Storing backhoe attachment for the winter?
/ Storing backhoe attachment for the winter? #21
Never use a tarp. It can trap moisture. Use a breathable car cover.
/ Storing backhoe attachment for the winter? #22
Don’t store near a tree. During a wind storm a large tree fell and bent my top hydraulic cylinder rod.
/ Storing backhoe attachment for the winter? #23
Yes. This is exactly what I am planning to do! Thanks for sharing.
Glad you like it, it took several changes to finally get what I wanted it to do. Sorry it took so long to comment, but have been unusually busy.
/ Storing backhoe attachment for the winter? #24
I have a Kubota L3560HSTC with a BH92 backhoe, I always store mine inside the barn on a dolly I made. I prevent "sag" of the out-riggers by hooking them together with a tie-down ratchet strap.View attachment 575517View attachment 575518
Nicely done! I do the ratchet strap thing as well.
I use standard 4'x4' shipping pallets for all my attachments like backhoe, snow blower and heavier stuff like log splitters, snowmobile, SXS etc.... Then move them around my shop with a pallet jack.
Jack was like $200 and pallets are free all over the place where I am.
/ Storing backhoe attachment for the winter? #25
I used bailing wire last winter to hold up my BH outriggers. Like the idea of a lightweight ratchet strap... got plenty.
I use pallets for my idle implements as well. Works great to move them around and I even stack them with my forks albeit somewhat precariously to save real estate.
/ Storing backhoe attachment for the winter? #27
I have never owned a backhoe before, I want to take it off for the winter (sub frame mount) .
What is the best position to leave it in for ease of taking it off and putting it back on.
The backhoe in question is a Woods Groundbreaker 7500 on my Kubota L2850.
Thanks and pics of yours stored would help :)
I have a quick (15 min.) disconnect hoe.
I have had it off once in 30 years.
I don't use the TLB often, but when I do, I may need both the hoe and loader functions.
I often have 3pt. hitch needs, and the TLB (with hoe removed) does have a three pt hitch.
It would not be even remotely practical to remove the hoe every time I might need the hitch (maybe 2 or 3 times in a day?).
The answer is simple: Have at least one more tractor!
My tractors are all for play. I do not need a new tractor. I have older tractors in excellent condition for dedicated use.
I probably have a similar amount of total $ tied up in my 3 older tractors as many do in a nice shiny new one, but it is SO convenient to just jump on the one I need for the designated task.
Besides: I find DPF and/or Regen, and complicated electronics to be simply unnerving.
Two of my older tractors have been completely refurbished, and except for body style, actually do look like new.
I like that philosophy! I have been slowly searching for the right deal on another 30-40 hp tractor. My list of needs is simple, 4x4, loader and a bargain!
/ Storing backhoe attachment for the winter? #29
If you can be patient, the right deal will eventually come to you.
Took me two years (30 years ago) to find the right medium sized TLB.
/ Storing backhoe attachment for the winter? #30
Sooo, I ask again. Are there any negatives to leaving the backhoe on the 2601 in storage for the winter?
I cannot imagine a problem leaving it on. I have a B21 with backhoe that has never been off the tractor in the 15 years I have owned it. I am thinking about taking it off this year.
The manual suggests putting blocking under the main subframe to enhance stability. If left outside, it suggests covering it with a tarp to protect it.
/ Storing backhoe attachment for the winter? #31
Thanks for the helpful information and the pics. I have a BH92 backhoe and will use the strapping to keep the out-riggers up as you showed. I have a number of automobile dollies that I can add some wood tops to in order to create a similar dolly set up as you show it. Do you drop the unit directly down onto the dolly? Also, it looks like it would be easier to line up when re-attaching (moving the dolly/bh92 instead of tractor back and forth to line up perfectly. My storage shed has a concrete floor also.
/ Storing backhoe attachment for the winter? #32
Glad the post was helpful, one other thing I did, was I made the part that goes under the tractor wide enough to touch the tires, that way I know I'm in far enough and not too far and it lines up better. The concrete floor makes it easy to roll around, though it is EXTREMELY heavy and takes a lot of effort to move it, but it does make it easy to line up like you said instead of moving the tractor to get the line up. Also, I store the BH92 sideways in the barn to save room, works great!
2019 F150 (A61306)
2019 F150 (A61306)
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2017 Ford Explorer SUV (A61569)
2017 Ford Explorer...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
