Front Loader from a Ford Truck
/ Front Loader from a Ford Truck #101
Nimble, I think the idea of making a loader out of whatever is just great! Go for it! Great project.... And when you get it done, do with it as you want. You're going to learn a ton no matter what the finished project looks like.
It doesn't hurt to listen to the "nay sayers", but don't let them stop you. If you want to protect yourself that's fine, but I'd say to just go ahead and do what you know you can do.
Advice is cheap, so here's some cheap advice from an old, old mechanic: Protecting yourself in some minimal way makes sense, but keep in mind that when troubles come your way - and they will - they tend to come from a direction you never anticipated anyway. It's way too easy to be so concerned with anticipating problems that you end up spending your life doing not much at all.
So pay attention to what you can do and let the rest work itself out.
good luck,
rScotty
And lastly, here's something I found written on the inside of an outhouse door at the top of a 14,000 foot mountain peak many years ago,
"If you are working for someone... and you think you are smarter than they are..... You're wrong."
/ Front Loader from a Ford Truck #102
IMO, if you continue with the build, build it do what you want/need it to do. Use, break, fix, re-design, repeat. Then if you have close friends or family that have similar needs you could rent it to them, or what I would do is offer to perform the work because your limited budget is going to lead to compromises in safety, reliability, and intuitive operation that equipment manufacturers spend a lot of time and money developing.
good luck,
rScotty
No one's suggesting he not build it. It would be fun and educational.
But let's face it, it's going to be a one of a kind machine that will not excel over something that someone can rent at a rental yard and be covered by insurance.
/ Front Loader from a Ford Truck #103
I have a complete JD-1 Loader attachment from a 1953 John Deere 40 Crawler. I've often thought of mounting it on my '77 Intl. Traveler frame. Would be easy to do and would be helpful around the homestead. It would never leave the property.
/ Front Loader from a Ford Truck #104
I’ve got the loader off a old case backhoe that could be someone else’s at a good price if they wanted to attempt such a project.
/ Front Loader from a Ford Truck #107
In saying "let's face it", you are arguing that your own opinions are universal, correct, and absolute. That's your right, but I've got a different opinion. I don't want to be offensive, but I tend to disagree with absolutism in any form.
If excellence is the goal, I don't see any reason why a one of a kind machine cannot excel over a mass-produced version. I'll admit that the odds are against it, and that such machines may be less common today than in times past, but that doesn't mean it isn't possible.
As for the need for specialized insurance... I've heard it before, and it sounds like an urban rumor to me. I'll leave it up to you to deduce what group or groups would benefit from promoting such an idea.
The legal angle seems to be similar to the danger of being hit by a meteorite. The risk may be real, but it is also very small and quite rare. Call me a risk-taker if you wish; it may even be accurate. I simply believe that some risks are worth the reward.
rScotty
/ Front Loader from a Ford Truck #108
rScotty
You must be talking about my one of a kind machine that I put together 13 years ago. :thumbsup:
For those that have not seen it, here it is with the 42" wide bucket full of dirt:
And some weird color rock:
And the 4' wide box blade:
And the 54" wide brush forks:
Click the link below \/ for more info.
/ Front Loader from a Ford Truck #109
Would you ever rent it out?
That's how older skid steers used to be configured. No operator cage to keep them from putting their head, neck, limbs or trunk into the loader arms. I recall injuries, deaths, and lawsuits because of that.
/ Front Loader from a Ford Truck #110
No I would never rent it out. I am the only one to have ever driven it.
I thought about adding a rollover bar like this one, to the loader uprights, but never got a roundtuit.
/ Front Loader from a Ford Truck #111
Excellence was never the goal. When OP started this endeavor, his target build cost was $2000. It sounds like he is well over half spent already and has a long way to go.
https://www.tractorbynet.com/forums/projects/393034-build-buy-skid-steer-wide.html
Even with double the budget I still don't see this turning into something that would work well enough or long enough that someone would pay to rent for more than beer money. Maybe moving mulch or other motorized wheelbarrow tasks, but not leveling a lot as was the original goal.
I will reiterate that I'm here to watch the progress and provide advice/motivation/feedback/criticism since I like these types of projects. For some people, sometimes it's more about the journey than the destination. I'm one of those people.
/ Front Loader from a Ford Truck #114
I don’t think this whole deal is very smart aside from the enjoyment of buildings it part. Renting it is an insane idea and it’s almost certainly less useful than a commercial built machine and buying a commercial built machine is probably more money upfront but it retains its value a lot better. If you’re building this for the enjoyment of doing so than proceed. I understand the desire. If you’re building this from a financial standpoint you better re evaluate.
/ Front Loader from a Ford Truck #115
Back in the 60s when I was growing up, Pa built a hay stacker from an old military truck. He took the body off and set it up to have the loader part over the rear, driving it backwards just like you are describing... It worked great and was set up to handle (8) 100lb bales. The baler had an "accumulator" on it that collected 8 bales (2 bales x 4 bales) and dropped them together. Then the homemade stacker would run around the field, picking up a set of 8 bales, then taking them to haystack and stacking them up to 12' high or so... BTW, Pa had degree in mechanical engineering so he figured all the loads and such out... he was very fast with the slide rule and could make most anything.
It is doable, I would not suggest renting it just due to the lawyers that chase everything.
/ Front Loader from a Ford Truck #116
I agree with Moss and 4570, fun little project, could be really cool looking & working, but not a good idea to rent it!
I had some similar ideas a few years ago for a small yard loader like a Waldon. I would use the back half of two pick ups and cut/join the frames with a pivot for articulation. Pivot the rear axle for oscillation too. Double T cases and as low of a gear I could get in the rears. SSQA so that
All sounded really fun until I started estimating the number of hours needed to put it together. And at least an attempt of high quality (to post on TBN!). Needles to say, I've put it off for a retirement project in 20-25 years.
A quick search indicates liability insurance covering 1 million costs about $100-$200/month.
So that is not a big expense if you are renting stuff at $1000/month
and a mini-skidsteer rental is $250/day.
Obviously I'd spend the time to get exact figures before starting a business renting equipment.
You might also know I built a safety warning system for race cars, wow think of the liability!! Heck, farmers selling food people EAT? They can die from that!
/ Front Loader from a Ford Truck #118
First of I seriously doubt you’ll be able to rent that for $1000 a month. And I doubt the insurance company will insure such an idea, but I’m not an insurance agent so you should ask them. Both of your analogy’s are poor. I’m no lawyer either but you’ll almost certainly loose if someone gets hurt on this thing every if it wasn’t a fault of your design.
/ Front Loader from a Ford Truck #119
You found liability insurance that covers a home made machine for rental to the public?
/ Front Loader from a Ford Truck #120
Getting back to the technical aspects...
Using reverse as the only "forward" gear probably isn't going to work very well. Assuming 29" tires, 3.55:1 axle ratio, 3.5:1 or so low range in the transfer case, and 3.4:1 reverse gear, you're looking at 2154 engine RPMs to travel 4.4 MPH. I used 4.4 MPH because that is the max speed of my 4400 HST in "A" range that I use most of the time when digging. Our soil is fairly soft with mostly sand/silt and few rocks so not particularly difficult to dig. I'd imagine the torque curve of your 4 banger drops fairly quickly below 2000 RPM, so would have to slip the clutch to keep from stalling.
If you added a second transfer case or transmission that would give you more reduction and more than one ratio to choose from.
It sounds like you're well on your way to spending your $2000 budget...
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
JOHN DEERE 7930 TRACTOR (A64280)
JOHN DEERE 7930...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
2022 John Deere RD40F Draper Head (A63111)
2022 John Deere...
2017 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2017 Takeuchi...
