4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,189
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I thought I’d give hauling rock on the trailer and driving up the end to unload it it try. First off this is hard on the decking. If your trailer gets washed and waxed after each use forget this idea. I view the decking as a consumable and I’ll replace as needed. I didn’t have any sideboards and hauled about 5 bobcat scoops of rock which is probably 1500 pounds a scoop and didn’t loose any. So if your trailer is 10k or less you really don’t need any sideboards. Even a 2x4 sideboard would significantly increase the hauling capacity without spillage. Driving up to unload and placing the rock where I wanted worked beautifully. The biggest problem I had was pushing rock off the sides which would be a non existent problem with side boards.
