newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,879
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
I知 35 years old if that matters.
I had a Poulan Pro pole saw and that thing was super handy but couldn稚 keep it running. Ran good as long as it was running wide open. Let off the throttle and it would die. I have found that extended handle loppers work just as good for what I used the pole saw for.
But I either need two size saws or one good saw with 2 different size bars. Would probably be buying Stihl whatever I decide to go with.
I might have missed it but all I see for your uses are "small saw" short term tasks. 90% or more could be handled by a 40V chainsaw, might need an extra battery.Fellas, I知 thinking about upgrading chainsaws but I have very little knowledge about what might be 途ight for me. Right now, I have 2 saws for different purposes and that system seems to work well though I知 not entirely happy about my saws that I currently have.
One saw is small and lightweight and I use it around the house property (6 acres) for pruning limbs and cutting up down limbs. I also use it at my hunting property for keeping ATV trails cut back from growing in and also for cutting shooting lanes and stuff for new deer stand locations and such. About 7 years ago I bought a Stihl MS 170 and like the size and weight, but the dang chain gets dull almost immediately. I keep it out of the dirt, no rocks, but still I知 constantly trying to keep it sharp. I知 at a point now where the bar needs replaced and I知 wondering if I should just get a new saw altogether and keep this as a backup.
I had a few mature trees fall at my home property and quickly realized the MS 170 was way to small to be cutting up whole mature trees for firewood. So at the time, money was tight and I needed a bigger saw so I bought a Poulan Pro 18 and used it to cut up the big trees. I noticed immediately that the chain stays sharper for a lot longer and I致e not had any problems aside from it being harder to start than the Stihl. It seems to have plenty of power for what I致e used it for, but does feel a little cheaper than other brands.
I definitely use the smaller saw way more though. So I guess first question is whether I should stay with my 2-saw system or just get one good quality saw. Second question would be what should I buy to replace my MS 170 with first and then later replace the Poulan with? First priority is really doing something about the MS 170. Aside from being easy to start and being lighter weight, it痴 a pain to keep sharp.
Your not cutting cords of firewood or milling trees. Replace the chain on the 170, keep it sharp. But I believe a 40V saw with a 14" blade would fit most of your needs.
