Rounded off drain plug
/ Rounded off drain plug
To make the plug square again, I'd file the edges down with a Harbor Freight air file. Of course, you'd also need an air compressor large enough to support air tools.
I have a dewalt battery cut off tool and an IR air cut off tool. I've misplaced the tool to change the disc on the dewalt, but i should be able to use the air tool in bursts if i can find a grinding disc suitable for it. The big compressor we have crapped out last year, engine seized I believe. I replaced it with a 13 gallon c&h compressor solely for tire fill use.
/ Rounded off drain plug #682
Grind/file the whole exposed part of the plug parallel down to the root dia on just 2 sides. Dont cut into the root much. The root wrench surface is getting too small. Youre looking at twist off time.
Use a Crescent that will fully engage the faces to gauge // -- and then to take it out. You get 1 try.
/ Rounded off drain plug #683
For the dewalt:
Take an appropriate length 2x4 and two 20d or 16d nails, hammer the nails in the 2x4 at the spacing you need and cut the heads off so you've got got about a half inch of or so of nail sticking out. You've now got a spanner wrench.
/ Rounded off drain plug #684
I wouldn't do any grinding on what you have left of the plug. Soon you will have a greater problem than you have now.
Find someone with a wire welder they can bring over and help you. Get a piece of 1/4" flat bar, about 2" wide, 12" long. Drill a hole in the end so it fits over the remainder of the plug that is hanging down. Insert the plug into the hole and weld it there with the flat bar facing in a direction you can get some leverage on it. A little 110V wire welder can do this job and fit in the area easily.
/ Rounded off drain plug #685
I like this idea. The heat from welding on the flat bar may help loosen the plug also.
/ Rounded off drain plug #686
For the dewalt:
A buy several of these next time you are in Harbor Freight.
Adjustable Pin Wrench
Bruce
/ Rounded off drain plug #688
For the dewalt:
What I have done is drill two holes in a flat bar at the right spacing. Set two pins from a roller chain in the holes and weld them into place. Works very well and cheap to do.
/ Rounded off drain plug #689
Hammer and chisel five minutes three hits with the hammer and its finger loose. Come on no rocket scientist needed.
/ Rounded off drain plug #691
What D2Cat said.
Iv been thinking of using a hammer and punch for a long time. I didnt mention it due the continuing demonstrated saga of fiasco finesse.
/ Rounded off drain plug #693
good, except that you have to re-harden the pins after welding, welding takes the temper out.. heat up to orange, quench in oil. if the pins cant be filed with a file, then you know they got hard enough..
/ Rounded off drain plug #695
Still like the hole in the bar stock.
At this point, with a skilled welder, surely the most straightforward solution.
/ Rounded off drain plug #696
Make sure the bar can make a full turn without interference. :)
Bruce
/ Rounded off drain plug #697
Bruce
Exactly. That's why I prefer welding a nut over the stuck plug. Then you can use any wrench or socket that fits the new hex nut.
/ Rounded off drain plug #698
It's too bad that there isn't a TBN member close enough to go help the poor guy out. People keep giving suggestions based on their own level of expertise and Kando is a good egg about it; but doing the wrong thing at this point could get expensive.
/ Rounded off drain plug #699
I agree but taking it to a welding shop shouldn't be ruled out. I can stick things together and do 90% of my own. However,when it's crtical as in life and limb,I tack it up then have a pro finish it.
I got bombarded with 'do it yourself' when I suggested running it to a shop. The option is in mind.
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
RoadTec RP190 (A63118)
Knapheide Service Bed (A61165)
Knapheide Service...
2018 Forest River Travel Trailer (A61569)
2018 Forest River...
2020 POLARIS SPORTSMAN HIGHLIFTER XP-1000EFI ATV (A62131)
2020 POLARIS...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
