Chainsaw Sizing
/ Chainsaw Sizing #1
Olympus
Cape Girardeau, MO
LS R3039
Fellas, I’m thinking about upgrading chainsaws but I have very little knowledge about what might be “right” for me. Right now, I have 2 saws for different purposes and that system seems to work well though I’m not entirely happy about my saws that I currently have.
One saw is small and lightweight and I use it around the house property (6 acres) for pruning limbs and cutting up down limbs. I also use it at my hunting property for keeping ATV trails cut back from growing in and also for cutting shooting lanes and stuff for new deer stand locations and such. About 7 years ago I bought a Stihl MS 170 and like the size and weight, but the dang chain gets dull almost immediately. I keep it out of the dirt, no rocks, but still I’m constantly trying to keep it sharp. I’m at a point now where the bar needs replaced and I’m wondering if I should just get a new saw altogether and keep this as a backup.
I had a few mature trees fall at my home property and quickly realized the MS 170 was way to small to be cutting up whole mature trees for firewood. So at the time, money was tight and I needed a bigger saw so I bought a Poulan Pro 18” and used it to cut up the big trees. I noticed immediately that the chain stays sharper for a lot longer and I’ve not had any problems aside from it being harder to start than the Stihl. It seems to have plenty of power for what I’ve used it for, but does feel a little cheaper than other brands.
I definitely use the smaller saw way more though. So I guess first question is whether I should stay with my 2-saw system or just get one good quality saw. Second question would be what should I buy to replace my MS 170 with first and then later replace the Poulan with? First priority is really doing something about the MS 170. Aside from being easy to start and being lighter weight, it’s a pain to keep sharp.
/ Chainsaw Sizing #2
I have a Stihl MS180 that I use in the apple orchard all the time. I use a hand saw a lot for pruning but for bucking downed trees or limbs the Stihl is fine. Also have a Stihl 029 and pole saw too.
Don稚 know why you cant keep the chain sharp, no such trouble here.
/ Chainsaw Sizing #3
Doing the same work, a large saw will stay sharp longer than a small saw. Why? There is more chain and it typically has a larger, more aggressive tooth. Other problems could be a chain that has been over ground when sharpened or just a poor quality chain.
Having two saws is kind of normal. I have a 14" and a 20" and that seems a good spread for me. I don't do that much cutting (maybe 3 cords a year) so mine are cheap - Poulans. You have to be a little careful in how you start them, but otherwise I've been happy with them. The small one is close to 20 years old and about to be retired - it's so old it doesn't have a chain brake. When I replace it I may go battery.
/ Chainsaw Sizing #4
Your age? As strength ebbs it becomes more difficult to use a chainsaw safely.
One saw is small and lightweight and I use it around the house property (6 acres) for pruning limbs and cutting up down limbs. I also use it at my hunting property for keeping ATV trails cut back.
Consider a battery powered reciprocating saw (Sawzall) to replace your smaller saw. Nine inch blades are cheap, easy to replace on the saw and last a long time. I have a seven year old 18 volt Milwaukee Sawzall but I will replace it soon with a 36 volt Makita reciprocating saw. ( I am tired out before a Sawzall battery charge is depleted.)
Size your larger saw so most of the bar is in the wood, most of the time. Better a more powerful saw with this length bar, than a less powerful saw. Once some significant part of the bar is out of the wood, control becomes a problem.
Are you purchasing Stihl made-in-Switzerland saw chains?
/ Chainsaw Sizing #5
I've got 4 or so saws that we clear trails with, so these units get used much each summer. What we do, might not be Olympus would like to. Among these, I got a small Stihl which I've not fired up in years. I've also got a MS260 Stihl which is among there pro saws, but not that large of a CC machine. We tend do go light weight since they are commonly carried into the field. The 2 pole saws constitute 95% of sawing we need to do in the field... If we could only own one saw, it would be this type.
/ Chainsaw Sizing #6
I like a small saw for cutting limbs at my place and branches for shooting lanes at my deer lease. I think I paid 69 dollars about 8 years back or so for a refurbished Homelite 14 inch bar. Pretty sure I've changed it to a 16 inch bar. This cheap saw starts every time on second pull. I've never done anything to it. Its had a hard life. Can't complain.
I have a 291 Stihl for bigger stuff but it doesn't take 24 inch bar saw to cut a tree branch. I've been known to cut a pine tree or two my pole saw also!!!. Got to have a pole saw also. Cheap attachment that fits on a weed eater works plenty good for home use.
/ Chainsaw Sizing
I’m 35 years old if that matters.
I had a Poulan Pro pole saw and that thing was super handy but couldn’t keep it running. Ran good as long as it was running wide open. Let off the throttle and it would die. I have found that extended handle loppers work just as good for what I used the pole saw for.
But I either need two size saws or one good saw with 2 different size bars. Would probably be buying Stihl whatever I decide to go with.
/ Chainsaw Sizing #8
possibly the oil delivery is too low.. or perhaps improper bar oil?. Stihl is used by pro's for a few good reasons. Poulan is junk, Craftsman chain saws are Poulan saws rebadged!..
/ Chainsaw Sizing
It’s the factory bar and Stihl brand chain. The MS 170 is the smallest model Stihl makes. It’s far from professional grade.
/ Chainsaw Sizing #10
I have the MS 241, great saw but pricey. I have 45 acres of trees, so it gets a bunch of use. Great balance of weight and power..also starts very easily. And I am at 9000 ft.
16 inch bar.
/ Chainsaw Sizing #11
I ended up being a "Stihl guy" somehow, just never had a Husky or Dolmar/Makita, pretty much the only commercial duty saws made anymore. Recently after reading some great reviews by fellas that are real saw snob's* (see the above saw's) and wanted a smaller, lighter saw than my 70cc range of "pro" saws that I've been running for 20+ years and ended up buying a new Echo cs 490. It's about 50cc's and starts and operates just as well as my Stihl's and is backed up by a great warranty, out the door for about $350. Imho, any one of the above saws should last you for 20 years +, just use good 2 stroke mix that has a fuel stabilizer (for the ethanol). Buy the saw by the size of the engine (cc's) you need to fill a gap or up size from your current list. Poulan used to be something in the day. Those days were a long time ago and now seem only to make throw away "consumer" saws and not to mention no local serious service shops. Keep in mind bar lengths are only a sales pitch for the un informed "consumer". There is a ratio between cc's and what size bar it can pull in what type of wood (hardwood/softwood). Even on some of my larger saw's I'll only run a 18" bar to be less cumbersome limbing up.
* not really snob's, but the guy's that buy a $1200 saw then hot rod it with muffler mod's & tuning to be satisfied.
/ Chainsaw Sizing #12
30 years ago we had just bought an adjoining 10 acres. We had it aggressively logged and there was lots of cleanup to do. We were visited by an arborist who lent me his Husqvarna 268XP with 18" bar. I had used various saws over the years, and was totally blown away by the saw. I used it for about a year when I felt I really needed to return it, and bought my own. This was in the days when I was buying 20 year old cars for $1000-2000, and I paid over $700 for the saw.
I still have it, and it still is a beast. I did have the top end rebuilt once, but it is a real winner in my book.
Getting back to your question, I do think that having one small and one larger saw is a good idea. I only have the one - while I do have a pole saw attachment for my Stihl trimmer. For more normal sawing operations I will use a battery powered "sawzall" or just a handsaw. the 268 is relatively light, but if you are doing a lot of small stuff it does get heavy after a while.
/ Chainsaw Sizing #13
My MS1xx was stolen (can't remember but it was the predecessor to the 170) ..... so I bought a $650 Stihl MS201 pro limbing saw. Boy was I misled. The $330 Stihl 1xx started every time with one pull, but the MS201 ALWAYS took 3-4 pulls. And didn't have much more power. So I hot-rodded it. Now it's loud, and faster, and starts in 1-2 pulls. Still not as easy as the MS1xx and arguably not twice the saw. But I get respect, nobody knocks my MS201 (except the Husqv guys laugh at all the rope pulls).
Then I bought a Makita 36v top-handle electric saw ($169) and am very happy. I can't remember the last time I started the Stihl. I have some pretty big firewood decks of 4-6" firs, so it's just incidental that I can always get what I need with electric. If I had to fell trees I'd have to start the gas saw but in the last year since I got the Makita, it just doesn't happen. And I have a Stihl 028 with an (oversized) 24" bar too. It should have 20".
Well anyway, the bigger the saw the more you have to carry around. If you cut for hours, bigger will be faster. If you cut a few logs then shut down, smaller/lighter is better. If you are maintaining trails etc, there is absolutely NO QUESTION that battery/electric is superior. You don't have to ask anyone, the gas saw sitting, not started, will confirm it.
If your oiler is not oiling that could explain the bar wearing out too.
Also branches and logs near to the ground can get enough dirt on the bark to dull a chain fast. From dust and from rain splashing mud up off the ground. You need to develop a habit to "clean a chain cut path" with one quick swipe of the chain, so then each tooth doesn't drag dirt into the cut. Just assume the bark has dirt on it and make a quick 'line' ahead of your cut path. Then when the chain is pulling hard, throwing big chips, you know its in 'clean wood'.
/ Chainsaw Sizing #14
It might do the job where you are on fir and cedar. I would not wish for anything bigger than an 18'' bar on my 034 over here on sugar maple beech or oak.
/ Chainsaw Sizing #15
Discount tool manufactures reduce cost with loose tolerances and other corners cut. If I have a job to do, I like to use something that runs well and is dependable. I think you be better off with two saws with dedicated bars, not switching them out.
I had a Poulan Pro pole saw and that thing was super handy but couldn稚 keep it running. Ran good as long as it was running wide open. Let off the throttle and it would die. I have found that extended handle loppers work just as good for what I used the pole saw for.
/ Chainsaw Sizing #16
Look at the Husqvarna saws at Loews. I have had excellent service from them. Upgraded later to their professional series but I think that would be an overkill for your uses. The 455 and 460 Ranchers are beasts for the money. Never had a starting problem.
Ron
/ Chainsaw Sizing #17
Try a new new chain first.
Your present chain may have been overheated when used dull. That takes the temper out of the teeth.
Keeping the chain sharp at all times makes for much easier sawing. Many do a touch up sharpening after several tanks of fuel. Others keep more sharp chains at hand so they can change them out during the day. Then sharpen them all at one time.
If buying new it’s the cc’s That count. There are different bar lengths and chains available for the same head. Shorter bars handle easier. Longer bars cut longer but slower. If extremely long for certain cut’s the feed rate must be greatly reduced to avoid overheating the saw.
/ Chainsaw Sizing #18
I like the 2 saw route.
For trimming a small light saw works great with a .325" pitch chain is all you need. No sense in slinging a big heavy saw around that tires you out. I find that cutting brush and small sticks where the saw is going from one brush to the other is when one can get careless "slashing" (to quickly and blindly). As such a light saw helps.
For firewood, #1 priority is I want a .375" pitch chain. IMHO it's night and day compared to a.325 chain.
I also want a bar that 's big enough for 80% of what I'm going to cut (for me a 18" bar is plenty), I like the 50cc -60cc range, and a good horsepower to weight ratio. Weight being very important if you're going to run it for an extended period of time.
/ Chainsaw Sizing #19
I had a Poulan Pro pole saw and that thing was super handy but could not keep it running.
I have owned a $350 Stihl (Silky) PP800 manual pole saw for five years.
Great tool. Never again a gas powered pole chainsaw for me.
VIDEO: Stihl PP8 Telescoping Pole Pruner - YouTube
/ Chainsaw Sizing #20
Chainsaws are like tractors. You will find a lot of loyalty from those who support what they already have, but haven't ever owned anything else. Stihl is a good brand. I wouldn't spend the money to replace it just because the chain doesn't stay sharp for as long as you want it. I would figure out why it's going dull, or if you even have the right chain on she saw for what you are doing. There is a good selection of replacement chains out there, and chains are pretty cheap to replace. My first stop would be at your local Stihl dealer with your saw and I'd have a little talk with the people that work there.
While there, ask about a file to sharpen the chain yourself. I keep a chain on my saw until it's so stretched out that I can no longer tighten it. Brand new and it cuts really nice, but once it's starts to wear out, I start hitting it with a file before using it. It takes about five minutes to do the entire chain, and I just consider it part of my getting the saw ready routine before using it to cut rounds for firewood. Once you get the hang of it, you'll never have a dull chain again!!!
I've tried quite a few different brands, and like Echo the best. For a little less money then Stihl, you can have the same amount of power, but a saw that starts a lot easier. For the same money that you spend on Stihl, you can get a much better Echo. I have three Stihl chainsaws, one Echo and one Remington electric chainsaw. When working out in the field, I prefer the Echo, but my biggest and smallest saws are both Stihl, so I use them too. For pruning around the house, and cutting posts, I just love the electric Remington chainsaw. It's 110 volts, so you need a cord, and that's the only drawback. It's super light, and cuts as good as any small gas powered chainsaw out there. Just add oil to lube the chain and go!!
My wife likes to prune the trees, so I let her use my Makita sawzall with Porter Cable pruning blades. I use them all the time for cutting roots when digging footings or post holes, but she loves it for cutting low branches. She will stand in the back of the Mule, or even on the roof to get branches with it!!! I have six batteries for it and three chargers, so she's able to prune all day long and I'm comfortable with her using it without getting hurt.
We also have a telescoping pruning tool that you pull the cord and it cuts the branches off. It's for stuff an inch thick or less. Before grabbing a chainsaw, I'll use that if I can.
2017 Crane Carrier Co. G-S Products 23yd Dual Side-Load Refuse Garbage Truck (A66736)
2017 Crane Carrier...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
SHELVES WITH HEAVYEQUIPMENT ITEMS (A68842)
SHELVES WITH...
1994 MACK CH613 FUEL AND LUBE TRUCK (A67714)
1994 MACK CH613...
2012 ATLAS COPCO  AIR COMPRESSOR XAS 375 (INOPERABLE) (A68842)
2012 ATLAS COPCO...
2022 TAKEUCHI TL12V2 SKID STEER (A65053)
2022 TAKEUCHI...
