Mold in sprayer
/ Mold in sprayer #1
ironpen
Gold Member
Montgomery, Alabama
tn75s, tc33d, mc35, gt65, 6640, 3010s, TS110, TS115, TN70, Massey 5470, Kubota F2690
I've got what looks like some green mold inside my sprayer. Don't know why it's there. Would Chlorox harm my pump if I put some in the sprayer?? Any other thoughts on how to get rid of it?? TIA
/ Mold in sprayer #2
Don’t know what kind of sprayer you have but I run bleach through mine a few times a year and have no issues. I also flush it with water after every use.
/ Mold in sprayer #3
If you have viton seals your pump should be ok. Rinse with clear water. However most weed killers or fertilizers will kill mold at spray able mix levels.
/ Mold in sprayer #4
If I leave weed killer in my sprayer over a month to so; It gets some type of mold or algae in it that cogs everything up. I then run bleach though it and everything works fine and is back to normal. Before cold weather I run a little bit of pink RV antifreeze though it, so the pump and valve don't freeze and bust.
/ Mold in sprayer #5
I use the outdoor cleaning bleach. It's a lot stronger and will ruin your clothes if you get any on you, but I really like how quickly it works.
/ Mold in sprayer
I clean it thoroughly after each use. I'm a little nervous about running bleach through it (Seals??), so I was looking for a bleach alternative. Thanks for all the replies thus far.
/ Mold in sprayer #7
Im getting same thing in my roundup tank.
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
429835 (A61166)
429835 (A61166)
Fork Extensions (A61572)
Fork Extensions...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
