Sourcing Early Toolcat Wheels and Tires
   / Sourcing Early Toolcat Wheels and Tires #11
Even a LT235x70-15 truck tire with a load rating of D would work and would be about 28" tall.
backspacing looks to be about 4.5"
Purchased wheels with 4" backspacing from the link someone posted on the other page
Will 235/75R15 fit a series C toolcat? Is load range C too low?
   / Sourcing Early Toolcat Wheels and Tires #14
You should be able to check tire clearance at the extreams with the info you have. That tire is a 29" dia so I would think it would fit with that rim. If it were me, I would try to get a D load range tire as I run over the occasional stump/rock. If I was crawling over that stuff daily, go with a E rated tire.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=55
   / Sourcing Early Toolcat Wheels and Tires #15
I have been lurking on this topic for quite a while. opinions are like A**holes, everyone has one. I have settled on BKT LG306 tires. at about $125 each, not that bad on the pocket. they are turf tires and I think will sute the cat well, at least for my purpose. the current lug tires flat out suck for snow that is for sure. I have to pull the trigger soon as snow is coming to get us here on the east coast. I am interested in the new wheel info provided above. if anyone buys them would sure like a report as to how they work for you. thanks
Wheels came in today, I plan on mounting one up soon to verify fitment before I get tires
Wheels bolt right on without issue, they are 15x8 with 4 backspacing, 6x6 pattern with 4.63 centerbore. Oem wheels appear to be 4.5 - 4.625 backspacing but extra outboard spacing doesn't look like itll cause clearance issues. I ordered another set of 27x10.50-15 R4 load range D tires for $375 shipped from simpletire. The wheels were just under $300 shipped so I'll be into them for around $700 total. If I have winter traction issues I'll get a set of chains
Here are pictures of one wheel mounted on the front:
   / Sourcing Early Toolcat Wheels and Tires #20
Pictures didn't upload.
Are you using a phone or computer?
NEW Long Forks (A59000)
NEW Long Forks...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
