Oil & Fuel Tc-35 Major oil blow/blow by out problem, from soft over flow tube on top of engine.
   / Tc-35 Major oil blow/blow by out problem, from soft over flow tube on top of engine. #21
Sorry I have not replied in a timely fashion. I will check to see if it is hydraulic oil or diesel. I took a sample to a diesel mechanic and he smelt it and told me it was not diesel/oil mix?
I will see if I can get conclusive evidence. Where would this be coming from if it is hydraulic?
Thank you for all your kindnesses!
Kind Regards,
Steve
The hdy pump is powered by the engine. I think it is a gear connection. The pump leaks into the engine at the spot it is mounted onto.
   / Tc-35 Major oil blow/blow by out problem, from soft over flow tube on top of engine. #22
On my tractor TN95A
The high-pressure system pump mounts on the right-hand side of the engine. It is a fixed displacement, open-center, gear type pump driven by the engine timing gear.
When operating orbital motors or front-end loaders, it is desirable to use a factory installed optional 64 1/m (16.9 g/m) 16.9 g/m pump on tractors with a mechanical shuttle transmission, which will include the installation of an oil cooler.
The type of hydraulic pump installed in each system depends on the configuration of the tractor, and the transmission.
   / Tc-35 Major oil blow/blow by out problem, from soft over flow tube on top of engine. #23
In other words.. follow the hydro lines & find the pump.. IF its mounted outside the engine & is gear driven..
The seal that holds the fluid inside the little box might have ruptured..?? & filling your engine oil w/ hydro. fluid.
Its easy to check but requires the pump to be pulled away from the engine..or removed..
Just blow air into 1 side while blocking off the other..
OR pull it back far enough to see the gear/seal & run the machine..
I'm not familiar w/ that machine so I don't know if that's possible.??
Check your workshop manual.. & if u say, I don't have 1.. GET ONE..they're worth their weight in gold..{hydro. fluid} lol
Hi thclimer,
Thank you, thank you, thank you! That is exactly what I needed, and from Jinman too. I sure miss him. He probably would have been all over my post if he was still around. Many thanks to all who responded to this matter. I will keep you posted on the outcome of all of this.
Thank you kindly! All of you!
Kind Regards,
Steve
   / Tc-35 Major oil blow/blow by out problem, from soft over flow tube on top of engine. #26
Yes Jinman is clearly missed, he had great insight at troubleshooting.
Hope its not too difficult for you to have your hydraulic pump rebuilt.
Hi TheClimer,
Thanks again for the specific information you sent. It got me over a tough row to hoe with all the other stuff going on here. I will be getting to it soon.
Sincerely appreciative!
Kind Regards,
Steve
   / Tc-35 Major oil blow/blow by out problem, from soft over flow tube on top of engine. #28
Those gear pumps are super simple to rebuild as long as the metal parts are in good shape.
Usually an overpressure at some point blows the o-rings. After you get it rebuilt check the relief pressure on your system.
Thank you DwayneB I appreciate the info!
Kind Regards,
Steve
Hi Dwayne,
I got the pump out. There is only one seal? Jinman mentions 2 seals? Where can I find the squared off o-rings? Does anyone have an exploded view/ schematic of the pump? Much appreciation in advance!
Kind Regar5ds,
Steve
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
CLUB CAR (A55758)
CLUB CAR (A55758)
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
