RX6010 motor failed @ 450 hours
Status
Not open for further replies.
   / RX6010 motor failed @ 450 hours #11
Apparently something let go in the valve train trashing two cylinders and cracking the head.
Five years old but only around 450 hours and out of warranty.
Both dealer and myself contacted Kioti and they have determined to offer no help what so ever with the motor rebuild despite the ridiculously low hours and lite use the tractor has seen.
A replacement motor only carries a 1 year warranty I’m told so that’s not worth the cost IMO.
Tractor will be repaired at our expense and then traded or sold.
Very disappointing that Kioti offered no help whatsoever with the repairs. Not only have they lost a customer but they’ve gained an unhappy brand detractor.
Sorry to hear of this. You can try to get your dealer to talk to Kioti about Kioti funding good will work. Aftertall, that wouild be io their best interest, given that Kioti's warranty department is earning the reputation among their dealers at working hard to not warranty anything and an engine shelling this early is nothing but pie on their face--especially so since it is a current production model.
   / RX6010 motor failed @ 450 hours #12
That is truly a shame that with such low hours they refuse to help you out on this. John Deere is the same way and they are a huge Corporation.
   / RX6010 motor failed @ 450 hours #13
Apparently something let go in the valve train trashing two cylinders and cracking the head....
First, welcome to TBN, sorry that itç—´ under unfortunate circumstances.
If it were my tractor I think the first step is to ditch the 殿pparently and figure out exactly what went wrong or at least come up with a reasonable and detailed explanation for the failure and why it should not have happened. Kioti may be thinking é„*pparently this guy ran it out of oil or messed up the valve adjustments or some other form of owner abuse.
Tractor manufacturers get a lot of requests for out of warranty repairs that are due to owner screwups and they may arbitrarily say no the first time out of self-preservation. If you are persistent and can show them exactly what part failed and that it was a Kioti failure and not due to something you did or didn稚 do they might end up with a different response. If for nothing other than curiosity about this expensive failure I壇 want to determine exactly what happened.
   / RX6010 motor failed @ 450 hours #14
That is a great idea.
   / RX6010 motor failed @ 450 hours #15
you can knock them here. KIOTI Tractor - Home | Facebook perhaps after that, and many others agreeing with you, they may change their tune, and not be so cold!.. their tractor should not be destroying itself at 450 hours!. maybe a defect, or just improperly torqued bolts from the factory!..
   / RX6010 motor failed @ 450 hours #16
As is clear, Kioti is not obligated, so bashing them for their lack of responding to a not-contractually obligated response/action isn't fair.
First step is to gather data, find out what happened. If there is a smoking gun pointing at Kioti's engineering or manufacturing process THEN one can use that to try and gain out-of-warranty help: ONLY way for a manufacture to improve on their products is to have a good feedback loop (warranty work usually provides for this documentation process).
I haven't looked at the video yet. The question raised as to who installed the block heater is a good one to get an answer on: if only Kioti or Kioti-backed dealers are responsible for touching the engine for anything other than simple maintenance then one has a good leg to stand on for pushing for some sort of compensation/help.
   / RX6010 motor failed @ 450 hours #17
That is the block heater it blew out.
If one but looks their are countless horror stories about block heaters.
Circulating hot water heaters are used by by those that know the difference
   / RX6010 motor failed @ 450 hours #18
I believe that the block heater blew out when the motor exploded. My guess is that this tractor dropped a valve which them lodged between the piston and cylinder head. When the head cracked, the compression blew out the block heater. I hope the owner puts up pictures of all the parts so we can see what happened.
   / RX6010 motor failed @ 450 hours #19
^^^ I agree!
Most likely a valve train failure is at the core of this. Things like this can usually be identified (when things are disassembled*).
* I'd look to take MANY pictures of the process. I'd actually figure an independent shop might be best as there could be no owner bias introduced; but, this is extra expense.
   / RX6010 motor failed @ 450 hours #20
I think that any reputable dealer would be honest enough to help this guy out. Although I do recall working at a Ford Dealership back in 1979 where a guy brought in his Ford Torino with a defective motor that was involved in a recall. The warranty for the recall was for under 50K motors. This guy had 51K on his. I overheard the service manager tell him sorry, there is nothing that I can do. I did the motor swap on this car with a new motor. The service manager told me put it aside as it is going back for warranty. This SOB screwed this guy on his motor and double dipped on the repair work. I should have turned him in for it, but I needed that job.
Status
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
LOT: (10) Chairs (A59076)
LOT: (10) Chairs...
1997 LUFKIN  48X102 FLATBED TRAILER (A58214)
1997 LUFKIN...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
