Is there a Vertical grapple type attachment?
/ Is there a Vertical grapple type attachment? #1
MikeR 2018
Central Pa
Kioti CK2610 HST with FEL, Rotary Cutter, Box Blade and HLA Grapple
I love my grapple. It has so many uses but, sometimes I find myself wishing for a grabber that is at right angles to the grapple. I want to grab something that is vertical, rather than horizontal. Is there such a thing?
/ Is there a Vertical grapple type attachment? #3
I read a couple posts here on TBN about a grapple with a gimbal head. Could rotate from H to V. I think it was on a unit like Xfaxman has - a telehandler. You could send a PM to him.
/ Is there a Vertical grapple type attachment? #4
Mine is a long arm tree puller, vertical only, does not rotate:
What do you want to use it on?
This is a post grapple:
/ Is there a Vertical grapple type attachment? #5
Well - JMHO, but if Xfaxman doesn't know of it - it must be extremely unique, rare or non-existent. However - I pondered further. I think it was one of those tracked forestry fellers/buncher machines. Grab the tree when vertical, cut it off at the base - slowly rotate and lower the tree to a horizontal position.
Not a piece of homeowner equipment. However, if you want to see one - - John Deere 955M Feller Buncher
That vertical tree puller of yours - Xfaxman - is a real nut cracker. You are able to reach out and simply pull big trees right out of the ground?? That represents a lot of brute power.
/ Is there a Vertical grapple type attachment? #6
/ Is there a Vertical grapple type attachment? #7
Yep, over 6,000 pounds of lift and 7,000 pounds of push/pull, plus the boom extension force that I haven't measured.
Clamp on the tree trunk, raise up, curl down, extend the boom moving forward, then still pulling up, curl up in reverse, retract the boom and out it comes:
Here it is pulling 2 for 1: Tree Puller?
/ Is there a Vertical grapple type attachment? #8
This guy uses his vert grapple to pick up logs with his toolcat (ssqa).
Well, after reading all these posts, I realize that I am probably asking for something that is much more than I need. Upon further thought, I realize that all I really need is to pull fence posts – T-Posts and wood posts. I see other threads about post pullers. I’ll try one of those.
/ Is there a Vertical grapple type attachment? #10
a 5/8 thick piece of flat with a hole in it attached to a piece of chain used with a fel will pull post . you could even bolt it directly to a bucket and pull post without ever leaving the seat
/ Is there a Vertical grapple type attachment? #11
Three point has a lot more power for pulling fence post;draw bar and chain should work.
/ Is there a Vertical grapple type attachment? #12
Two people using a choker chain or strap can pull lots of posts in a day. Some of my wood posts rot off at ground level so then I dig down to good wood and choke a strap on the buried part of the post. I may even use the high lift jack to pull a post using that same choker strap.
/ Is there a Vertical grapple type attachment? #13
Rotating quick attach. Would be nice if someone produced a manual one that you could pin or bolt into the vertical position.
/ Is there a Vertical grapple type attachment? #14
Ditto. That would be sweet!
/ Is there a Vertical grapple type attachment? #15
Just weld an SSQA plate to an SSQA adapter (Universal Mini Skid Steer Adapter Plate) 90 degrees from each other. WHEN you need it rotated, get the adapter.
Though, you'd most certainly need some sort of hoist or another tractor to get things lifted/situated where you'd need it. Or a tractor-anti-gravity device (rotate the tractor on its side).
aaah well, nevermind.
/ Is there a Vertical grapple type attachment? #16
They make articulated grapples.
Look up Gator grapples- they are expensive.
/ Is there a Vertical grapple type attachment? #17
This vertical grapple flattened 30 acres on my place this spring,, in nothing flat,,
It could cut and lay down a 22" diameter, 150 foot tall tree,,,
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
