rounded off drain plug #1,128
I've taken several of those bases out with needle-nosed pliers, grabbing and twisting a side to shrink the base a bit.
But I don't think they will work on a rounded-off drain plug.
Bruce
/ Rounded off drain plug #1,129
Ron
Did you try using the needle-nose pliers like circlip pliers... open the needle-nose inside the screw base (on two inner sides) and twist?
And I take it that it is a screw in base, not a bayonet base. It looks like a screw base.
/ Rounded off drain plug #1,131
Naturally via the 'Go Fund Me' collection that will gather more donors than posters on this discussion (?).
Manufacturer of the tool that solves the problem! ???
As long as no Trump is involved there could be some funding left over for the winner.
/ Rounded off drain plug #1,132
jam a potato into the broken bulb socket. It should twist out.
/ Rounded off drain plug #1,133
Collapse the bulb base with a center punch or a small (1/4" or so) cold chisel in one spot until you have a large enough opening to get a needlenose jaw between the bulb and socket and collapse it some more? I am thinking using the needlenose sort of like a spam can key.
FWIW, I have heard of this happening more and more with bulbs galling in sockets, and at least one person suggested a small amount of oil smeared on the threads of every new bulb before installing.
/ Rounded off drain plug #1,134
What will the Army Corps of Engineers:flag-army: think if they hear a drain plug wupped a guy called Kando:m1helmet: then a light bulb stumped another called Seabee:flag-navy:? :stirthepot:
/ Rounded off drain plug #1,135
Aluminum bases in aluminum sockets.
Bruce
/ Rounded off drain plug #1,136
Some one please send me a PM when he finally gets the plug out.
/ Rounded off drain plug #1,137
Nope!
NO PM's!
You gotta stick this one out to find out!
This started way back when I was 77.
Now I am 78!
Sure hope I make it.
/ Rounded off drain plug #1,138
Nope!
NO PM's!
Now I am 78!
Awwww come on man!.... I got a tractor to rebuild.
2020 International LT625 Sleeper 48 (A62613)
2020 International...
Case 586H 4wd Off road forklift (A63118)
Case 586H 4wd Off...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
Kubota SVL75-2 (A62180)
Kubota SVL75-2...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
