Moving small bales - bad back
/ Moving small bales - bad back #1
TheMan419
Indiana
New Holland Boomer 24
So life/age are catching up to me. I have a bulging disk in my back.
We own a small horse operation. Seven horses. Currently have about 1200 small square bales of hay in inventory. We move bales from storage to the stall barn such that we have week's supply or so on hand.
Currently we simply stack them on the FEL and move them that way. Easy for me to do and I can load my little tractor with 9 or 10 bales.
With my back as it is I cannot do that any more. So option A would be to have SWMBO do it. You can all imagine the risk/reward there.
What about using Bucket Hay Bale Spear Attachment With 49 Inch Long Spear | Neat Attachments | Bale Handling Attachments | Neat Farms and spearing the small bales? I could then move them to the stall barn. SWMBO would have to stack them there, but it eliminates her handling them one time.
Of course that spear weigh's 85 pounds. I could build a stand to put it on so I could drive up to it and slide the cutting edge of the bucket in place and then just have to attach the turnbuckle. No need to lift it in place.
My question is if that is just going to obliterate the small squares. They are stacked in such a way that some of them I would spear down the long side and some I would spear down the short side.
Any thoughts?
/ Moving small bales - bad back #2
I don't think a (~2") spear should obliterate them
Are you going to spear and move one at a time?
I'd think a grapple, or forks with a couple top grapple thumbs would be better for lifting/grabbing more than one bale.
Small square bales aren't really adaptable to automation/ non-labor intensive methods like round or large square bales. I think that's the point of round and large square bales.
/ Moving small bales - bad back #3
I have seen an attachment to move 8 bales at a time, set in 2 by 4 layout. My hay guy almost never touches a bale by hand. But bales mostly small bales. Not knowing what equipment you have, Coby may be right about the grapple. How many to move at a time and distance to move them?
/ Moving small bales - bad back #4
/ Moving small bales - bad back #6
If they are already stacked I would be thinking about moving a whole layer or part of a layer into a wagon. Then at the other end reverse the process. Store them on a shelf where you can slide or push them into the feeder without lifting them.
I would use a trolley hoist at each end to move the bales into and out of the wagon. Maybe something like: https://www.amazon.com/Jervis-Webb-Trolley-Capacity-Included/dp/B01NBIWUNM/
The other thing you'd need is some sort of rack that you lay down on top of a layer of bales, attach each bale, and then lift the rack and put it in the wagon. I think the best way to pick up bales would be by the twine, so the rack would have a bunch of clips on the bottom. You lay the rack on top of the stack, go around and hook each bale by the twine, then hoist the whole rack into the wagon. Leave the rack on and use it at the other end to unload. If you need to do more than one rack per trip just have multiple racks.
You don't say how many bales per week you need or how big your stack is. If' you're moving 9 at a time now you could do that with a lawn tractor cart, you don't need anything fancy.
This is how hay used to be put up before there were balers. They'd have a beam running the length of the barn and out one end. They'd lower a giant claw into a wagon, which would pick up a load of hay, then hoist it up into the barn and across the hay mow.
/ Moving small bales - bad back #7
I have a Kuhn’s 8 bale handler for the front of my L6060 and it works well for storing but not as nice for removing. I can’t really spear a bale - my spears tend to push them away before the spear goes in far enough to handle.
/ Moving small bales - bad back #8
How far apart are the storage and stall barns? Who loads the storage barn? Can you move storage to the stall mow? I have 3 bulged disks and the haying actually helps because it strengthens my back muscles to support my spine. However, NEVER lift and twist while loading or unloading hay. It's also going to eventually hurt your knees.
If you are set against manual bale movement, then co-location of long term and short term storage and feeding has to be on the agenda. What about putting 1 or more shipping container(s) next to the stall barn with appropriate access and ventilation. You can put 400+ bales in a 40' unit (as described on a few horse forums). Your hay supplier could even deliver hay already loaded in a container or semi-trailer. There are a few horse operations around here who do this. Drop off a full load, take away an empty.
I use a horizontal transport elevator in addition to an upload elevator to move hay around for loading and unloading. Motors run both directions so the lifting is minimized. I feed off the end of the mow into bunk feeders so I just need to roll square bales into the transport (and remember to open the sliding screen patio type door).
I suppose pallet stacking could be done, too, with some bucket forks.
So to answer a few of the questions in this thread....
The tractor is listed in my profile.... NH Boomer 24. The bucket is NOT quick detach.
Stall barn is like 100 ft from the hay storage barn.
Currently the hay guy brings his skid steer to stack. He uses the kuhns 10 bale graple. String side is down. I am not sure my tractor could lift 10 bales and the grapple even if it were a quick detach bucket.
I need to move about 21 bales a week give or take in the winter. Less in the seasons when the paddocks are green with forage.
I am not dead set against manually moving them. The problem is right now I cannot do so due to my back. Going to see the dr today for further answers. I am sure a bunch of physical therapy is in my future. So it may be several months before I am able to do it.
So ultimately this is one more thing SWMBO has to take on and I am trying to minimize that for her.
Frankly if I could only move one small bale at a time with a spear I would make the 21 trips between the two barns and git er done. It is not that far so as to make that an annoyance. If I had the capacity to use the same grapple as my hay supplier I would look long long long and hard at doing that. However it seems cost prohibitive at this point.
One easy thought I started in another thread was just to get a carry all for the 3 point hitch. Build a platform for it. Then SWMBO can more easily stack hay on that for transport. While it does not cut down on the manual labor part of things it at least makes part of the job easier. Plus the carry all is under $200 so if it is not useful I don't feel like I have wasted a bunch of money.
The square bale spear is an interesting idea. While the one two bit linked to would likely not work there are bucket mounted versions. Seems like that would at least let me grab two bales at a time. Maybe 3 if I was hitting the short side. Could probably even grab them such that you were taking two layers and thus have 4 or 6 bales at a time.
Thanks for all the thoughts. Getting older is no fun!
/ Moving small bales - bad back #11
We move 4 bales a day from three different barn locations during the season with atv or riding mower and either utility cart (2x2) or the spreader (again 2x2) hooked behind.
100' downhill or uphill? Downhill can be pulled by hand. This is the cart we have with dual use handle .......... Gorilla Carts 1 cu. ft. Heavy-Duty Poly Dump Cart at Tractor Supply Co.
/ Moving small bales - bad back #12
It's for this very reason that we went to round bales 10 years ago.
I also have far more back fusions than I'd care to relate but suffice it to say that a 5-6 ft round bale
strategically placed in each paddock has relieved me of haying duties for days on end.
Small square bales are far too time consuming.
Even if I could tote them around but there was a time years ago.....
Can I get a witness? :laughing:
/ Moving small bales - bad back #13
Titan has a nice clamp on spear that has 2 smaller stabilizer spears. I can't link the darn thing. They are $260. Looks like another option.
/ Moving small bales - bad back #14
I don't know if you wife is experienced around tractors or equipment. Just a reminder to discuss safety aspects of tractor operation and put them in practice. If she is not as familiar with equipment as you are, you may know of certain risks or safety hazards that she does not.
/ Moving small bales - bad back #15
I like the idea of a grapple if you can find one that work's without breaking the bales. Maybe have a hydraulic operated claw adapted to the fel bucket. Can you offer lunch once a week to an able bodied individual in exchange for them stacking 21 bales on as many pallets as required? You could then use bucket forks or 3 point forks to move pallets as needed.That is better than a carry-all since swmbo would only need to handle bales once as she feed's them.
/ Moving small bales - bad back #16
In my experience, the best way to move square bales without mangling them is to lift by the strings. This hay grapple has hooks to grab the bales:
You can read about it here: Hay Grapple | Parrish Agriturf | Farm Equipment
I haven't ever used it, I just saw their ad.
Now the poor man's version is you get off and hook the strings yourself. For one or two bales at a time, just attach a couple snaplinks to your bucket somehow and clip them onto the strings. For bigger loads, I think what I would do is put a pointy end on a bunch of rods, and run the rods through several bales and under the string. Then figure out a way to join the rods together and lift the whole load. I think maybe a 2x4 with holes drilled in it for the rods to go into at each end of the load would do it. I suspect that manually hooking the bales wouldn't take that much longer than having a grapple, it can be frustrating precisely locating an implement that's way out in front of your tractor, especially if you're working in close quarters.
The reason I'm thinking low-tech is that once you use up the 1200 bales you have in stock, you really should look at round bales or large squares. Pound for pound they're much easier to handle with equipment.
/ Moving small bales - bad back #17
Specialty Grabbers | Kuhns Mfg LLC | North Bloomfield, OH
I have the small 205 model that your tractor can handle. This will make your work a breeze, It does not matter what the string orientation is. Also you never want to lift by the strings as that leads to busted bales. You will need to get a quick attach plate fitted to you tractor. The initial cost will pay fro itself as there is a world of attachments you can get later. Also give Kuhn a call as they can custom fit these - great customer service
/ Moving small bales - bad back #18
I'm not to keen on what to do with the spearer or otherwise but you mention trouble with your back. Something you may need to consider is a suspension seat for the tractor in lieu of your present seat. From the pix I've seen of your tractor on line its basically the same as mine. It has two heavy duty springs under it for suspenion which you know the tractor has no suspension so you get all the bump amd bounce up through you back. I'm changing mine soon. In addition to my tractor I have a 52 inch zero turn bobcat lawnmower. It too had the spring suspension, it was killing me. I had neck surgery about 5 or 6 years ago and fused my c3 and c4. Worked good, but the mower reminded me i need to protect the work done. I wound up buying a suspension seat from bobcat, it's been my salvation. You adjust the seat to your weight and it works great for a heavy set like me or when my grandson runs the ower he dials it down accordingly.
Any chance you have a link to this? Yeah there is zero suspension. I think the two little springs under the seat have an inch of travel if that much......
She is not, but she is very very careful when the tractor is running. Overly so in my mind, but I won't tell her that because that is a heck of a lot better than the other option.....
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2017 FREIGHTLINER...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2008 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2008 Stertil Koni...
